Question about Hitachi DV-PF74U DVD Player/VCR
Door won't open on hitachi dv-pf74u - Hitachi DV-PF74U DVD Player/VCR
    Sergeant:
    Champion:
  • 285 Answers
Could be a number of things.
Loose belt ( this can be heard if its like a squeeling noise when you press the eject button. )
The motor which wont make any noise at all if faulty or the Motor Driver I.C is shorted.
hope this helps.
Posted on Feb 13, 2009
Where is the serial number on a hitachi DV18DGL combi drill
Replacement HITACHI DV 18DGL battery pack 100% compatible with the original DV 18DGL battery, high quality, wholesale price. Replacement Cordless Drill Battery for HITACHI DV 18DGL
Jun 03, 2017 | Hitachi Drills
Hitachi ax-m71 cd door won't stay closed. Unable
if it opens back up when you close it the drawer mechanism is probably out of alignment. Most players have a slot on the bottom of the drawer that a pin must slide in. Look under the drawer and see if there is a pin sticking up that maybe should be in that slot.
Jul 09, 2013 | Audio Players & Recorders
Hi I have a provlem, I have a canon xl1 and when I try to open it to tack the mini dv out but the only thing it opens its the door but the mini dv dose not comes out, if someone have some recommendation it...
You have to have a battery attached in order for the camera to eject the tape, also sometimes if you don't open the door all the way it won't eject the tape either. If it's not that the DV deck may be broken and you could send it in to the company or you could pay a local camera repair company to fix it.
Feb 26, 2012 | Canon Photography
I am looking for a User Guide for a Hitachi DV-RX7000A.
Hello
The model number you sepecifies here is not available even with Hitachi Europian website too.
Oct 30, 2011 | Hitachi DV-RX7000 DVD Recorder
How do I tune DVD into television
All you need is to connect the DVD into the AUX ports of the TV Use the digital output/optical cable if there is an input If not use the video output to the video input and the audio outputs to the audio inputs.
There is no tuning required but only the selection of the AUX or other input source selected.
Feb 19, 2011 | Hitachi DV-PF74U DVD Player/VCR
I have a Hitachi DV PF74U the sound comes out on
you have your audio wire in the dvd side, put it in the vcr side
Feb 14, 2010 | Hitachi DV-PF74U DVD Player/VCR
Vcr picture is scrambled on our VCR/DVD combo unit.
If you have used the VCR a good bit, the drum may need cleaning. VCRs derived their synchronization from the recorded tape and if the heads are contaminated, the sync signal may not be getting through often enough to stabilize the tracking.
This is not a fun thing to do but I once serviced these and it can be done with care and cure the problem.
You will need cotton swabs and (preferably) some pure alcohol (not rubbing alcohol). Gaining access to the drum requires removal of the housing and perhaps, in a combination unit even more, keeping mind that both of the decks works with astoundingly small signals; relatively low voltage signals and an amazing precision in the mechanisms.
If you can gain access to the drum, do NOT ever touch the shiny surface of it with fingers since the oil on the skin can really screw things up.
You can rotate the drum with a finger on the top of the drum and hold your alcohol wetted swab gently against it while rotating the drum.
If the drum is the cause of the problem, you should see some dark deposits build on the swab. If fibers catch in the opening for the heads, you will have to rotate it in the other direction while holding a tissue gently against the drum; no fibers from anything should remain snagged on the drum, otherwise your efforts will be for nought.
Good luck-
Sep 13, 2009 | Hitachi 168589 DVD Player/VCR
Dish can not open.Remote is dv-rmds160.Can not read languge on it
need to go to www.hitachi.com. Go to support, query for your model, aguire pdf file for manual on language and all other problems
Jun 17, 2009 | Hitachi DV-DS160 DVD Recorder
Unlock zone Hitachi DVD player
I can't get my hitachi natura to connect to my dvd player using RCA plugs. I can't actually see how to switch to the av mode! Please help - small children going BONKERS!
Apr 13, 2009 | Hitachi DV-P745U DVD Player
Hitachi DV-PF74U DVD Player/VCR Logo
75 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
