Question about Bosch 24 in. SHE44C02UC / SHE44C06UC / SHE44C07UC Built-in Dishwasher
Bosch dishwasher wont take in water through the cold inlet
No obvious physical block, plumbed in, and switched on.....?
Please help,
  • 10,865 Answers
First of all, the hot water line should be supplying the dishwasher, not the cold water line. That being said, if the machine is hooked up to cold water line, the only reason why no water is coming in would be that the valve is not open. Look under the sink to see if that is where the dishwasher line is attached to the cold supply. If not there, perhaps in the basement. Open that valve and you should have water.
Finally, if there is no water coming in and you have a lime deposit problem with your water it is possible that the line is full of lime and will have to be changed. good luck with this.
Posted on Feb 13, 2009
Bosch dishwasher is not filling with water and detergent is not being released.
The soap wont come out if there is no water. Does the detergent flap open? If so, the dispenser is OK. If not, you need a new dispenser. If the machine is not filling, check the pressure switch and or the tubes that go to the pressure switch, they may be blocked, tricking the machine into thinking its already full of water.
Feb 27, 2015 | Bosch Dishwashers
SG13002GB/07 bosch dishwasher: Water isn't getting
1. Water inlet valve is faulty = replace 2. Main motor (circulation pump) faulty = replace
Jun 23, 2017 | Dishwashers
Hi, The dishwasher is not filling with water. Have checked all the obvious hose blocked, pump clear etc.... Please help Jayne
The problem is likely with the water inlet valve or float switch. Both are inexpensive and easy to check/ replace. Here is a link that should help
Aug 31, 2010 | Dishwashers
I have an FDF780 dishwasher that wont spray water
Sounds like wash pump is weak or siezed.
Sep 28, 2009 | Dishwashers
Dishwasher not taking in water
It could be a few things, one of them is a defective water inlet valve, the water inlet valve lets water enter the dishwasher from the main water line, another thing it could be is a defective float switch, the float switch rises up as water fills the dishwasher.
Mar 13, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch aquasensor
no it should be plumbed into the hot side... it will not wash untill the water is hot enough ...
Aug 20, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Hot water fill
No you need to plumb into COLD only the unit has a built in heater if you plub it into hot you will ruin the sealve and the inlet valve will fail
May 11, 2008 | Bosch 18 in. SRS55L02 Logixx Slim-Line...
No water coming in
is there water in the bottom there is a float switch there which shuts off the inlet valve
Jan 03, 2008 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Bosch 24 in. SHE44C02UC / SHE44C06UC / SHE44C07UC Built-in Dishwasher Logo
234 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
