Question about Garmin nuvi 200W GPS Receiver
Screen reads "No detailed maps found that support routing."
"The nuvi cannot be used without them."
  • Anonymous Apr 11, 2009
    Same problem. I think this fixed it.
I just posted this for someone else and it worked on my Nuvi 200:
"When you downloaded and installed the WebUpdater, you also got a program called MapInstall. Use it, pick the states/areas you want to install and watch the bar on the right. It will turn green and "fill up" as it calculates the amount of space needed on your gps vs. the amount available. When you have chosen too much it will let you know by turning all red.
You can ignore that huge 2GB executable file Garmin had you download. I think it's supposed to be a self extractor/application for installing the maps but has three drawbacks: One, it's painfully slow; Two, it does not work. It will go way past 100% completed and then give you a message that it failed to update your maps; and Three, once it begins the update it erases your old maps leaving you with a Nuvi that's useless without them. I tried it three times, with three different machines (after waiting 45 minutes for the Garmin helpless desk to tell me it was my chipset that was causing the problem. Nope) and got the same result. This leads me to believe the self extractor is flawed.
Once you have chosen all your states or provinces, click on the finish button and it will load those maps and you'll have a usable, updated Nuvi again. I spent the best part of a day with the .exe file because the process was so slow, and when I did it the above way it took maybe 20 minutes.
Good luck, hope you see this solution."
Posted on Feb 14, 2009
The screen is reading "no
what you can do is restoring it or update it and it will work again
Apr 12, 2011 | Garmin Nuvi 660 GPS Receiver
My gps says "no
Question: What should I do if my Garmin nuvi or zumo displays the message "No Detailed Maps Found That Support Routing" or "No Map Data Available?"
--> Answer: The "No Detailed Maps Found That Support Routing" or "No Map Data Available" message may appear on your device for the following reasons:
  • The GPS device is missing it's unlock code
  • The maps on the GPS device have been disabled
To determine the cause of the message, touch the screen until the message "No Detailed Maps Found That Support Routing" disappears.
  • If you see a "Can't Unlock Maps" message following this error, remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device
Retrieving your unlock codes:
  1. Log into your myGarmin account
  2. Select Manage Maps
  3. Select Details
  4. The unlock code is located under the Installed Maps.
Nov 16, 2010 | Garmin Nuvi 360 Bilingual GPS Navigator...
Garmin Nuvi ~ No detailed maps found that support routing.
Please see this link for more inforamtion on this problem. I can help you resolve the issue. Your map unlock code is either corrupted or missing.
http://www.sharc.net/discus/messages/6/250.html?1247812497
- Jim
Jul 11, 2009 | Garmin nuviĀ® 200 Car GPS Receiver
My Garmin nuvi says ''maps unavailable''
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The "No Detailed Maps Found That Support Routing" message may appear for the following reasons:
  2. Select myMaps
  3. Select Manage Maps
  4. Select the device from the drop down menu
  5. The unlock code is located under the "Maps installed on this device" section
    /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Enabling maps on the GPS device:
    1. Touch the wrench icon on the Where to/View map screen
    2. Touch Settings
    3. Touch Map
    4. Touch Map Info
    5. Select the checkbox next to the maps to be enabled on the device
Mar 21, 2009 | Garmin nuvi 260W GPS Receiver
No detailed maps found to support routing
Have you tried updating the unit at Garmin's Website?
Let me know if you need help, I can get you the right web-link if needed.
Benjamin
Feb 28, 2009 | Garmin nuvi 255W GPS Receiver
"No detailed maps found that support routing".
Please click on this link to obtain more information on this problem:
- Jim
SHARCNET-USA
Feb 20, 2009 | Garmin nuvi 350 GPS Receiver
Screen with message.. " No detailed maps found that support routi
This error is caused by a corrupt or missing map unlock code. Please email me @ sharcnet-usa@sharc.net and I will talk you through on how to fix the problem.
- Jim
SHARCNET-USA
Feb 06, 2009 | Garmin nuvi 350 GPS Receiver
No detailed maps found. Help! Please
my email address is ada @ ebucksmail.com.
Can u please help with my sons nuvi 200 that shows no detailed mapsfound. Thanks A Million, Ada.
Jan 22, 2009 | Garmin nuvi 350 GPS Receiver
Garmin Nuvi 200 Maps Disappeared
Contact Garmins Tech support hot Line they will walk you through the process and if they can't fix it over the phone they will send you a disk that will completely fix the "NO detailed maps found that support routing" I have contacted them with the same problem and the disc was free of charge.
Jan 01, 2009 | Garmin nuvi 200W GPS Receiver
Garmin nuvi 200W GPS Receiver Logo
170 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
