Question about GE Spacemaker Washer and Dryer Electric Laundry Center
GE spacesaver washer fills, but won't agitate, just hums .
The tube seems to be stuck only turning in one direction. how do you get the tub out.
SOURCE: Ge prodigy wpse4270aoww won't rinse or spin
if basket wont spin, remove front hatch by inserting spackel knife to trip spring latch on both sides,then check the belt for wear & tear.factory length is 29.5 " time will stretch them out, resulting in broken belt.check behind control panel hatch for diagram of machine for exact location of belt also can be downloaded online.
I hope this helps.ie overloading machine will shorten belt life.
Posted on Mar 07, 2008
Macintoast
  • 4 Answers
SOURCE: GE washer won't agitate
I had this same problem with our GE top load washer.  I just needed to pull harder.  (Note: The agitator is held in place by about a dozen L-shaped clips in a ring around the agitator's base that will release more as you pull harder on the agitator.)  Everything from the base below the large fins on up comes out together.  Grab the shaft above the fins and pull slowly and hard. I had to take the entire tub out, lay it on the porch, put my feet inside of it, and pull the agitator assembly out.  I wasn't able to pull it out while it was still in the washer.  BE CAREFUL! DON'T **** IT OUT; that might injure your back; just pull out slowly and as hard as you can without hurting yourself.  I was able to get it out successfully, but I am currently stuck at removing the bell below the agitator.  Good luck!
Posted on Feb 28, 2009
  • 3 Answers
SOURCE: My Estate Whirlpool Washer, model #TAWS850PQ0
if it cuts off the water ok and motor running
it could be a coupling .
possible transmission.
if no motor noise
could be motor .
wiring,
timer.
Posted on Jun 16, 2009
hiltonjug
  • 612 Answers
SOURCE: ge profile washer WPSR3100W1WW won't agitate
I see this pretty regular. You have a bad transmission. This is very common with the older GE's. To replace the transmission will run around $340 / $400. Not sure about your area. Just be glad you got this much use out of it, you are one of the very few that have. From 1998 till 2007 I owned my on repair company where I did GE's warranty work in my area for them. During that time period. When I found a GE washer under warranty doing what you are describing. GE would warranty the whole machine. They would have me destroy the machine after I would deliver the customer a band new one. GE knows they had a bad transmission and it cost them a lot of money. It was cheaper for them to replace the washer than have me repair it. The transmission list price was $298.00 back then. A word of advice, when you replace it. Buy a Whirlpool, Kenmore, Maytag. These brands hold up the best. I have the least service calls for Whirlpool and Kenmore. Both are made by the same people. Kenmore is made for Sears. Good Luck.
Please rate this solution if helpful. Thanks
Posted on Aug 21, 2009
mgprice
  • 744 Answers
SOURCE: Tub will fill, but won't advance to agitate or
Hello, from the limited information I have this sounds like it's going to be a broken coupling. Kenmore's and Whirlpool's are direct drive machines this means they don't have a belt. Instead the transmission is connected directly to the motor via a coupling. This is what a coupling looks like: 0c6b869.jpg To confirm this pull the machine forward enough that you can lean it back and it will stand back under it's own weight. Wedge something underneath the chassis so it does not fall on you while your accessing the bottom. Go under the Machine and locate the motor, You will see the pump connected to the motor connected to the transmission. 1. Unplug the wire harness from the motor then. 2. Use a screw driver remove the 2 clips holding the pump in place and remove or push the pump out of the way. 3. You will need to remove the 2 screws from the brackets holding the Motor in place with a nut driver. 4. With a screwdriver remove the 2 clips holding the motor in place (be careful to support the motor as the clips comes off) 5. remove the motor and drop it onto the floor. Now you will see the coupling..one side on the motor the other side on the transmission the rubber connector in between. Replace the coupling if broken or worn and reassemble the washer in reverse order. Now you should be all set. Be aware you may smell rubber on the first couple loads this is normal after replacing a coupling. Good Luck!! if you have any other questions or concerns please feel free to comment again. Mike p.s Please remember to rate my solution since this helps me to help other people :) Thanks! P.s Don't forget to unplug the power cord before servicing.
Posted on Oct 10, 2009
Frigidaire washer goes straight to agitation and won't fill with water.
IN UNIT THERE IS A SENSOR OF PRESURE WICH HAVE A TUBE FROM WATER CUVA , and when fill water presure high from tub activate membrana and cicle startit ;may there a problem and also at ev . of in water, chec connection and clean dirt but with main out
Nov 04, 2012 | Frigidaire Washing Machines
Washer hums but will not fill or start/ spin has water pressure and tub seems to move freely the model #on tag LTF2140ES0
If it doesn't fill it won't start any other cycle unless you move it ahead yourself. If it hums I am thinking it is trying to fill. Sounds like the valve is turning on to let water in but it is not getting through. My washer has a screen where the hoses go on and sometimes the screen becomes plugging with scale. If that is ok then the solenoid must be coming on but the valve is stuck. Does neither hot or cold settings work? Please rate my answer so I am rewarded points for it.
Jan 27, 2012 | Frigidaire Washing Machines
Washer won't fill
Hi pollystepp.
Without knowing the make and model, a basic answer to this problem is that the fill switch has gone bad. If your machine proceeds to agitate and spin without water, the washing machine 'thinks' it has water in it and this happens when the fill switch is stuck open. Rarely, the tube that goes from the tub to the switch may be clogged which may cause the switch to remain open.
Good luck from Detroit, MI.
Oct 20, 2011 | Washing Machines
My washer started to leak. I removed the front panel. I ran a load of clothes and watched closely. When the machine filled and started to agitate I noticed water coming front what to me appears to be some...
Hello litespeed102,
When you observed the agitation cycle did you hapen to notice if the inner tub was rotating during the wash cycle(not spin) if so the brake that is a internal part of the transmission isnt locking down the tub, and what is happening is water is coming from that tube due to centrifugal focre of the the tub rotating causing the water to rise to the level where it will enter into that tube. The only fix for that is to replace the transmission,which would cost more that the purchase price of the machine,over time it will get worse and while it may be only moderate leakage now later it it will be 1/2 of the waterin the tub if not more leaking from directly over the tub cover and just not merely from that tube
Jul 22, 2011 | GE Washing Machines
GE Spacemaker Washer/Dryer. Model # DDPI380GAMWH. Water won't stop filling. It continues to fill during all cycles. Fills during agitation. Agitates inproperly. It agitates in short pulses as water...
Thanks for choosing FixYa and welcome. This sounds like a problem with the water level switch in the washer. It controls the amount of water entering the tub. It is probably defective. You may want tomake sure the switch is getting power first by testing the wires with a voltage meter.
Jun 18, 2011 | Washing Machines
GE washer does not agitate does not stop filling up
If your washer is filling until it overflows without agitating, and will stop filling if you turn machine off or interupt power to it, the machine is not seeing that it is full. This may be caused by a blocked water level tube (usually some "goop" where it connects to the tub), a hole in the water level tube (look near the suspension rod or where a mouse may have chewed a hole in it), or a bad water level switch. You do not state a model number, or even if it is a top loading or front loading machine, so that is the most information I am able to provide at this point.
Oct 19, 2009 | GE Washing Machines
Brand new agitator does not rotate. I realized that I did not buy a new "seal-cap" that goes between the agitator and the cap. Would the missing cap cause the agitator to fail to rotate? GE spacesaver...
by 'rotate' do you mean that it will not turn at all or that it turns in both directions and does not 'rachet', turning in one direction only and agitating the clothes? If it rotates freely in both directions, it's probably your agitator dogs not engaging either due to improper assembly or breakage.
Aug 21, 2009 | GE Washing Machines
Washer will not spin
I fixed it yesterday. After checking the continuity of my lid switch and pressure switch and finding them ok I removed the tubing from the pressure switch and applied air (blew into it). There was a clog and blowing on it removed it for now. Apparently the pressure switch was telling the machine that the tub was full of water and wouldn't let it start the spin cycle. I ran three loads last night and it worked perfect. I may have to remove the connection on the side of the tub and clean it properly if it clogs again.
Mar 23, 2009 | GE Washing Machines
Fills the hums loudly
Hello , Have you looked inside the pump where the hose comes from the tub , there could be an item clogging it , also try turning the pump where the shaft goes by hand , it should turn freely.
You can also try turning the gear case with the motor off where the coupler is attached , 1 direction will agitate and the other direction spins , you should be able to turn the gear case both ways and it will not turn easy.
if all of these check out the motor could be bad but it is highly unlikely.
let me know how it works and if you have any other questions.
Phil
Jan 08, 2009 | Kenmore 15864/15862 Top Load Washer
GE Spacemaker Washer and Dryer Electric Laundry Center Logo
127 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
