Question about Numark CDN95 2-Disc CD Player
Left jog wheel on CDN *88 remote controller not working
The left jog wheel on the controller (remote) is not working which means that I cannot use the special effects/search/change tempo with the wheel for that channel. Does anyone have a technical manual as I'm gon try and prise the unit open so that I can try and fix the wheel myself? the unit is over 4 years old and the retailer i bought it from will not fix it!
  • 4 Answers
Hi tmal004,
I don't have a technical manual for this unit, but I have worked on these before. They are fairly easy to dismantle, take care to apply even pressure when removing the jog wheel, use something like a butter knife (2 off) to slide under opposing sides of the wheel and gently prise up. Spare parts for this unit are available directly from Numark, however you can source them from elsewhere. you'll probably need to replace the transducer.
Good Luck.
Posted on Feb 15, 2009
How do I get the nikon ML-L3 to work for D90 camera
Set the camera to one of the remote modes. The quick-response remote mode fires the camera when you push the button on the remote, just as if you were pushing the shutter release button on the camera. The delayed response remote mode gives you two seconds to hide the remote behind your back before firing the camera.
See "Release Mode" beginning on page 64 of the manual: http://cdn-10.nikon-cdn.com/pdf/manuals/kie88335f7869dfuejdl=-cww2/D90_en.pdf
Jan 29, 2013 | Nikon ML-L3 Remote Control
I have a Gemini CDM 3600 combo unit. The Jog wheel doesn't work on the left cd. Any ideas on how to remedy? the unit only has about 5 hours of playtime on it but is over a year old.
You would have to get it to a service center. It could be the control or some supporting circuitry. If there is no service center near you. You can send it in to pro Line Music 215-736-8055
Jul 15, 2011 | Gemini Sound Products Gemini CDM 3600
Where is the self timer on the c-3000 digital camera
try to check this path: Press the Menu button, then press the top/bottom arrows on the Jog dial to select DRIVE. Press the right arrow and press the top/bottom arrows to select. Press the left arrow on the Jog dial to confirm the setting. If you take a
picture without pressing the OK button, the setting will be valid until the Menu is canceled. To take a picture using the selftimer, when the shutter is released, the Selftimer/Remote control signal lights for
approx. 10 seconds then blinks for approx. 2 seconds before the picture is taken. To stop the activated selftimer, press the Menu button.
Sep 06, 2010 | Olympus C-3000 Zoom Digital Camera
Baby trend double jogger stroller pulls to the left when front wheel is in locked position AND front wheel wobbles (cannot push through it)when on swivel.
Hey! I just fixed my shaking wheel! There is a red lever above the swivel wheel. I pushed it up. And guess what... I can jog with my stroller!
Jul 03, 2010 | Baby Trend Expedition Double Jogger
Jog wheel is blocked and hard to spin
Hey, the vci 100 out of the box has the problem of sticky jog wheels, Im not sure how long you have had the interface, but mine took a bit of use to start spinning freely. These jog wheels are definately the weekest link and degrade rapidly, the case is easy to remove there are about 8 screws including one one front and rear edge, you will notice the grafite lubricant used on the jog wheel mechanisim, a fine grade grafite would not go astray when maintaining this moving part
May 06, 2009 | Vestax Vci 100 Midi Controller
1991 Oldsmobile 88 Royale loud clunk when turning??
Ball joint, tie rod end or upper strut bearing. CV joints? Pulling to the left may be an alignment problem with front or rear tires. Get a four wheel alignment.
Oct 23, 2008 | 1991 Oldsmobile 88
Hi a lamp was left on and its damaged the jog wheel on my cdj. is it possible to replace the jog wheel ? if so how much does this usually cost? Thanks
What sort of unit is it? Make and model. Most just pop off but not all. Some have a small c pin holding them on and if you try to force them you will brake the jog wheel
Jul 25, 2008 | Audio Players & Recorders
I've owned my new Pioneer CDJ1000mk3's for 6 months and they have had hardly any use. The jog wheel on the right 1 in my road case only spins with no mixing ability at all. It doesnt curve the sound...
Hey Mark, on the Goldy... and me in Brisbane. Was an agent for Pioneer for 12 years, but gave it away just before the cd deck revolution;) Will find out for you man and get right back at ya.
regards
Graeme
Mar 15, 2008 | Audio Players & Recorders
Stroller pulls to the left
It's a wheel alignment issue - I had the same issue & my husband fixed it. Try removing the front wheel & reattaching it. If that doesn't solve the problem, keep adjusting the front wheel slightly until the stroller no longer veers.
Jan 10, 2008 | Zooper Cool Zone Buddy Stroller
Wheel alignment
Just take it to your local bike shop. They should be able to fix it. The wheels/tires are basically small bicycle wheels/tires.
Mar 29, 2007 | Baby Trend Expedition Double Jogger
Numark CDN95 2-Disc CD Player Logo
137 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
