Question about Lexmark All-in-One Printer with PictBridge
New Lexmark 6500, will not print, says load paper
When I send something to the printer to print, it says load paper, the paper is already loaded according to the instructions, if I press down on the paper then it sounds like it is printing, but doesn't print and then says paper jam. I don't know what else to try. Thanks for your help.
Having the same problem... did you figure it out?
Posted on Apr 29, 2010
After the paper is replaced you must push the checkmark button
zzat2@hotmail.com
Posted on Mar 17, 2009
    Genius:
  • 2,120 Answers
If you have a by-pass tray, load paper in it.
Posted on Feb 13, 2009
Machine is asking to: Load manual Feeder with Custom Type 1 Letter
in the printer properties during printing change the "paper size" from letter to a4
Jan 23, 2014 | Lexmark Xs736de All In One Laser...
Lexmark 734dn error is "load more paper and continue"
Check if the correct paper type and size is set in the printer settings. Also check if the paper guides are set to the correct size in the paper tray. Sometimes, the paper sensors will not detect the correct paper if the guides are set to the incorrect size.
Aug 20, 2012 | Lexmark C734DN Laser Printer
My HP officejet 6500 keeps giving me two messages 1. load paper when there is already paper and two align cartridges for 7 minutes.
before you on the unit put a single page on a tray then turn it on while initializing it feeds the paper automaticaly then print a sample page after printing put the sample page face down on the scanner then press the scan button then wait till the power on light stop blinking then youre ready now
Aug 09, 2011 | HP Officejet 6500 Wireless All-in-One...
My lexmark t430 says load mp feeder letter. what does this mean?
You have send a print job from your application (ex. word), and the paper format in this appl. is letter. The printer tells you to insert a letter format paper in the mp (multi purpose) feeder (upper the tray).
If you press the GO key the print probably proceeds with print job (if has the paper load in mp feeder)
Feb 23, 2011 | Lexmark T430 Laser Printer
Whenever I try to print something I keep getting
It's a possible hardware issue in the feeding mechanism. Try to remove the cartridges from the printer then close the cover. Remove the sheets of paper. Unplug the printer from the power source. Wait at least 30 seconds before plugging back the printer to the power source. When the printer's ready, reload the cartridges. Load some paper but don't overload as this may send wrong information to the printer. Have the paper guides lightly touch the sides of the paper, thus avoiding shifting of paper when it feeds. Let it print an alignment page and do some test prints from computer. If problem persists, I strongly suggest you contact Lexmark Technical Support to further investigate the problem. Thanks.
Jul 25, 2010 | Lexmark X4270 All-In-One InkJet Printer
X5470 lexmark has paper jam now makes squealing noise when I use it!
Try this. Remove any paper jams, take out all sheets of paper and remove all cartridges from the printer. Close the cover. Unplug the printer from the power source. Plug it back in after 10-15 seconds. When the printer's ready, re-insert the cartridges. The printer will print an alignment page. Load just 5 sheets of paper only. Let it print the alignment page all the way through without cancelling it. If printer is not making the squealing noise, problem resolved. If it's still making the noise, the printer's mechanism somehow got affected by the paper jam now. If that's the case, any mechanical/hardware problem in the printer, it's better to ask assistance from Lexmark. If printer is damaged already, and it's still within warranty, they might send you one for replacement. Good luck!
Apr 07, 2010 | Lexmark X6170 All-In-One InkJet Printer
Lexmark t630
Paper size is incorrectly set!.....
Merlin's idea, of what paper Lex has, and Lex's are different or you have loaded Lex's tray with the paper sideways
Your in Oz so it would be A4 standard and I guess your trying to print B5 script. Try these
The printer has been loaded with one size paper but thinks it is another. change printer settings via keypad on printer
The B5 scripts paper is being loaded sideways instead of length ways or visa verse
There is a incorrect setting in the printer driver that is set up for this specific printer that 'merlin' uses, check print driver setting (control panel,printers and fax, right click on lexmarkt642's icon, properties and check properties fully) in windows software that is running under merlin, also check merlin settings if any for this printer
Nov 20, 2007 | Lexmark T642 Laser Printer
Cant load paper into my printer
My name is Vikram Kumar Thumu, from India-Hyderabad. I have seen your message on the issue related to loading the paper    . I would like to provide my suggestions on the issue. I hope that this should work for you and will resolve the issue.
Please try below steps if you want to know how to load paper in to the Feeder.:
Important: When loading paper into the feeder, make sure you are using separated (i.e., cut) sheets of paper. Banner paper that is connected end-to-end should not be used unless you are specifically printing a banner.
To load separated sheets of paper:
  1. Obtain a fresh stack of paper.
  2. Separate the paper by bending it back and forth in an "S" shape before loading it into the printer.
  3. Place the paper against the right side of the sheet feeder, with the print side facing you.
  4. Gently insert the paper into the feeder. Do not  force the paper down into the printer.
  5. Squeeze the release tab and the paper guide together, and slide the paper guide to the edge of the paper.
Humid conditions may cause some sheets of paper to stick together.
If the issue still persists,  then I recommend you to look in to USER MANUAL that is provided along with Printer for instructions on loading Paper.
Well, for your convienience I'll provide you with steps that helps to access USER MANUAL.................
Steps are :
  • If the Lexmark P4300 software is already installed in Windows:
    1.  Go to Start, (All) Programs, and point to Lexmark P4300 Series.
    2.  Select User's Guide.
  • If you have not yet installed the Lexmark P4300 software, you can find the User's Guide on the installation CD.  Do the following:
    1.  Insert the CD into the CD-ROM drive. The Lexmark installation screen should appear.
      • If the screen does not appear, open My Computer and double-click on the 4300 Series icon.
    2.  Click on the ?  icon to the left of View User's Guide (including setup troubleshooting).  You will be asked whether you would prefer to save the User's Guide to the desktop and view it from there (Yes), or to view it from the CD (No).
    3.  Select the option you prefer.
  • This should resolve the issue for you.
     If you need any further assistance on the issue, you can mail me at thumuvikram@rediffmail.com . I'll be glad to help you.
    Bye.
    Oct 18, 2007 | Lexmark P4350 All-In-One InkJet Printer
    Lexmark All-in-One Printer with PictBridge Logo
    210 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
