Question about Canon i850 InkJet Photo Printer
Replaced ink in canon i850 printer. Now it will not print
Pinter will not print black. Just replaced the black.
Was working fine before I replace cartridge.
What did I do?
  • Anonymous Feb 21, 2009
    I have the same exact problem!
  • 40 Answers
Hello.
First make sure you removed any protective tape or caps on the
ink cartridge.
If there is a contact surface on the cartridge make sure
there is no dirt or fingerprints on the contact surfaces.
You can download the user manual here.. CLICK HERE.
Have a nice day...
/Tech5508
Posted on Feb 13, 2009
My Canon i850 printer has stopped responding to a
The Canon i850 uses cartridges of type BCI-3. according to Canon, the color cartridges are compatible to:
BJC-3000 Series, BJC 6000, i450, i550, i850 Series, MultiPASS F30, F50, F60, F80, MP 700 and MP 730, S400, S450, S500, S520, S530D, S600, S630, S630 Network and S750.
The black one will work in a few more models.
Feb 07, 2010 | Canon i850 InkJet Photo Printer
Printing, but not full words Canon i850
Sounds more like the actual print head has become dried out and simply needs to be cleaned. This is a common problem with Canon Bubble and Ink Jet printers.
You should be able to remove the cartridge and then the print head shuttle that moves across the page. Once you have it removed, you will need to get a couple of Q-tip swabs and some DENATURED ALCOHOL, NOT RUBBING ALCOHOL as the water in rubbing alcohol will damage the printer head. Wipe the face of the printer head GENTLY with a moistened swab, you should see the dried ink dissolve, do this a few times until you see no further ink on the swabs.
Allow it to dry for a few minutes and then reinstall it into the printer. You will need to run the alignment function of the printer to ensure that the print is aligned properly. That should do it.
Cheers,
Keith
Sep 19, 2009 | Canon i850 InkJet Photo Printer
Canon i850 printing but pages are blank
I had the same problem after changing the black ink cartridge. I went to Control Panel of my computer, chose Printers, then Canon Inkjet. Chose Properties, then Maintenance, the Deep Cleaning. NOW my printer is working!!
Jun 16, 2009 | Canon i850 InkJet Photo Printer
Colour printing comes out in lines across the whole page
Is the nozzle is perfect? i dont think so. But, if you print with best/photo mode is ok.
Jun 01, 2009 | Canon i850 InkJet Photo Printer
7 yellow flashes not printing
hi welcome to fixya!
I believe there is no print head failure happening. I experience that one time, it only needs a new ink cartridge. Be sure to replace the right color!
have a nice day!
Apr 17, 2009 | Canon i850 InkJet Photo Printer
Print head problems 7 yellow lights 1 green light, how do I fix
That's not a printhead problem, it's saying that the waste ink absorber is full. You need to have them replaced at a shop where they can also reset the waste ink counter.
Apr 13, 2009 | Canon i850 InkJet Photo Printer
Printer stopped printing colour
Are you using Name brand ,new ink cartridges?
Take the color cartridges out and make sure you removed the tape from the bottom of those cartridges. if done already take a wet paper towel and squeeze out the excess water, then lay the damp paper towel folded in half on a flat surface.
Then set the colored in cartridges one at a time with the ink side pressing against the damp paper towel for about 3 min. after 3 min you should see the ink drain on to the paper towel if so then replace the cartridge back into the printer and that should solve your problem.
Feb 14, 2009 | Canon i850 InkJet Photo Printer
Black doesn't print
THE CARTRIDGE MAYBE NO GOOD OUT OF THE BOX.
PRINTER NEED TO BE CLEANED
I DONT THINK ITS A DRIVER PROBLEM
BUT YOU WANT SOME OTHER OPTIONS TYPE IN THE ADDRESS BAR:
CANON 850i INKJET PHOTO PRINT WILL NOT PRINT BLACK INK
ROD
Jan 11, 2009 | Canon i850 InkJet Photo Printer
Blank pages coming out of i850 with new printhead
Alarm / Power light flashes orange 7 times consecutively is a Print head error so it sounds like you did the right thing.
I would reseat the printhead along with each one of the ink cartridges. Make sure that you removed the tape from the bottom of each of the ink cartridges and try it again. After installing the new printhead, you should have run a printhead cleaning cycle immediately after installing.
Issue: Certain colors are missing or no ink prints on the paper
Solution: Install / replace the recommended ink tanks correctly i550 / i850
Untitled Document How to install / replace the ink tanks
The ink tanks suitable for the printer are as follows;
Black Ink Tank BCI-3eBK
Cyan Ink Tank BCI-3eC
Magenta Ink Tank BCI-3eM
Yellow Ink Tank BCI-3eY
Note: There are two ink tank label designs.
Operation procedures are shown with label design A.
labelsa.jpg Replacement Procedure
1. Check that the printer is powered on, and open the front cover. Wait until the print head moves to the center.
2. Remove the empty ink tank by pushing the tab on the ink tank.
Note: When doing this, do not remove the print head. When replacing multiple ink tanks, it is recommended to replace one at a time to avoid inserting them into the wrong slots.
(The image is an example using i850.)
3. Remove the new ink tank from its package. Pull the orange tape in the direction of the arrow to remove it completely, and remove the shrink-wrap film.
Note: Remove the orange tape completely. If the tape remains, printing may not be performed properly.
Confirm that the orange tape is completely removed from the ink tank, as shown in image 1. If the tape is similar to the sample in image 2, remove the remaining portion of the tape so that it looks like the sample shown in image 1.
(1): Correct
(2): Incorrect (where the arrow indicates)
4. Slowly twist the orange protective cap in the direction that the arrow indicates, and remove it. To avoid ink adhering to your fingers, brace the orange protective cap while removing it.
5. Insert the new ink tank to the print head by holding it at a slight angle.
Note: Confirm that the ink tanks are installed in the right order according to the labels on the print head.
6. Press down on the top of the ink tank until a click sound is made.
7. Close the front cover. The next time the printer performs printing, it will automatically start print head cleaning. The power lamp will flash while cleaning is performed. Until cleaning completes, do not perform other operations.
May 07, 2008 | Canon i850 InkJet Photo Printer
Canon i850 InkJet Photo Printer Logo
120 people viewed this question
old marine
old marine
