Question about Brother MFC 420CN All-In-One InkJet Printer
How do I get rid of "fax in memory"?
Message says "fax in memory:01". Does this mean that last fax I sent did not go?
    President:
  • Brother Master
  • 990 Answers
Hello sir; it's means you have message in memory didn't print out, you can go to manue to clear memory.
Posted on Feb 13, 2009
Memory info retrieving from lexmark x5630 fax machine
Usually, faxes are temporarily sent to the printer's memory when one of the cartridges' ink level is not substantial for printing at the instance of receiving the fax. When this happens, try to replace the cartridge(s), *without navigating away from the message "fax sent to memory", by opening the printer cover and replacing the low-ink or empty cartridge(s). After the new cartridge is installed, close the printer cover and press the OK button. Your printer should then print the fax stored in the memory.
*Make sure not to navigate away from the "fax sent to memory" message, otherwise, data will be lost.
Dec 30, 2011 | Lexmark X5650 ALL-IN-ONE PRINTER
How to print faxes from the lexmark x5630 which is stored in the memory
Dec 30, 2011 | Lexmark X5650 All-in-One InkJet Printer
I have a fax in memory how can I retrieve it
Usually, faxes are temporarily sent to the printer's memory when one of the cartridges' ink level is not substantial for printing. You are advised to replace the cartridge/s, *without navigating away from the message "fax sent to memory", by opening the printer cover and replacing the low-ink cartridge/s. After the new cartridge/s is installed, close the printer cover and press OK button to let printer print the fax stored in the memory.
* Make sure not to navigate away from the "fax sent to memory" message. You will lose the fax-in-memory data once you turn off the printer or navigate away from the message.
Oct 31, 2011 | Lexmark X6570 InkJet Printer
How do I print faxes in the memory of Lexmark X6650 all-in-one-printer ? Is there a "tools" item in the setup menu ?
Sep 15, 2011 | Lexmark C533DN InkJet Printer
I am unable to retrieve fax from memory, on the Fax Setup menu no reference to faxes in memory. I have a Lexmark 6650. When the fax wa sent it said "printing" but nothing came out
Aug 16, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
Message saying "received in memory", what does it mean and how do I get rid of it?
It means there are pending documents in the memory of the printer awaiting to be printed. This documents could be a received fax documents or a documents failed to send.
Just press the menu button to enter fax setting: under it the appears "receive mode set"...... use the right arrow button to go to "memory referrence" then click OK button.
Use again the arrow buttons to delete documents in memory.
Oct 15, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
I cant receive fax. it has some in the memory.
if there are a message like empty cartriage or low cartridge that means
the printer want new cartridge for print fax, when it print another document and also print reports without trouble.
Jun 25, 2009 | Lexmark X5470 All-In-One InkJet Printer
Fax Spam
I couldn't find anything specific to delete the memory without actually printing it,
here's a copy of the manual if you need it:
http://pdf.textfiles.com/manuals/FAXMACHINES/Panasonic%20KX-FHD331%20Plain%20Paper%20Fax.pdf
May 26, 2009 | Panasonic KX-FHD331 Plain Paper Thermal...
Erased files
the problem is the fax that are stored in memory you will lose anyway.
you will need to do the following to get rid of your error:
DATA REGISTRATION button,
and # button, on the operation panel
go down to number 8
then scroll round to ALL
and then restart the machine and the fault should go.
Hope this helps
Oct 23, 2008 | Canon FAX-L800 Plain Paper Laser
Brother MFC 420CN All-In-One InkJet Printer Logo
460 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
