Question about Bunn Coffee Makers & Espresso Machines
Bunn commercial coffee maker plug overheats, no hot water
Our bunn commercial coffe machne only heats water till warm and the plug over heats<
ideas? we think its the element?
  • 131 Answers
Most likely this is your heating element, but it could also be your main thermostat
Posted on Feb 13, 2009
How do you get a bunn pour omatic coffe maker to pour water into the hopper. I put water where it's supose to go it heats up but no water come out. Is there something I'm not doing. Its an older one.
did you pour in another pot of water? It heats up the reserve tank so you always have hot water instantly, but to get that water you need to pour in another pot of water to replace it.
Manual:
www.bunn.com/sites/default/...manuals/10424.0000.pdf
May 12, 2016 | Bunn Coffee Makers & Espresso Machines
My bunn 10 coffe maker just died
not brew if no water coming in to filll the tank
Jul 11, 2014 | Bunn GRX-B
Will not percolate. Water is poured, it heats up, no coffee brew
Bunn Home brewers don't perculate. They work the same way that commercial brewers do. Fillit with water, let it heat for about 20 minutes, then put your filter and coffee grounds in the funnel, pour a pot of water into the machine, put the pot on the warmer, and let the water run through. Then enjoy a nice hot cup of coffee.
Apr 12, 2010 | Bunn BX HOME BREWER 10-Cup Coffee Maker
I have had my Bunn since 1999 and I have had no trouble whatsoever until today, it decided to become a steam roller and will not shut off at the reserve hot water well. I have to power off the switch each...
It is most likely time to decalcify the machine. If you haven't made a regular practice of this, a cocoon of mineral deposits has encased the heating element causing it to struggle to warm the water adequately even as it overheats itself. If one or more decalcifications using white vinegar and the instructions in your owner's guide fail to improve the situation, the thermostat may be faulty. Contact BUNN for toll-free support:
https://www.bunnomatic.com/retail/service/contact.html
Mar 04, 2010 | Bunn NHB Coffee Maker
Our Bunn A10 Coffe Maker has no brew timer on the left side. How can we adjust the coffe maker so that we can get a full pot?
Hello. I need to know if you have an automatic unit, or a pourover. The pourover will not have a timer at all. The difference is you have to pour the water in to get coffee out, an automatic would be connected to a water line, and you just push a start button. If it is an automatic unit, there has to be a timer somewhere to adjust the amount. Here is a web address that has your manual, and a parts breakdown should you need to find where the timer is located.
http://www.bunnomatic.com/pdfs/commercial/manuals/29079.0000.pdf
Hope that helped, and thank you.
Mar 05, 2009 | Bunn A10 Coffee Maker
Coffe first pot is hot after that they are cold
This can be caused by scale build-up on the thermostat probe that hangs inside the tank. The scale stays hot for a long time, tricking the thermostat into believing that the water is still hot. Try pouring 1 Qt white vinigar into the unit, let it warm up completely, run a pot of clear water thhrough the machine, then turn the unit upside down over a sink (making sure it's unplugged first, and always keeping the fill hole down at all times) to let it drain out all the way. Then before you plug it back in, pour water through the machine until water comes out the sprayhead. Then plug it in, let it heat up, pour 2 pots of water through the machine & see if it heats up properly. If this doesn't cure your problem, your unit may need to be completely dismantled to de-scale the tank & thermostat probe.
Jan 20, 2009 | Bunn GR10 Coffee Maker
Bunn Coffee maker leaks
I called Bunn and they were not helpful at all! I wound up putting silicone (it is not hot enough here to matter) on it, and after it cured, it was great! We have been using it at the Office for almost a year with no problems. I just made sure I did not get any on the part that acts as the "valve."
Jun 23, 2008 | Bunn Pour-O-Matic VPR
Coffee Makers & Espresso Machines Logo
356 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
