Question about Maytag MMV1153A Microwave Oven
No heat from my microwave maytag mmv1153aaw
From previous posts I read that the problem is with the diode, capacitor, or the magnetron. I was wondering if anyone knew how test for the faulty component?
  • William Miller
    William Miller May 11, 2010
    Are the inside light, turntable and cooling fan coming on when you try to microwave?
    Is it making any unusual noises?
    Louder or quieter than normal?
    These answers will help
    me judge whether it's in the high voltage
    section (magnetron, transformer, or diode) or the control section
    (door switch or control board relay or connection).
  • Maytag Master
  • 9,098 Answers
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
But if when you start to microwave, if the turntable, inside light and internal light are not on, then you instead have a bad door switch or door switch mount, in which case you should see this:
http://www.microwavedisplay.com/doorsw.txt
Posted on Feb 15, 2009
Carosel won't turn and won't heat
Investigate these three areas if your microwave won't heat
Power Diode
A diode is an electronic component that readily passes current in one direction only and blocks the flow of current in the opposing direction. If your microwave's diode has become defective, your microwave will not heat. Test the diode to determine if this is the cause of your problem. Replace it if it is defective.
Testing a diode
NOTE: Before you test your diode, make sure your microwave is unplugged, and that you discharge the microwave's capacitor.
Whether it is shorted or open, a defective diode will most likely show some sign of defect. Defective diodes will usually emit an electrical burning smell, signifying its defectiveness. Also, it may have split in two, or it may exhibit a burned crack, or possibly even a blistered spot.
A shorted diode is indicated by a loud humming noise from the high voltage transformer, and no heat produced when a cook cycle is initiated. Whereas little or no heat produced in your microwave, with an absence of a humming noise is indicative of an open diode. In either case, the diode has to be replaced.
With your microwave unplugged, and your capacitor discharged, use extreme caution to remove the lead that leads to the capacitor. You can leave the ground connection attached. The side of the diode that goes to the ground is usually marked with a dot, stripe, or arrow. Set your ohmmeter to R x 10,000 or higher. Touch the positive meter probe to the anode and the negative meter probe to the cathode to measure the resistance across the diode terminals. Remember that the cathode is on the side that goes to the ground, which is often marked by a dot, stripe, or an arrow.
A normal diode, that is a non-defective diode, will read anywhere from 50,000 to 200,000 ohms. Differences in microwave make and model account for this large range in resistance readings.
Reverse the meter probes and measure resistance while touching the positive probe to the cathode and the negative probe to the anode. Reversing the probes like this should result in a reading of infinity. Unless a bleeder resistor is present. The presence of a bleeder resistor would produce a reading of the value of the resistor.
High Voltage Capacitor
A capacitor is an electrical device which stores electricity. A defective capacitor may be why your microwave is not heating. The capacitor will have to be tested to determine if this is the cause of your problem. A defective capacitor will have to be replaced before your microwave will work again. Make sure you discharge the capacitor before you test it, though.
Magnetron
A defective magnetron is the third possible cause of why your microwave is not heating. Test your microwave's magnetron. Replace it if it is defective.
Testing a magnetron
NOTE: Before you test this component, make sure your microwave is unplugged, and that you have discharged the capacitor.
There are two tests to conduct in order to determine whether or not a magnetron has become defective. If you receive results other than what are detailed below, you will have to replace your microwave's magnetron. Each test is described for you here:
TEST 1: Locate your magnetron and label each of the wires attached to it so that you know which wires are to be replaced where. Set your ohmmeter to the lowest resistance scale. Take a resistance measurement between each of the magnetron's terminals by touching each probe to one terminal each. Reverse the probes and take a second resistance measurement. Each measurement should read less than one ohm.
TEST 2: Set your ohmmeter to its highest resistance scale. Touch one of the meter's probes to a magnetron terminal. Touch the other probe to the metal magnetron housing. Take special caution to not touch the two probes together. This could result in an inaccurate reading. This test should produce a reading of infinity - indicating an open circuit.
Read the tips on the below links on how to replace your microwave oven's diode and how to discharge the capacitor.
http://www.fixya.com/support/r7088355-replace_microwave_ovens_diode
http://www.fixya.com/support/r7088317-discharge_microwave_ovens_capacitor
I hope the above is helpful.
Regards.
Oct 27, 2011 | Sharp R-930AK Convection/Microwave Oven
My viking microwave is not heating
Power Diode
Testing a diode
Magnetron
Testing a magnetron
Regards.
Oct 22, 2011 | Viking VMOS200 Microwave Oven
Microwave won't heat, timer goes off after 1 minute or so
Microwaves are a quick, convenient solution to the hassle of preparing and cooking hot dinners. They are popular appliances with students and large families where food often needs to be prepared fast. Microwaves use radio wave technology harnessed through an antenna, known as a "magnetron," to create friction between food or liquid molecules, causing them to heat up. Some microwaves can cease to function properly, resulting in the appliance running but failing to produce any heat.
  1. Magnetron
    • Magnetron tubes are often the source of heating problems in microwaves. Before having any repair work done, check the warranty on your microwave. Many companies offer 10-year warranties on magnetron tubes so you may be able to get it repaired professionally for free. Otherwise, unplug the microwave then remove the rear casing with a screwdriver. Locate the tube inside the microwave and check it for burn marks. A burnt tube cannot usually be repaired and will require replacement. A tube that doesn't appear burnt should be tested by a qualified technician to see if it can be repaired.
    • A microwave capacitor holds electricity as the appliance is running. A malfunctioning capacitor can lead to the microwave not heating, along with an irritating buzzing sound. Test the capacitor by first disconnecting the power then removing the wires attached to the capacitor. A capacitor with burn marks is usually damaged beyond repair and will require replacement. A capacitor can be tested by connecting each of the probes of an ohmmeter to the capacitor terminal. Each probe should provide a reading of infinity if the capacitor is working properly.
    Power Diode
    • The diode in a microwave oven is a one-way pathway that channels electricity from the capacitor. A malfunctioning diode can sometimes be the cause of a microwave that won't heat. The heating problem is often accompanied by a loud buzzing noise. You can test the diode by first unplugging the microwave oven, disconnecting the diode from the capacitor then measuring the level of electricity inside the diode with an ohmmeter. The ohmmeter can determine whether the electricity in the diode is flowing in one direction as it should. In most cases, the magnetron tube will have to replaced as well if the diode is damaged.
    Safety
    • Disconnecting the plug from your microwave to carry out an inspection does not guarantee safety. Even an unplugged microwave still has electricity running through its components, which can lead to severe electric shocks. Unless you have previous experience in dealing with electrical appliances, it is advisable to hire a technician to test component parts rather than undertake the job yourself. Anyone without a basic knowledge of electrical currents and safety should avoid testing components altogether.
Oct 03, 2011 | Microwave Ovens
My zanussi microwave is not heating any more
Power Diode
A diode is an electronic component that readily passes current in one direction only and blocks the flow of current in the opposing direction. If your microwave's diode has become defective, your microwave will not heat and you will hear a buzzing noise. Test the diode to determine if this is the cause of your problem. Replace it if it is defective.
Testing a diode
A capacitor is an electrical device which stores electricity. A defective capacitor may be why your microwave is not heating but you are hearing a buzzing or humming noise. The capacitor will have to be tested to determine if this is the cause of your problem. A defective capacitor will have to be replaced before your microwave will work again. Make sure you discharge the capacitor before you test it, though.
Magnetron
A defective magnetron is the third possible cause of why your microwave is not heating, but you can hear a buzzing noise. Test your microwave's magnetron. Replace it if it is defective.
Testing a magnetron
Good luck.
Mar 21, 2011 | Zanussi Microwave Ovens
The oven is not heating the food
Power Diode
Testing a diode
Magnetron
Testing a magnetron
Good luck.
Mar 19, 2011 | Panasonic NN-S255 Microwave Oven
Does not heat food
Investigate these three areas if your microwave won't heat food.....
Power Diode
Testing a diode
Magnetron
Testing a magnetron
Good luck.
Mar 11, 2011 | Microwave Ovens
The microwave is turning, but the food is not heating!
Power Diode
Testing a diode
Magnetron
Testing a magnetron
Good luck....
Mar 09, 2011 | Siemens Microwave Ovens
Does not heat,code F-7 shows, Power not getting to magnetron or magnetron burt out. How do you get to this,must the unit be removed[its built in,] Thanks for all help. I did try shuting off the power which...
Power Diode
Testing a diode
Magnetron
Testing a magnetron
Good luck.
Mar 08, 2011 | KitchenAid Microwave Ovens
It stopped heating things up
Investigate these three areas if your microwave won't heat:
Power Diode
Testing a diode
Magnetron
Testing a magnetron
Good luck.
Feb 26, 2011 | Microwave Ovens
My Samsung Mw 87L microwave just suddenly stopped heating? Does anyone know why?
Power Diode
Testing a diode
Magnetron
Testing a magnetron
Jan 14, 2011 | Samsung SMH7174BC Microwave Oven
Maytag MMV1153A Microwave Oven Logo
687 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
