Question about GE JVM1650 1000 Watts Microwave Oven
GE JVM 1650 Microwave Night Light does not work
My GE JVM 1650 Microwave countertop light does not dim when I press the button for the night setting. The display says night. I can hear a relay pick but the brightness of the lights is the same brightness for both normal and night settings. DOes any body have a wiring diagram. I suspect it was miss wired.
Bill
  • bsadek Feb 16, 2009
    Thanks very Much for the Fix!. I am going to get the diode from Radio Shack and install it. You gave me exactly the information I needed!
  • GE Master
  • 9,098 Answers
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
Sometimes this will also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
In your case, it may just be a shorted dimming diode, a black diode usually located between the light relay and the connector.
(Not to be mistaken for the tinier red-bodied diode on the other side of the relay that protects the relay coil).
If it is shorted, you will have bright lights in both the bright and dim settings.
In case you or someone you know has the tools and experience to desolder and solder small components, the replacement rectifier diode is not critical and can be any of these:
1N4001, 1N4002, 1N4003, 1N4004, 1N4005, 1N4006, 1N4007, NTE116, or NTE125 some of which are available form Radio Shack.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Feb 14, 2009
  • William Miller
    William Miller Feb 23, 2009
    Once you fix it, we'd appreciate if you;d consider giving us a "FixYa" rating for our solution.
Night light isn't dim
The problem is in the keypad control board, in order to address this, the assembly will need to be replaced, but since this is a dimming situation I would leave well enough alone when you consider price as the factor.
Apr 16, 2012 | GE JVM1650 1000 Watts Microwave Oven
Microwave Cooktop / Night Light not working
I would check the door switches with a digital meter, set to ohms, disconnect one wire from switch and test for open and short by pressing door switch, if you hit one that tests the same when pressing and releasing, switch should be replaced.
Mar 06, 2012 | GE Microwave Ovens
I have a JVM-1650-ch01 space saver oven hood and the oven light will not turn on. I've replaced the bulbs and the read out says that the light is on but the loght will not turn on by pressing the...
Sorry to read about your problem, I hope this helps you out.
The main control board controls the lite with a relay,, the relay is defective or you may have a broken wire
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 21, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave oven night light
This is a bad connection or a shorted dimming diode on the control circuit board.
We regularly repair these controllers for customers nationwide with our guaranteed $39.95 service in about a week.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
Sep 19, 2008 | Microwave Ovens
Fan and Light out on GE JVM 1650
We actually repair these for customers nationwide for only $39.95 (details here).
If you'd prefer to get a new board, they run $106.94 plus shipping, and you can order one here.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
May 28, 2008 | Microwave Ovens
Ge Spacemaker XL Microwave Oven JVM 1650/1651
the microwave is running even though your not pressing any buttons? it would be a control board problem,. could be main relay contacts welded together.
Feb 19, 2008 | Microwave Ovens
Ge spacemaker microwave jvm/1650
Mmmm it's so easy,
First disconect the power, take the cover off, moslitly there would be 5 screws and two tab's on the top.
inside on the right hand side the magnetron it's a sylver box measuring about 4 in x 4 in x 5 in. It will have a plasic cover moslitly that would have to be remove first then on the magnetron there is 4 crews and one connector.
It should fall downard after.
If you have a power supply after the secondary , that may also be your problem.
Regards
Bob
Jan 22, 2008 | GE JVM1650 1000 Watts Microwave Oven
Light Bulb Replacement On JVM 1860SF001
You can find an exploded view diagram by entering your model number (without the space) here: http://www3.sears.com/ That diagram may help.
Mar 23, 2007 | GE JVM1860 Microwave Oven
GE JVM1650 1000 Watts Microwave Oven Logo
2,023 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
