Question about Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
Kenmore oven wont light
Broiler works top works oven won't light
  • scott948 Feb 18, 2009
    Thanks once again you save my ****
  • stevefrazin Feb 26, 2009
    I have the same problem. I replaced the ignitor. Now it glows, but won't light the gas. The gas comes on, but will not light even though the ignitor is glowing. Can you help????? Thanks.
    Novelist:
  • 117 Answers
I am not sure what model or make you have to be precise but replacing the oven ignitor is relatively simple. Gain access to the bake burner area. There are two mounting screws which secure the old ignitor to the bake burner. Remove these screws and then follow the wires to their respective connections. Make the connection change and mount your new ignitor. If I can help further, I am here...
Waiting to hear from you,
Eric Campion
Posted on Feb 14, 2009
3 Suggested Answers
duby1990
  • 370 Answers
SOURCE: top broiler working but botton part not
Try changing the oven ignitor.
Posted on Nov 18, 2008
aborcass
  • 2651 Answers
SOURCE: Amana stove, oven igniter works but oven wont light
although the bake ignitor appears to be glowing, it probably does not glow with the intensity it needs to open the safety valve assy, VERY common problem, go aheadand replace the ignitor, this will correct your issue
Posted on Feb 09, 2010
Testimonial: "100% correct, I ordered the part from on line and it was a very easy fix and the oven is working great. Thank you"
Kenmore elite stove model #7909912949B. Can get anything to work on oven. Light comes one. Nothing else in the enter panel. Top burners work.
Can you enter the oven temp and press start on the control panel? Do you hear it click on, but it just does not get hot? Try turning on the broiler and see if the broiler gets hot.
Feb 01, 2015 | Kenmore Kitchen Ranges
Kenmore electric range model 790 oven stopped functioning, both broiler and bake. however, oven light still comes on.
I believe there is a thermal fuse (also called a TCO or Thermal Cut-Out) located either on the back of the oven, or between the top of the oven and the cooktop that has opened up. Did this happen after running a self-clean cycle?
Sep 09, 2014 | Kenmore Kitchen Ranges
Kenmore gas range model #790-77471790 oven stopped working...broiler and stove top still work
If the oven has stopped working but the broiler continues to work, it would imply that the bottom heater is broken. When you are using the oven, both the heater for the broiler and the bottom heater are at use. The broiler only uses the top heater.
Elisa Jed ' http://www.atlasappliances.com
Aug 19, 2014 | Kitchen Ranges
Oven made pop noise now won t heat
It sounds like the control board blew out. I have had a couple of these just blow like that lately. The bake and broil wont work. . Check for any bad wiring but the control board is most likely the culprit.
Feb 20, 2014 | Ovens
Broiler wont light everything else works..model ffgf3023lwa
Hi Chris Stewart - If the bake element and the top of the range works, but just not the heating element, then you possibly have a bad broiler element or connection. However, if you are experiencing other performance difficulties, then the control board may possibly be faulty and needs replacing. Consult a professional for an accurate diagnosis.
Feb 02, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Ge profile gas oven broiler works but bake wont light
The ignitor for the oven burner is bad...
Here is a tip that I wrote about that...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Mar 30, 2010 | Ovens
My Kenmore oven wont ignite. The broiler works
The problem is your bake ignitor. The following link explains:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
The bake and broil oven features each have their own separate igniters and operate independently of one another. That explains why the broiler still works. They are, however, fed from the same gas source. So...the logical conclusion would be to replace your bake igniter (the no glowing is usually a dead give-away).
Replacements can be purchased on line at searspartsdirect.com, appliancepartspros.com, pcappliancerepair.com, or repairclinic.com. Prices can vary amongst sites, so shop around for the best price. The sites I provided to you, I found, tend to offer the best service and prices.
If you have questions along the way, or require addtional service, please let me know. I hope you find this information helpful.
Feb 28, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Oven not working. Top, broiler, and warmer are working.
Have you checked for proper gas flow into the over or broiler? This is a gas valve back there that will sometimes go bad. Also there is a sensor near your knobs, it is a timer that will go bad, the valve is about 85 dollars and the timer is about 65 dollars
Feb 08, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore Propane Range won't bake
The glow plug underneath the over floor need to be replaced
Dec 19, 2008 | Kenmore 36665 / 36669 Gas Kitchen Range
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Logo
514 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
