Question about SanDisk Sansa E280 MP3 Player
Thumbwheel/scrollwheel races uncontrollably can anyone help?
It is with great difficulty to select genre as the scrollwheel races without stopping. Once volume is set it will also race very high or very low. Sansa has no support for out of warrenty MP3 player. I love my e280 and willing to have it serviced, but no one will touch it. Help.
  • dehull402 Feb 21, 2009
    didn't work, thanks for trying...
    Problem Solver:
  • 11 Answers
Does it only race around in volume and genre selection? If so you have a software problem and beyond suggesting that you update to the latest firmware I can't help with that. If it races all the time or all the time when it's been activated start by feeling it. Does it feel steady and fastened or loose? If it feels tight add a drop or 2 of (electronic) contact cleaner and lubricant. Still doesn't work? update the firmware. Still doesn't work? A pro will need to fix it.
If it's feels lose- it probably is. the player's front and back covers have to come off and the thumbwheel has to be lined up and fastened- there are two tabs on the part that you actually touch that fit into recesses on the assembly that it sits on- this will normally not hold it on though. The black center button does that and it gets snapped into recesses on the board. You may need to take the board out of its carrier to attach it right- but only if it doesn't snap in on its own. Reassamble, and if you still have problems add 1 or 2 drops of (electronic) contact cleaner and lubricant. If it still doesn't update the firmware. if it still doesn't work a proffessional will have to fix it.
Posted on Feb 14, 2009
  • jdt630 Mar 01, 2011
    Thanks for giving me an idea of how to fix the problem. A diagram would be helpful to better understand how the parts fit together.
    FYI _ I found a You Tube video showing how to disassemble the Sansa e 200 series..http://www.youtube.com/watch?v=zgz8h8aHU...
LAWNMOWER ENGINE RACES BADLY - HOW DO I FIX IT
Sounds like your governor linkage and or governor control fan arm " most small engines have them to control over speed" is binding or maybe has dirt and grass built up.. Or the return spring is disconnected. Once it starts to race manually move the governor linkage back an let go see it it stops racing.. Then release if it races again..check the spring if connected...you must check the governor fan it is located under the top housing..it uses the engine fan calling air to slow the engine when over speed occurs by pushing the governor linkage back to slower speed.. Check it out...good luck..
Apr 25, 2015 | Garden
I have a 1997 Fiesta auto, runs fine apart from a slight gearbox issue. When starting from cold and selecting Drive the car will sit there for upto 5 seconds before moving away and will stall if the brakes...
I would be looking for a vacumn hose leaking. The cold engine needs a rich mixture and braking uses the vacumn booster causing the mixure to lean. A warm engine races with the extra air.
Feb 27, 2015 | Cars & Trucks
How do I turn the shuffle off?? I go to settings, choose music options, choose shuffle and highlight "on" and nothing I hit makes it change to "off". Help!!
For the Sansa Fuze, the selection Shuffle Mode is correct, just like you told:
In Main Menu > Music > Submenu > Music Options > Shuffle Mode:
1. Select Shuffle.
2. Use thumbwheel to choose Shuffle on or Shuffle off.
(to play songs in random order, set Shuffle to ON).
3. Press Select to change the Shuffle mode.
See page 9 (=page 6) of the manual in pdf format for the Sansa Fuze:
http://mp3support.sandisk.com/sansa/UserManual/FUZE/fuze_userguide_en.pdf
Thumbwheel: 5
Select button: 9
Jan 07, 2010 | SanDisk Sansa Fuse MP3 Player
How i can change the genre of the song to organize my mp3
Open Windows Media Player 11
Right-click a song on your computer that you want to change and select "Advanced Tag Editor"
Change the Genre
Now, you must delete the version of your song off your GoGear (the ones without the genre), and then resync the newly-edited song using Windows Media Player.
It is slow and painful, but you cannot make these edits once the song is already loaded onto the GoGear. Also, you cannot simply sync the newly-edited songs onto the GoGear once you are finished with the edits, without first deleting the song off the GoGear, because the GoGear would otherwise think, "Hey, this song is already on here, I'm going to ignore you now!"
-Tha Mp3 Doctor
Mar 23, 2009 | Philips GOGEAR SA6045 MP3 Player
The pictures on my sansa mp3 8gb
I didn't realize the sansa clip supported pictures - are sure you posted in the right section?
Just giving you a hard time. If you have a Sansa Fuze 8GB:
Looping a Slideshow
1. Press Submenu button while viewing photos.
2. Scroll to Loop and select it.
3. Use the thumbwheel to select Loop on or off.
4. Press the Select button.
5. Press the |<< button to return to previous menu.
Specifying the Slide Duration
1. Press Submenu button while view photos.
2. Scroll to Slide Time and select it.
3. Use the thumbwheel to highlight and select the desired duration (from 2
seconds to 30 seconds).
4. Press the Center button.
5. Press the |<< button to return to the previous menu.
Selecting Slideshow Music
2. Use the thumbwheel to highlight Slideshow Music and select it.
3. Select Current Song (if a song is currently playing) or Music Go List
(plays music from the Go List) then press the Center button.
4. Press the |<< button to return to previous menu.
-Tha Mp3 Doctor
Jan 06, 2009 | SanDisk Sansa Clip MP3 Player
Uncontrolled scrolling within excel app
Try pushing in on the scrolling ball on the mouse.
I just had the same issue and that's what I did and it quit.
Hope this helps!
Sep 11, 2007 | WYSE Winterm S30 Network Terminal
What is the "Clickwheel"? How is it different from the "Thumbwheel"?
The revolutionary "Clickwheel", introduced with the now discontinued iPod mini and also used on all subsequent iPod models (except the iPod shuffle), places pressure sensitive navigation buttons underneath the scroll wheel. The "Thumbwheel", introduced with the original iPod and used on the second and third generation models as well, is designed for one handed selection of song tracks and other information, but navigational buttons (play/pause, previous, next, menu, and select) are each separate buttons placed either around or above the "thumbwheel", depending on model.
Sep 29, 2005 | Apple iPod nano
SanDisk Sansa E280 MP3 Player Logo
141 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
