Question about Kenmore Oasis HE 27082 Top Load Washer
Kenmore oasis He
The washer turns on and lets out a flash of water, and then spins with no water comming out after the first time.keeps spinning.nothing else
  • 15,935 Answers
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
Regardless of how big or small the load is right around the time for the washer to rinse and spin it just hums and then the Ld light starts to flash, however if I restart and do a rinse mode it completes...
Verify that BOTH hot and cold taps are turned on. If one is off, the machine will buzz (inlet water valve, with no water present) and wait forever for water to fill.
May 04, 2011 | Kenmore Oasis HE 27082 Top Load Washer
Why is my kenmore elite (top loader) oasis washer HE is displaying a code of HC
The water inlet hoses are probably removed and reconnected in reverse, and then trigger the HC error code to flash indicating the hot and cold water inlet hoses are reversed. Reconnect the water inlet hoses properly and start a cycle then let us know what happens next.
Apr 18, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Our washers keep flashing LF after the wash cyle and stops workin, not spining very fast either.
Hello there :
the Dreaded LF code means
LF Long fill If the water fill time exceeds ten minutes, the water valves are turned off and "LF" is flashed.
Press STOP/CANCEL to clear the display.
check the water controle inlet valves that are attached to the machine for proper operation and replace if found bad
Jan 07, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Keep getting an LF error
Hi There
I have found something for to read and this should help you. Try this and let me know how it goes.
LF Long Fill If the water fill time exceeds ten minutes, the water valves are turned off and LF is flashed.
Press STOP/CANCEL to clear the display. Thank you for writing to fix ya. Merry X-Mass and a Happy New Year.
Best Regards Richard
Dec 15, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore oasis won't completely drain and flashes "LD"
Does the pump keep running and then shut off first if so you can try this .It is not the proper way but sometimes you have to wait for the machine to go into the spin drain cycle and tilt it gently a few times like an old pinball machine. I sometimes have to do that. but I want you to know it is not the best for the machine you could break something else while doing this
Dec 14, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Washer won't start spin cycle, error f50
The F50 error on the Whirlpool Cabrio / Kenmore Oasis points to the basket and possibly some obstruction keeping it from turning freely.
Please see the following PDF Service Manual for the Whirlpool.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
Oct 31, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Oasis top load always out of balance and bangs
First just to let you know, the oasis is very sensitive to the load level and water ratio if its too heavy the load has to be perfectly balanced inside the tub. Next check to see if any of the straps are broke. The next thing is that the newtator has tighted up all on its own so when it spins the newtator grabs the tub while it spins at high speed. I have never had to fix this but i know it is a common problem. I hope i helped a little. Good luck!
Jan 14, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Elite Oasis Wash Machine Error Code F54
The F54 fault code indicates that the control board senses high motor current.
This can be caused by excessive friction in the spin basket.
With the washer off, open the lid and see if the basket spins freely.
If not, you may need to remove the basket and check for an item stuck between the spin basket and the outer washer tub.
The second and third images show procedures for removing the basket on the Oasis washer depending on whether you have an impeller or agitator in your model.
If the basket spins okay, then you can follow the technical troubleshooting described in the first image.
This may help you determine the cause of your washer problem.
Removing Tub, Basket, lint filter: http://media.fotki.com/1_p,srfssgbktsdgrrqxgtqsskgwtqkq,vi/rstsfdwbbxwwdskwfgkxrrdqddwqb/1/1303472/5961857/image5139789143943268173img-or.jpg
Removing basket & Hub: http://media.fotki.com/1_p,sqgwstkfwtfwsqwxgtqsskgwtqkq,vi/kbkbfbkgwxbfdtwrdxkrkggrdrw/1/1303472/5961857/image27197img-or.gif
Wiring Diagram: http://media.fotki.com/1_p,srfssgbdfbbkfwsxgtqsskgwtqkq,vi/rstkrrqkkxwrtdkbbrbxbqdswfffs/1/1303472/5961857/image3973684248966800668img-or.jpg
http://media.fotki.com/1_p,wktkgtrtsbsgwfrxgtqsskgwtqkq,vi/wrskkfsfrxwwqgrkddg/1/1303472/5961857/image35809img-or.jpg
Dec 01, 2008 | Kenmore Oasis 27042 Top Load Washer
3 quick beeps during cycle if you can get it to stay in a cycle
MY KENMORE OASIS HE IS DRIVING ME CRAZY! THE CYCLE SIGNAL CONTINUES TO BEEP AT LEAST 25 TIMES, STOPS FOR MAYBE 20 SECONDS, THEN BEEPS AGAIN ABOUT 25 TIMES. THE WASHER WORKS GREAT, BUT IT WILL NOT STOP BEEPING! HELP!!!!!
Sep 13, 2008 | Kenmore Oasis HE 27062 Top Load Washer
Kenmore Oasis has LF code on and won't reset
The LF code indicates "Long Fill" which means it is taking too long for the water to fill the washer (times out). From the owner's manual:
"LF" (Washer is taking too long to fill)
Check the following:
Are the water inlet hoses kinked or clogged?
Are the water inlet valve screens clear?
Press STOP to clear display.
Here's a suggestion I found that worked for me:
Check your drain hose to see it it's stuffed too far down the standpipe. Another poster had this problem and it gave her LF errors. If the drain hose hangs down too far it can siphon water out of the washer, and then the washer thinks it's taking too long too fill. There's supposed to be a U-shaped plastic bracket that sets the length of the drain hose where it goes into the standpipe. Your installer may have tossed it.
Apr 07, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
