Question about Belkin (F5D7231UK4) Wireless Router
Wireless router just stopped working after my pc updated itself
G wireless router , i can only get on the internet with my cables from modem to router to pc. computer cant find any net works even thou built in wireless is switch on .
    Genius:
  • 1,269 Answers
You need to power cycle the router by unplugging the power for 30 seconds. If it your computer still cannot find the network, you need to change the channel of the router from 6 to channel 11 by accessing the router's setup page.
Posted on Feb 13, 2009
Linksys router not recognize internet
Make sure your router's WAN port is set to dynamic IP. If the light on the front doesn't glow/blink for the WAN port, try a different cable. If a different cable doesn't work it's probably toast. :( This problem appears to be directly linked to the relationship between the WAN port and the modem. Given that the devices can connect to the router, but not internet, it has to be the WAN. Sometimes if the modem goes out it will send too much voltage through to the router and fry the WAN. Had that happen to my parents router. If the above doesn't "fix ya" then try a different router.
Worst case, you might have to put a wireless card in your PC and bridge the modem (wired connection) to the wireless card and broadcast for your wireless devices. At least until you get a new router.
Aug 02, 2013 | Dell Computers & Internet
Craig tablet cmp741e
This can be caused by a number of issues most have to do with the router itself and not the tablet. First, let's make sure the router DHCP Server is not frozen so take the following steps:
Step 1: If the router is separate from the Cable or DSL Modem, power down the router/wireless, next power down the cable/dsl modem. Power up the cable/dsl modem wait 60 seconds then power up the router/wireless wait 2 minutes
Step 2: Try to connect to the wireless
Step 3: If you have a modem or wireless router supplied by Comcast, Verizon, AT&T or any major carrier, contact them asking them to walk you through resetting and rebooting and updating the firmware to the router/wireless.
Step 4: After the reset and update try to connect, if it fails move on
Step 5: Log into the wireless/modem - let's change the wireless encryption. Go to the wireless settings, change the wireless settings to WPA Personal and add any pass-phrase. Try to connect using the new pass-phrase.
Step 6: If you still can not connect, as a last resort switch the wirlesss encryption to WPA for testing. Try to connect, if this works contct the vendor and have the modem replaced.
Jun 08, 2013 | Curtis Klu 7-inch Touch Screen Mobile...
My cable network is not reading my router what could the problem be?
First off you should think if you changed anything recently, like driver updates, updated your computer or Operating System? That could give BIG clues to whats the problem.
What type of OS are you using?(ie,xp,vista,7) is it 32bit(86x) or 64bit(64x)?
When I updated my pc to a new 64bit win 7 model, my old wireless g would not work due to compatibility issues(no driver update).
Always try first:
1. unplug all power to router and modem for 30 sec(differs with model)and pc if connected through gateway.
2. Connect router first(wait for full boot-up) then connect modem(wait for full boot-up)then re-boot router while modem is still green(this allows the router and modem to communicate and prepares to open ports. Sometimes the order needs to be reversed to create a comm link.
3. Next thing would be to make sure its the router and not your internet connection(modem) itself. Plug directly into the modem (bypass the router) and make sure you get internet.
4. Last but not least, check to see if you can access your router(everything connected during this test), open up a browser and type your provider I.P.for your router into the browser bar at the top of the page,( ie. 192.168.1.1) different providers are a little different, if it allows you to access your router then it is communicating, and may be being blocked by firewall preferences or closed ports.
Any questions concerning this, feel free to email me knowitall1979@yahoo.com
Dec 15, 2010 | Linksys Wireless-G WRT54GS Router...
HOW TO USE INTERNET IN MORE THAN ONE PC FROM LINKSYS WIRELESS G B
You have two ways on how you can get other computer online through this router. First, you can wired them (using an Ethernet cable) to one of the Ethernet ports on the back of the router. They are the ones labeled 1, 2, 3, and 4.
Second is through wireless, but those computers that will connect through wireless must also have a wireless adapter to be able to pick up the signal that this router is broadcasting.
Feb 12, 2010 | Linksys Wireless-G WRT54G Router
Use of router in network
Try reset the router & cable modem. There ia a reset (very small) button on the back of the wireless router & the modem. Disconnect the power cords to both. Use a pen & hold in for 10 seconds (router & modem). Re-connect power (router & modem) & restart PC. If your service still has not returned. Chances are it's your internet provider & not you. Double check by connecting your modem directly to your PC.
Luck!
Mike
Apr 04, 2008 | Linksys Wireless-G Broadband Router
Setup asistant will not work with Belkin wireless router & computer
Try the manual method.connect router to pc with ethernet cable
1.logon to 192.168.0.1
2.Connection type ; PPPOE
3.type in your username@ISp and pass
4.Save settings
5.Configure wireless setting(SSID,Wep)
Configure pc with the same SSID and WEP
uplug the ethernet cable and check if your are able t connect wireless
if you still have issue use this guide
Cheers !!!
Feb 23, 2008 | Belkin (F5D7230-4) Router (587009)
HELP PLEASE ASAP
OK well I think it is better to set it up like this... Connect the Modem to the Phone Line, Connect the Modem to the Router with an Ethernet Cable, Use a CABLE connection from the Main PC to the Router. (Ya gonna ditch the USB WiFi) Set that Main PC connection up to connect to the internet from the Main PC, thru Router thru Modem.... Then from Slave, install the USB adapter in this PC, and use this to connect DIRECTLY to the WiFi Router... and thus to the internet. This way will give the best transfer rates, and reliability
Sep 15, 2007 | Actiontec GT704WG Wireless Router...
Belkin (F5D7231UK4) Wireless Router Logo
94 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
