Question about Sony FD Trinitron WEGA KV-36FS120 36" TV
Black box on screen
A black box shows up on the screen when you turn it on. It will sometimes go away when you turn it back off, wait a few seconds, and then turn it back on.
    President:
  • 2,559 Answers
Use the remote and turn off the closed captioning.Button is Usually maked cc
Please rate this a fixya
Posted on Feb 13, 2009
Projection TV. DVD works. Cable often seems, "untuned". Static & un-fine-tuned sound of channel with black screen. Then, later, it will come on just fine. Sometimes, will go back to untuned status.
I would suspect your cable box first. I would unplug the power cable from your cable box and wait 60 seconds. Plug it back in and try to watch cable tv. I would also make sure the coaxial cable going from the wall to your cable box is connected properly. I would also make sure the cable going from the cable box to the tv is connected properly. Test your tv and see if it works correctly when you watch cable. If this fixes the issue you are good to go.
  • If this makes no difference use a set of new cables if you have them.
  • If this does not work then call your cable company. They may have to replace your cable box.
May 25, 2015 | Televison & Video
Acer aspire one D255 went away from notbook for half an hour or so, when i got back the screen was black. It won't come back on. Help
Hi, try disconnecting the power completely and take the battery out, wait a minute and put the battery back, connect the power and turn the machine on, if still no luck try holding the power switch for over 3 seconds, wait few seconds then try turning on... if still no luck then there might be aproblem with the machine that require taking it to service center... best of luck
Jan 30, 2011 | Acer Aspire One D255-2670
Computer was on, screensaver is from my photo file - it was running. I moved the mouse to get back to the screen I had previously been on, walked away for a minute, came back, the screen was black. ...
Windows 8 especially and sometime Windows 10 may have a black screen during an update for over 15 minutes with no indication that anything is happening.
Try complete power down by holding the power key for 10 full seconds. Consider unplugging power for a few seconds after that as well.
Re-connect power, press power button to turn on the computer then if the screen goes blank, give it a half hour before looking for another solution... it may come back to you.
Nov 06, 2017 | Sharp LL T19D1-B (Black) 19" LCD Monitor
TV is about 1 year old. Started yesterday having a black rectangle in the middle of the screen. Can press any button and it goes away but come's back in just a few seconds. Tv is a Element ELCHS321
most times a black rectangle pops up when closed captioning is on. sometimes there will be gibberish in it sometimes not. See if you have button on remote labeled "CC" . Also if you have a cable or sat box make sure closed captioning is switched off there too.
Jan 21, 2010 | Televison & Video
Unwanted rectangular black area appears on screen blocking 40% of picture
This could be the result of a partly shorted vertical winding on the deflection yoak.Since the line is on an angle and not straight across.
Nov 07, 2008 | Durabrand DWT1304 13" TV
Screen blackout on Ilo TV
I never heard of this model either but there are some universal things to try. First, is there a reset button on the set? Usually it's a recessed hole that can be pushed with a paper clip or strong tooth pick. If this can be done, wait until any laights on the set stop flashing before continuing.
If yo uhave the maual there should be a reset instruction on a page outlining the use of the front control buttons. Good luck. Let me know how you do.
Sep 22, 2008 | Televison & Video
Black Squares on the Screen
this kind of problem is normally do of bad cable box or sat
Apr 05, 2008 | Vizio L32 32 in. LCD HDTV
Blank black box in lower half of screen
turn off text mode in the closed caption menu
Jan 30, 2008 | JVC AV-20120 TV
Sony FD Trinitron WEGA KV-36FS120 36" TV Logo
52 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
