Question about Toshiba 62HM95 62" HDTV
Problem when you turn it on,
When you turn it on there's this sound and no video, just the audio, it takes a while for the video to come up and when the picture comes up the color comes back and forth and the noise continues and continues a buzzing sound.
P.S. The lamp was change but the problem persist..
    Novelist:
  • 184 Answers
You have a bad color wheel motor. Its bearings are humming and the shifts in color are due to the speed of the motor changing. Obtaining a color wheel for these Toshiba DLPs is difficult. The manufacturer does not sell any of the most often needed components, color wheels, ballast boards separately form the light engine assembly resulting in a very expensive repair bill.
Call Toshiba. Maybe they'll have mercy on you and help with the cost of repairs.
Good Luck!
michtech
Posted on Feb 13, 2009
Sony kv 27V15: No picture but sound
Hi! the trouble indicates that your television's picture is the culprit, have your unit check by a qualified technician for verification.
Sep 12, 2009 | Sony KV-27V15 27" TV
No sound when the tv is on and the mute is turned off
I still am unclear as to your hook up but lets try this, if you have your DVD/VCR plugged into the TV audio and video and a audio cord from the tv monitor out to an input on the reciever, this way you should hear the sound at the tv and reciever.
However if you have your DVD/VCR plugged into the reciever first audio and video connections made at the reciever you should just have a video cord fromthe monitor out of the reciever to the tv and your audio will come from the reciever
Feb 25, 2009 | Panasonic PT-52DL10 52" Rear Projection...
Picture will not come on. only sound
Hi jsevcik897,
I am happy to help, we need to check the backlight inverter.
  1. Turn tv on and get to a point that you have audio.
  2. Take a flashlight and shine it on the screen.
  3. Look very closely at the screen for a very dark video image.
If you see an image you have a bad inverter, you should be able to replace it yourself. I can walk you through in chat. Let me know your findings. Lone99star
Jan 20, 2009 | Philips 50PF9956 50 in. HD-Ready Plasma...
Help
check the audio output settings it might be set on digital out
Oct 20, 2008 | Sony Playstation 3 (PS3) Console
Philips60p8341
If you have any of the following problems you may want to check the site www.tvrepairkits.com for a repair kit. Most of the issue below are fairly common with the older Magnavox projection sets.
Symptom: Screen shrinks and expands - may or may not correct itself after the TV warms up. After a few days, weeks, or months of having the shrinking/expanding problem you may loose all audio/video but the power light will remain lit!
(Note: The below symptoms typicaly occurs after having the expanding/shrinking screen problem above)
Symptom: No Audio or Video but power light is on
Symptom: Audio works but no Video. Power light still work
Symptom: No Video. Audio is intermittent. Power light still works
Oct 11, 2008 | Philips 60P8341 60" Rear Projection...
No sound on olympus sp-55ouz video playback
To turn on audio, go to the video setting. Hit the menu button. Hit ok to select the camera menu. Go down to the picture of the microphone and hit ok again. Select on and then hit ok again. Your sound should be set. Hit the menu button twice to get you back to taking videos.
Jul 13, 2008 | Cameras
My Sony comes on then both sound and picture goes black.
After being on a little while, the screen goes black (no audio as well) for 20 to 30 seconds. Green light stays on. Then, picture comes back on and takes a couple of seconds to get up to full brightness. About 5 seconds or so after the video comes back, the audio returns.
Until this morning, has only happened a couple of times a day, now happening more often. About 3 times in last 20 minutes.
KDF-E55A20 is about 3 years old.
May 03, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony KV-35S66 Audio ok but no Video
Is your picture somewhat weak ? This could be a problem with the picture tube . One thing you can try is to turn the screen control up just alittle at a time to see if the picture comes in . Once it does turn off and back on to see it it comes back on again . It might take 10 to 20 seconds but if it does your picture tube is weak . The control is on the flyback transformer it is the bottom control . Or it may be on the crt board on the picture tube . One thing to check once the picture comes is the video input . If you go to this mode and see faint white lines might want to try to turn the control down a little more to see if you can get them out and the picture stays on , if not thats how going to have to watch it . These picture tubes are expensive $500.00 to 700.00 depending on which one you have . One possible other thing if you tell me the picture was a great picture almost like brand new check the horizontal section for a loose connection as this will cause this problem . Don't get shocked and be carefull , Good luck
Mar 14, 2008 | Sony KV-35S26 35" TV
Avp7000
Sound is OK? Suspect a problem with one of the following; Heads, head amplifier, drum control servo IC, or video processing, in that order, assuming that you have audio....accordianman
Nov 03, 2007 | Audiovox AVP-7000 Video Cassette Player -...
Sanyo DS32920 Blue Screen
My panasonic Tv pic suddenly turned into a blue color I can't see the pic any more just can hear the audio.....any solutions????
Mar 19, 2006 | Sanyo DS32920 32" TV
Toshiba 62HM95 62" HDTV Logo
159 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
