Question about Linksys WUSB54GSC Compact Wireless-G USB Network Adapter w/ SpeedBooster [WUSB54GSC] (LS-SB54GSC)
Won't connect to source
We had a power outage. After the outage when I turned my computer on everything worked except for the adapter. When I plug it in it says it is active and the monitor comes up, then it says it cannot associate with access point. When I try to move to the site survey tab, it stops responding, I don't know if some kind of driver got removed or what happened. I don't have the original stuff that came with it because my brother bought and installed it for me. Would there maybe be a way to uninstall and reinstall without having whatever disk came with it. Like a place on the internet that has the drivers or something.
    Problem Solver:
  • 16 Answers
How do I fix my panasonic vierra that won't come on after a power outage?
Pull the plug and with the power disconnected hold the power button on for 60 seconds. After at least the 60 seconds plug the tv in and try to start it. If it works great if not , hold the power button in the on position for a count of 20 with the tv plugged in . If theres still no Joy try power with one of your volume buttons at the same time . One of these should provide a hard reset for the tv.
SOLVED 50 panasonic Viera model no TC P50C2 won turn on red light blinks...
Jan 26, 2018 | Televison & Video
Dell inspiron 560 won't recognize network adapter
Try reinstalling the NIC driver. If its separate network card, connected in PCI adapter, try to remove and plug it back in to see if its found after.
If these actions do not help, maybe NIC was damager with the power outage, it can happen.
Nov 04, 2012 | Dell Inspiron 560 MT Celeron 450@ 2.2GHz...
if there is no netework adapter in device manager or any device that is not instaled try checking in BIOS if it is enabled. sometimes after power loss bios is reset. if it is enabled in BIOS that short power outage probably killed your network adapter. you can add some PCI network adapter and solve your problem.
My dell gx260 ligth come green if i turn it on but for a few mins time it turn orange why
Do you mean the monitor's power light starts green and then turns orange when you turn it on? Most monitors will go to a power saving mode when they do not get a signal from the computer.
The Dell GX260 has a green power light when on. When the computer is off, the light is off. If it is green and blinking, then the computer is in a power saving mode.
Diagnosis: start with the obvious: is the monitor cable plugged into both the computer and the monitor (if not permanently connected to the monitor)? Are you connected to the active port? (You can add a video graphics card in most desktops. The motherboard video port usually needs to be disabled to use the card ports. If you plug in the monitor cable to the disabled port, it won't work.) Is the monitor set to the correct input? (This applies if the monitor has several ports. In that case, there will be a Source or Input button on the monitor.) Is the computer on? The GX260 has the power button on the front. (Other computers have the power button on the top.) There is also the power supply switch on the back which needs to be on.
Next try a different data cable between the monitor and the computer (if you can). Try a different monitor. If a second monitor works, than the monitor has a damaged main board. If the second monitor doesn't work, then the video graphics adapter has probably failed. Replace the add-on card, if in use, then boot in the safe mode to remove the old graphics driver. Then install the correct driver for the graphics adapter.
Note: the computer and the monitor should both be off when you connect the cables. Then turn on the monitor first and set it to the correct source before turning on the computer.)
I hope this helps.
Aug 21, 2011 | Dell OptiPlex GX260 PC Desktop
Power to house went out during area power outage. Everything came back on except the computer? Tries to restart by holding power switch in, unplugged and replugged power cord - no response on monitor. ...
When the power is returned after a power outage it can cause a power surge and damage electronic equipment such as a computer. This is a reason to install a surge protection power board and connect your computer equipment to a surge protection board.
The switch mode power supply may be faulty and replacing it may get your computer operating again.
If you cannot DIY then ask a friend or take it to a computer repair shop.
Jul 14, 2011 | HP Pavillion s7420n PC Desktop
Netgear wireless router has no lights after power outage. Actually, the circuit breaker switch for the room the router is in, was accidentally flipped. The power light will not even come on. The device has...
On the router, you will see some sort of ventilation for the air to pass try smelling from there and if you smell anything the smells like burnt plastic or rubber then the device itself is burned from inside because of the power outage, however, this is extremely rare case scenario I doubt it will burn like that so easily, and do perform the same step on the power source adapter of the router because in many cases it is the power source that gets burn and not the device.
After that perform some troubleshooting steps check if the power chord connected to the router is properly connected also please check the power outlet with other electronic devices to see if the outlet is working.
I am not sure but I am assuming that it is the power adapter that got damage and not the router. Let me know if any issues.
Aug 27, 2017 | NetGear RangeMax NEXT WNR834B Wireless...
WE HADA A POWER OUTAGE AND NOW THE WIRELESS IS NOT WORKING AND THE LIGHT ON ROUNTER DOES NOT COME ON
Is the router plugged into the same power source (surge protector or power strip) as your computer? Try plugging it into a different outlet -- one that you know works -- and if the router doesn't turn on there then either your router is fried or the AC adapter that powers it is fried.
May 30, 2010 | D-Link DI-634M Wireless Router (DI634M)
Power Outage & Now Wii Won't Power Up...
When this same thing happened to me, I unplugged the Wii power supply from the wall (not just from the back of the Wii) and let it sit unplugged for about 10 minutes. When I plugged it back in, everything was fine.
Nov 11, 2008 | Nintendo Wii Console
Computer Speakers
Try and plug your speakers into a friend's computer and check if they work. If they don't, then the speakers are fried, probably because of a voltage surge when the power went out. If they do work on your friend's computer then you most likely have a bad port on your computer because of the power surge.
Dec 14, 2007 | Cyber Acoustics CA-2016 Computer Speakers
Linksys WUSB54GSC Compact Wireless-G USB Network Adapter w/ SpeedBooster [WUSB54GSC] (LS-SB54GSC) Logo
131 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
