Question about Canopus ADVC-300 A/D Converter Video Capture
Can I convert PAL?
Does it have any PAL >> NTSC conversion capability?
What happens if I put in a PAL VHS tape? Can I at least get a PAL QuickTime file, that I might then be able to convert with Final Cut Pro's Compressor utility? I haven't done that yet either, so I'm looking for a solution. Any advice very much appreciated.
thanks!
  • 68 Answers
No, you have to capture a signal in format it is generated, save the recording and then do 'transcoding' into different format. Search web for free transcoding utilities.
Posted on Feb 16, 2009
Can i convert at PAL video with this machine?
The version of the ZV427MG9 sold in the U.S. only supports NTSC video files. Thus it won't play a PAL VHS tape.
If you find a similar version sold in Europe, that would probably play PAL videos. However, if you used the tape to DVD dubbing feature, the DVD would still have the PAL format. I'm not even sure that a video capture device with video conversion software on a computer would do what you want to do.
I wish that I had better news for you.
(The video would also matter. If you are trying to convert a commercial video (ex: a movie) to DVD, the dubbing feature doesn't work due to copy protection.)
Feb 14, 2015 | Magnavox ZV427MG9 DVD Recorder/ VCR
NTSC to PAL question
yes system conversion is you need just change the crystals! buy a palsecam crystal then replace the old crystal.
Dec 24, 2007 | Hitachi M2 Digital Camera
Honestech tvr video recorder
The Color subcarrier is different on pal. NTSC tapes , cameras, VCR's will all show B/W on a NTSC TV.
May 09, 2013 | Fulltone Ruby GrabBee Deluxe USB 20 NTSC...
VHS code compatibility
The video standard in Japan is PAL while it is NTSC here in the USA. You should be able to locate a VCR than can play both. If you'd rather not purchase a new VCR, some locations that create DVDs from VHS tapes can usually also read PAL tapes.
Dan
Mar 18, 2008 | Televison & Video
PAL to NTSC conversion
This is not a converting unit, it will play the format of the tape inside. To convert the signal you need one of the following:
1) A converting VHS player; they are fairly expensive.
2) A separate video converter (hardware); they run for about $200-$500; just put this between your VCR and the TV.
3) Capture the PAL on your computer using a software like Movie Maker via a Firewire cable. Than convert it to NTSC on your machine using software like Nero... do a search on Google for converting software. Or just watch it on our computer in PAL format, most computers do that... For this step I use a separate camcoder that has a passthrough feature. The VCR connects to it and the camcorder connects to the computer via Firewire.
4) send the PAL tape to a specialized shop for conversion. They normally charge $30-$40 for a regular 2h VHS tape.
Jan 20, 2008 | Philips DVDR3435V/37 DVD Recorder/VCR
You might need to input a code on your VCR Remote. Try looking it up on the Internet.
Jan 13, 2008 | Aiwa HV-MX100 VHS VCR
Pal to NTSC
Hi, Based on your post/description, you need to get a multi-system TV to go with your multi system VCR if you are going to playback VHS tapes from different regions. You are quite correct "Plays NTSC tapes to NTSC, Will not Play Pal to NTSC" to play PAL (even Secam) you would need a PAL/Secam TV. They have a different system for color and audio. In some cases, you can still play PAL but you get it in black & white and picture squeezed from top & bottom. Hope this be of some help to you. Good luck and kind regards.
Aug 22, 2007 | Samsung SV5000W VHS VCR
NTSC tapes to PAL DVD
Hi, I suggest you to contact a company that will convert the NTSC VHS to DVP Pal for you. This will be easier and more effective (and unless you have MANY tapes, this will be cheaper). I did a quick search and I found this place: http://www.video-convert.co.uk Please let me know if this is helping!
May 23, 2007 | HP DC4000 (Q2125A#ABA) DVD±RW Burner
NTSC to PAL
You have to buy first a VHS player that can play NTSC, might not be available locally in Ireland so you have to probably buy online (US). The DVD recorder is fairly comnon nowadays and all of them are capable of recording and playing NTSC and PAL. You can then connect the AV out of VHS player to the AV In of the recorder. Or you can use a VHS-DVD combi. You can google in UK, here is an example: Toshiba RD-XV45, according to the specs, it can play NTSC on the VHS and you can record to DVD on any format that yoou want You can go to this link to view other product: http://audiovisual.kelkoo.co.uk/b/a/sbs/100304323/16875665.html My father died of cancer 6 years ago and I am also transferring the Hi-8 videos to digital format using PC.
May 23, 2007 | Samsung SV5000W VHS VCR
Convert NTSC VHS video tapes to DVD PAL
If you do not have an adaptor to play the tapes to a standard VHS viseo player, you can use the camera as the player by connecting the AV out to a DVD recorder. There are hundreds of models in the market, and do not worry if it is NTSC or PAL because 99% of DVD recorder accepts both.
May 23, 2007 | Panasonic PV-GS150 Mini DV Digital...
Canopus ADVC-300 A/D Converter Video Capture Logo
111 people viewed this question
Top Canopus Televison & Video Experts
Yoav Shilon
Yoav Shilon
Josh Whitehead
Josh Whitehead
Paul Bade
Are you a Canopus Televison and Video Expert? Answer questions, earn points and help others
