Question about Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Kingston 2gb drive s not detcted by the system
When usb drive is inserted, the message "unknown device" in the device manager tab. windows shows that no driver is installed in the system.
Yaar meri pan drive open nahi ho rahi hai na hi format ho rahi hai
Posted on Feb 14, 2009
System detects kingston 2GB drive but when I click the drive Icon a message box appears showing ( please insert disk into drive H:.) . How can I resolve this problem?
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
if you need more help with this post a reply
hope this helps you
Jul 31, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
How do i remove write protection from my kingston datatraveler G2 2GB? thank you for your assistance
click start control panel administrive tools computer management disk management right click on your drive select properties then security select take full control in windows 7
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
# Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
also
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
hope this helps
don
Feb 24, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I want to format my kingstone Usb drive. but when i plug in the computer it shows me message that your usb drive is not recognize. I am using Microsoft Windows Xp SP3. i had checked in device manager but...
the only logical answer would be that you have updates available from microsoft that are disabled. youll need to allow these to download and instal before this will work.
Dec 20, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
USB device does not recognised and pen drive doesn't show its symbol. and my windows drivers are all of up dated. Help me please
There are a few possibilities for the problem you're having. Some you can resolve yourself, some you will need further assistance from a professional.
It sounds like you've done some basic diagnostics already so don't worry if these steps start off with things you've already done.
First, with the kingston drive connected, open my computer and see if the drive shows up at all, if it does click on it and see what messages come up. If you receive a message regarding hardware failure the device is likely damaged, if you receive a message telling you the device is not formatted then you have do it yourself methods available to recover any files before you format the drive.
Second, open device manager and select the Kingston, if you're not sure how right-click on your Computer or My Computer icon and left-click Manage. Once the management console opens, left-click device manager on the left panel, then expand **** drives section and identify the Kingston, if it's not there the hardware has failed beyond do it yourself techniques. If it is double click the Kingston to open it's properties sheet. Select the Volumes tab and then click the populate button. If it shows up with approx 2GB then do it yourself methods will likely work, let me know and I'll point you to a specific article to walk you through the process, if it shows up with an absurd size or fails to detect a volume let me know and I will get you a referral into a nearby data recovery facility(please supply Country, State and City).
Either way we'll get your files if it's worthwhile. If the volume does show up in Device manager and your have no need to recover files from the device, you should be able to then select disk manager from the left panel, find the Kingston and format it to get it working again.
Hope this helps Fixya,
Chris
Dec 19, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My Kingson 2GB pendrive showing unknown device message after connecting. i cant format it or read it.
Does it work in another machine? If not its a write off, if it does you have a corrupt Windows.
Oct 19, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Unknown device
you must install windows driver package to run it
Apr 10, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I don't have driver of pen drive in windows 98
Let's check your Windows 98 Version first :)
  • Right click on My Computer and select Properties
  • On the System Properties page that opens up click on the General tab, if it is not already on that page.
  • Under the System heading, look for the version number (see right)
    • Version 4.10.1998 is the original version of Windows 98 (98FE)
    • Version 4.10.2222 is Windows 98 Second Edition (98SE)
  • Click the link below for the download and installation instructions for your version of Windows 98
Fo Windows 98 FE:
  1. Download and install the Windows 98 Service Pack (35.5Mb)
  2. Download to your desktop the driver file from the Download section below
  3. Remove ALL drivers for USB flash drives in Device Manager (Optional)
  4. Remove ALL drivers for any USB 2.0 controllers (many have an uninstall option) (Optional)
  5. Remove ALL unknown devices from Device Manager
  6. Run the exe file you downloaded, and follow the instructions, rebooting after installation
  7. When the computer boots up again, it may detect new USB 2.0 controllers, in which case you may need to reboot again
The drivers can be downloaded from the following link:
Windows 98 FE Generic USB Mass Storage Device Drivers v3.20
For Windows 98SE:
  1. Download the exe file to the desktop
  2. Remove ALL drivers for USB flash drives in Device Manager
  3. Remove ALL drivers for any USB 2.0 controllers (many have an uninstall option)
  4. Remove ALL unknown devices from Device Manager
  5. Run the exe file you downloaded, and follow the instructions, rebooting after installation
  6. When the computer boots up again, it may detect new USB 2.0 controllers, in which case you may need to reboot again
Windows 98 SE Generic USB Mass Storage Device Drivers v3.3
For detail explanation, please visit http://www.technical-assistance.co.uk.
It's help for me :)
Thanks
AkulahPathub
Mar 13, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Kingston Flash drive is NOT accessible (8GB)
my flash drive is not supporting my computer kingston
Mar 04, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
KINGSTONE 2GB pENDRIVE dID NOT WORKING
show my drive but not open it and display insert disk to drive.
Feb 02, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
When pendrive is connected shows device has malfunctioned
when i connedted my pen drive i show has malfunctioned
Dec 14, 2008 | Transcend (589307) Media
Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
320 people viewed this question
Top Kingston Computers & Internet Experts
Cleverer2
Alun Cox
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
