Question about GE JSP26 Electric Kitchen Range
GE Stove clock shows FFF and oven will not work
The power went out and the clock and oven will not work. I have unplugged, reset breaker and nothing has helped.
  • 15,935 Answers
GE Error Code: FFF
Condition: Door motor safety circuit
Fix: Repair Electronic Range Control (ERC)
Usually, failure happens after power surge.
Thanks for using FixYa - a FixYa rating is appreciated!!
Posted on Feb 13, 2009
GE true temp flat top stove/oven isn't working at all, there is power to it, if you turn the burner dial on the clock/electronics turn on but nothing works. turn dial off electronics/clock turn off
sounds like you are missing one leg of the 240V power supply... first thing is to reset the circuit breaker. Then, meter how many volts you are getting at the terminal block where the power cord bolts on... Help Me Find My Model Number RepairClinic com, GE Terminal Block WB02X10606
Jul 26, 2016 | GE Kitchen Ranges
GE Stove tope range not working
If the phenomenon is intermittent, and you get it going and coming as you restart the oven, then it is likely a bad wiring or a bad connection.
Ensure first that the circuit breaker is ok and well in place, then proceed testing wirings.
Check connectors to buners, hobs, and controls panel.
If all wirings and connections are OK, the what reamins is a faulty control panel or a fault on some of the knob controls.
Sep 04, 2008 | Kitchen Ranges
-just got stove pluged it in an it will not come on but the light on oven comes on what is wrong ...it will not get hot ontop or bottom
This sounds like you are only getting one leg of your power to the stove. The lights will work but that is all. Try reseting the breakers by forcefully shutting both sides of the circuit breaker tied together with a bar or clip. Then forcefully reset them both completly. If your stove still does not work you may want to consult a licensed technician or electrician.
Dec 02, 2012 | Kitchen Ranges
Reset clock and oven light came on flashing
THERE IS A PROBLE WITH THE ERC (CLOCK) NOT TO SURE IF I WOULD USE IT EITHER. THE PART IS EASY TO CHANGE JUST TURN POWER OFF AT THE BREAKER FIRST. YOU CAN FIND THIS PART HERE.
http://www.searspartsdirect.com/partsdirec
Apr 22, 2010 | GE Profile JTP18 Electric Single Oven
GE glass top and oven are not heating?
I have an electric oven that is turning on but not heating up. The oven, broiler, & stove top are not heating up. Any easy solutions to this?
Jul 18, 2009 | GE Profile JKP18 Electric Single Oven
My GE Oven heating element and timer clock went
Try unplugging the oven and let sit for 10 min. This will reset the curcuit board and reboot the electronics. You may have to pull out the stove o get to the cord.
Apr 30, 2009 | GE Profile JTP18 Electric Single Oven
Cannot reset clock on my electric stove after a power failure!
Unplug the stove for 10 minutes, then plug it back in.
This should resolve your problem...
Nov 20, 2008 | General Electric Stove/Oven/Range Chrome...
GE Profile JGB97 Self Cleaning Oven Controls won't work
You have a problem that may be solved with my solution to the Dreaded F7 Problem. Even though you don't have a F7 error on the display the symptoms are all the same. You can find my fix at the following links.
http://www.fixya.com/howto/h155060-dreaded_f7_error
I have shared this with more than 1550 folks and most report success. This problem often develops after a self clean cycle.
I hope it works for you too. Please let me know at the following:
hutchipop@yahoo.com
Good Luck,
Charlie Popeck,P.E.
Consulting Engineer
Feb 06, 2008 | Ovens
GE JSP26 Electric Kitchen Range Logo
953 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
