Question about Dryers
My Whirlpool LGN2000PGO not getting HOT
Hi my dryer is not getting hot at all. modle num. LGN2000PGO i ordered a thermal fuse item 2986 didn't work then I order a cycling thermostat with internal-bias (heater) L155-25 still not getting hot now what do i do now. my whirlpool gas dryer is not getting hot. I already replaced the ignightor and still no heat.
  • Jeremy Reddick
    Jeremy Reddick May 11, 2010
    Are you sure that the unit is getting adequate gas flow?
    President:
  • 1,902 Answers
Have you checked the gas valve to make sure that it is functioning correctly?
Posted on Feb 13, 2009
2 Suggested Answers
kachbibi1
  • 979 Answers
SOURCE: My Whirlpool LGN2000PGO not getting HOT
It may be the element has gone bad. You can visibly check it to see if it is bad. Quite simply the wire will be burned in two. I assume your drum is turning o.k.
Posted on Jan 14, 2009
Whirlpool dryer wed5700swo. only about 2 years old, not drying as good as it used to. think i blew a thermal fuse because the vent was clogged. there is a thermal fuse with 4 wires in the lower left...
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 07, 2011 | Whirlpool Dryers
Amana dryer model YNED7200TW will not start. there is power, but start button does nothing. Resetting breaker did not work. Any ideas?
Thermal Fuse
Item #2986 (OEM Part)
$10.70
Thermal fuse. If the dryer overheats, this device stops the flow of electricity to the heat source and/or the entire dryer. It is located on the blower housing and cannot be reset. The most common cause for overheating is a vent tube clogged with lint, a birds nest or other debris.
Manufacturer Number 3392519
More
  • Admiral Dryer Thermal Fuse
  • Amana Dryer Thermal Fuse
  • Crosley Dryer Thermal Fuse
  • Estate Dryer Thermal Fuse
  • Kenmore Dryer Thermal Fuse
  • Kenmore Refrigerator Thermal Fuse
  • Kenmore Washer/Dryer Combo Thermal Fuse
  • KitchenAid Dryer Thermal Fuse
  • KitchenAid Washer/Dryer Combo Thermal Fuse
  • Magic Chef Dryer Thermal Fuse
  • Maytag Dryer Thermal Fuse
  • Roper Dryer Thermal Fuse
  • Roper Washer/Dryer Combo Thermal Fuse
  • Whirlpool Dryer Thermal Fuse
  • Whirlpool Washer/Dryer Combo Thermal Fuse
In Stock
Quantity: http://www.repairclinic.com/PartDetail/Thermal-Fuse/3392519/2986#repairHelpVideoTabs
Jun 08, 2011 | Amana Dryers
Won't start, stays in the sensing mode when i push start button.
I had the same problem & just had a repair man out. A Thermal Fuse was blown - this occurs if you run your dryer a lot & don't let the cycle complete so the dryer cools down. If you stop the dryer mid cycle it's important to leave the door open so it can cool down or run a timed dry cycle on Air Only so the dryer can cool off.
My repair took less than 30 minutes & you can get the Thermal Fuse (item #2986) on www.repairclinic.com - part is $13.05 + shipping. Shipping varies depending on how soon you want the part.
To test it, use an Ohm meter or continuity checker, if no continuity it must be replaced. Unfortunately, you can't tell if it's bad by looking at it.
Nov 01, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I replaced the igniter and thermal fuse and dryer
The thermal fuse should only be replaced if the dryer will not start
If it starts the thermal fuse is good.
If you touched the ignitor with your fingers it may have blown out.
Open the dryer and check for voltage to the ignitor through the ignitor wires while the dryer is on.
If you have no voltage check the hi-limit thermostat for continuity as well as the operating thermostat.
Check the flame sensor for continuity while it is cold.
If you have power to the ignitor place a clamp on amp meter on one ignitor wire and turn the dryer on.
If you read 3 amps or less the ignitor is bad.
If it reads the amps or more the gas valve coils are bad.
Jan 17, 2010 | Whirlpool Dryers
I have a kenmore dryer model # 86661100 and it doesn't get hot
Below are some links, courtesy of www.repairclinic.com, that will assist you in diagnosing/repair of your dryer. You may have to enter your model number in the search box to access some of the information. It is helpful to have a volt-ohmmeter for diagnostic procedures.
All links courtesy of www.repairclinic.com
Once your NO Heat issue is resolved, your timer issue should remedy itself.
1. Parts breakdown/disassembly procedures diagram.
http://www.repairclinic.com/Dryer-Electric-Whirlpool-Style-Version-1-Appliance-Diagram
2. Heating Element.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-86661100-%3d%3di3367&PartID=3367
3. Thermal Fuse.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-86661100-%3d%3di2986&PartID=2986
4. Drive Motor
http://www.repairclinic.com/SSPartDetail.aspx?s=t-86661100-%3d%3di2584&PartID=2584
5. Adjustable Cycling Thermostat
http://www.repairclinic.com/SSPartDetail.aspx?s=t-86661100-%3d%3di2895&PartID=2895
6. Hi-Limit Thermostat
http://www.repairclinic.com/SSPartDetail.aspx?s=t-86661100-%3d%3di2934&PartID=2934
Aug 30, 2009 | Kenmore Dryers
Whirlpool dryer not getting hot mod# lev5634aw0
REMOVE THE FILTER AND THE 2 SCREWS UNDER THE FILTER LID THEN PRY THE TOP OPENED AT THE FRONT EDGES BETWEEN THE TOP AND FRONT PANEL THEN OPEN AND LOOK AT THE TOP OF YOUR HEAT ELEMENT HOUSING REMOVE THE 5/16 HEX HEAD AND PUSH IT TOWARDS THE REAR TO DISENGAGE IT FROM THE BACK OF THE REAR BULKHEAD THEN LIFT UP AND OUT IT COMES. cHECK YOUR THERMAL FUSE FOR CONTINUITY. GO TO www.repairclinic.com SCROLL ALL THE WAY DOWN AND CLICK THE RED 100 AND CHECK THESE PARTS AS WELL. 2986, 2821, AND 2893. THE ELEMENT IS 3367. 2986 NEEDS TO BE CHECKED FOR CONTINUITY.
Apr 14, 2009 | Dryers
Jan 14, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool Dryer Model#GEQ9800LW0 will not get hot
Sounds like a heating element. Those can run pretty cheap and are not hard to replace.
Suzanne
Dec 11, 2008 | Whirlpool GEW9200L Electric Dryer
Dryer works but no hot air
Hello, if it's an electric dryer and you have absolutely no hot air, then it's either the heating element or the thermal cut-off, most likely.
The thermal cut-off is the fuse on the element's housing.
Check both for continuity. Good luck :)
Please feel free to keep emailing me if you'd like.
Nov 18, 2008 | Whirlpool LEW0050P Electric Dryer
Dryers Logo
259 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
