Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front load washer flashes F35 shortly after start
What does F35 error code mean on Whirpool Duet front load steam washer
  • 5 more comments
  • Anonymous May 20, 2009
    washer flashes f35 and sub i have what sould i do
  • mkd8951 May 11, 2010
    How do I identify the pressure switch?
  • Anonymous Mar 17, 2014
    Whirlpool duet DRIER flashing error code F01
    whirlpool duet F35
  • Anonymous Mar 24, 2014
    What does the F20 error code mean and how do I fix it?
    the motor runs but the machine does not spin or clean
  • Anonymous Mar 25, 2014
    this is a whirlpool duet front loader garment and wash light are flashing
    President:
  • 1,902 Answers
Sud= The unit has sensed there is too many suds in the unit it will flush and pump out for 5 min and restart on its own..This is caused by too much soap use..
From the book :
SUD Code=
If too much detergent was used:
—Run the unit through a Rinse/Spin cycle.
—Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
cycle.
Posted on Feb 13, 2009
    Problem Solver:
  • 7 Answers
I tried that fix and it did not work. The next step was to replace the analog pressure sensor, $168 with next day delivery. That fixed the problem, but the price is a ripoff and less than 4 year old washer should not need any repairs.
The part is a small unit with a small electronic circuit with a pressure switch.
I bet their cost is less than $10
1.Remove three screws on the back of the top.
2. Slide the top forward about half an inch and lift off.
3. the switch is mounted on the upper right.
4. Remove it from the side and slide the black cover up to make it easier to unplug the connector,
5. Remove hose.
6. Plug in new sensor and connect hose.
7. slide cover down and install unit.
Posted on Jul 07, 2012
  • eng42b
    eng42b Jul 07, 2012
    5. Remove hose.
I have a Whirlpool Duet Washer, washer starts and then stops code F35
Hello & Welcome to FixYa
F35 error means that there is some sort of issue with the steamer electronic board and analog pressure sensor has gone bad. Check that the hose is firmly attached with the washer and is not blocked. You can also check the water level pressure switch operation. Please get back to me if you have any other questions.
Kevin
Nov 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet steam WFW9600TW00 code F35
Kevin
Oct 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I get an f35 error on my whirpool washer
It could just be lint or flashing inside the tubing which connects to the pressure switch. Remove the tube and blow it out and make sure ain't no holes in it. Remove the top to access the analog pressure switch item 20.
May 11, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool duet washer - error code f35. shuts off
Just tilt the washer back and prop it up with some wood blocks. Three screws are right on the front at the very bottom. Use a 9/32 socket to remove them. The front cover slides right off. The drain trapclean out is right in the middle. Turn the large white knob counter-clockwise to remove it and clean.
Thank you !!
Jul 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet -Sud displays and washer stops
I;ve had the same problem (SUD on first fill) and found this most helpful for my WFW9600TW01 Duet washer
http://www.tellingmachine.com/post/Fixing-Sud-and-F35-errors-on-my-Whirlpool-WFW9600TW01-Washer.aspx
I duplicated his actions and it cleared up my SUD/F35 error. I think running the diagnostic test multiple times flushes the sensors/sensing lines to eliminate the problem.
Jan 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet Steam washer (WFW9600TW) flashes F35 shortly after the cycle starts and then turns itself off.
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F35 flashing
if it is less than one year old call for service it should be covered. if not take the kick panel off and locate the tech sheet it is either in the kick panel or in the cabinet to the right. it will give you a list of error codes find out what it means and let me know thanks
Jun 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
ERROR CODE F71
The following list of codes indicates an electronics communication problem with the washer:
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Dec 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
5,087 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
