Question about Insignia IS-LCDTV32 32 in. Television
Constant buzzing sound
My 37 inch flat screen has a constant buzzing sound and a purple bar that goes up and down the screen
  • 5575 Feb 15, 2009
    i have the same tv but the speakers wuit working all together.
  • 189 Answers
SOURCE: buzzing emitted by vsx-409
Could be the result of having DTS compatible equipment connected through the analog inputs on the VSX-409D. Noise and distortion will result as essentially the DTS signal is being played back undecoded. If this is the case you'll have to connect your LD or CD player through the digital connections (coax or optical) and set 'Signal Select' (button on front) to 'Digital'.
Posted on Jan 07, 2008
hawkwatcher
  • 67 Answers
SOURCE: Buzz or hum
My guess would be +and -12v supply to preamp opamps has ripple. (drycaps or bad solder). I may be able to get you a pdf service manual if needed. kstahl65@att.net
Posted on Jan 31, 2008
jerryg50
  • 1673 Answers
SOURCE: Purple and green scrolling lines
This may be a mechanical or electronic problem that is dealing with the sync of the colour wheel. There is basicly no colour lock. This may be the replacement of the associated circuit board, or the motor assembly or the colour wheel.
The link below is describing about how DLP technology works. They are relating to a front projection type. With the rear screen type, the basic technology is very much the same for decoding the pictures from the TV signal.
http://www.hometheaterhifi.com/volume_9_1/plus-piano-projector-3-2002.html
Jerry G.
Posted on May 06, 2008
praky16
  • 744 Answers
SOURCE: Black vertical bar about 4 and a half inches wide down center of screen
hi...
It sounds like an Intergrated Circuit (IC) has fried.
Your best bet in this situation is to contact ur tv service operator and let them recommend an authorized service center in your area....
rate me!!
Posted on Jun 01, 2009
  • 1138 Answers
SOURCE: Constant buzzing in my 15 W amplifier
Make sure you have a ground prong on your power cord. Most input jacks nowadays are closed circuit. They have a switch built in that won't allow any sound without the cord plugged in. You may have a damaged jack that will give you a loud hiss, a loud hum or crackling depending on what volume your controls are set at.
Posted on Aug 28, 2009
Buzz sound when tv is on constant
Hello; If you have a plasma TV, is fairly common to hear buzz noises. They can be always there or intermittent. They can get louder as the screen gets brightest. If the buzz is noticeable when you are at normal volume setting, the buzz is excessive and a PCB probably needs replacing. These buzz noises are almost never a sign of failure or safety. LCD TV's can also buzz, but the same applies. John
Jan 27, 2011 | Televison & Video
There is a constant buzzing sound coming from the back of my lg 37" lcd i returned the last one for the same fault and the replacement is the same any clues?
The sound is generated by the power source - it doesn't run smoothly because either it's defective (but 2 tv with the exact same defect one after the other is quite improbable) or you have a very bad mains power line, filled with interferences. Plug the tv thru a mains filter then check the voltage - if it's at 120 volts as it should and the sound is still there then return this tv also - you are really one of the unluckiest men alive.
Sep 07, 2010 | LG 37LC7D 37 in. LCD HDTV
36 inch tube tv - Screen flickers
my problem is don't sound in my mobile LG CE 0168 please help me.
Aug 17, 2009 | Toshiba Televison & Video
Buzing sound
Usually this is a defective main board, if it's under warranty it's an easy onsite fix. Usually takes less than half an hour.
Aug 11, 2009 | Vizio VO47L 47 in. LCD TV
Audio buzzing
Check the cables because this sound comes when the polarity of wires interreact with each other.
May 07, 2009 | Vizio GV42L 42 in. LCD Television
Buzzing sound after only 2-1/2 years of service
I suspect you have a bad set of capacitors in the control module. This problem usually starts out as a high pitched noise but can lead to the TV not turning on. Please see the link below, posted by StivO. It gives step by step instructions on how to replace the capacitors. This is a very inexpensive fix.
http://www.fixya.com/support/r741402-polaroid_flm_373b_lcd_tv_black_screen
Apr 13, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Samsung SP-S4243 has a constant buzzing noise
This is most probably you inverter board making the sound, most probably a bad solder joint, It would be hard for me to help you any further, but if it is a bad solder joint it could be repaired. Most shops no longer repair boards they just replace them.
If you have the knowledge you could do this, but I would recommend it other wise, there is High Voltage to deal with. I hope this helps. Merry Christmas!
Dec 23, 2008 | Samsung SP-S4243 Television
Noise coming from power supply
When we turn our TV the humming and buzzing begins! We cn mute it and it goes away and then it when we turn the sound back on the sound is back! How can we fix this?
Sep 18, 2008 | Polaroid FLM-323B Television
Buzzing sound coming from speakers
You maybe be able to turn the internal speakers off through the tv's menu...either in the Audio section or in Settings
Mar 15, 2008 | Proview PA-32JK1A 32 in. LCD Television
Insignia IS-LCDTV32 32 in. Television Logo
54 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
