Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
The Hoover Windtunnel vacum will not pull suction
The vacuum cleaner does not pull suction at all.
  • Anonymous Feb 16, 2009
    My windtunnel blows dirt out onto the carpet. What is that all about. Should I throw it out/
  • wuwuw Feb 17, 2009
    just opened the box - vacuum is brand new. Lots of good noise, like it's working, but THERE IS NO SUCTION! HELP
  • 134 Answers
Either the machine or hose is blocked OR the filters are blocked.
Also possible that the belt is broken.
Please leave feedback
Thanks
Posted on Feb 13, 2009
Vacuum not clogged but has low suction
Check all the pipes, there could be something stuck in them which hasn't come out.
Also check the base of the vacuum if there is something stuck in the base.
Lastly check if there are any leaks in the pipes.
Also check the suction without using the handle, by pulling the pipe in your hand and see if it has more suction.
Apr 28, 2014 | Hoover U6630-900 WindTunnel Bagless...
There is no suction when using hose. (Edging)
you have blockage in the hose or the vacum is not in its upright position to enable the suction to the hose..
Best regards
CK
Mar 06, 2011 | Hoover U6630-900 WindTunnel Bagless...
Hoover upright bagless vacum.motor runs, brush turns, no suction through hole behind brush roller. however there is suction going out of dust cannister filter flap to motor. what could possible problems...
Sorry to read about your problem, I hope this helps you out.
you have a clog between the brush and bag
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 23, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
I have a windtunnel vacum cleaner. When I
It might be a slipping rubber belt, is the brush roller moving when you look underneath? If it's a self propelled machine there might be another slipping belt. Friction from fast rubbing rubber can smell like it is burning.
Jan 16, 2010 | Hoover Company Wind Tunnel U53019 Upright...
Brush spin,good suction at hose, no suction at
Air passage from back of brush head, through the joint, and up to bag, may be blocked.
Jul 11, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
No suction on wind tunnel vaccum cleaner
Your brush might be clogged with hair. while uplugged, flip over the vacum and check to see if there is any hair or string wrapped around the brush...
Jun 03, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
Hoover Bagless WindTunnel vacuum cleaner.
very easy. you have clog. take the brush off look where the hole is thats where the clog is. it might be in there you might have to take the housing off of the motor
May 08, 2009 | Hoover U5753-900 WindTunnel Bagless...
Hoover Windtunnel spits dirt back out the back
Your problem sounds to be an obstruction in the foot (lower body) of the windrummel. Most all windtunnel's have a second cavity for suction to go over the top of the roller. When you remove the bottom plate, next remobe the belt and roller, under the roller will be a removable cavity, take it out. remove the dirt and clean out any debris. also check the suction path connecting hose. if your belt has not been changed in the last 12 months, I would recommend changing that as well.
Jan 17, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Plugged hose on Hoover Windtunnel
you will have to remove the bottom cowling under the vaccum cleaner there are 4 phillips head screws one at each corner when you turn over the vaccum cleaner, take this off and remember how it goes back on. in the area where the hos is there will probably be a clog at that point. remove this and pull hose off and make sure it is not clogged farther up the hose, reinstall and check
Dec 31, 2008 | Hoover Windtunnel Supreme U5280-900...
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
347 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
