Canon PIXMA MX700 All-In-One InkJet Printer
Problem for Canon PIXMA MX700 All-In-One InkJet Printer
Switching from copy to print from computer
By engmary on Feb 13, 2009
After copying a document, I wanted to print a document from my computer, but can't get out of copy mode. I checked connections, turned printer on and off. No luck. HELP!
Comments:
Feb 15, 2009
- I actually solved the problem myself when I discovered that I had reconnected the printer wrong after taking my computer in to the Apple Store for a lesson. Thanks.
Best Solution
posted on Feb 13, 2009
Very Helpful)
websnail
Rank: Guru  Canon Expert
Rating: 92%, 211 votes
If you look carefully at the printer you'll note that there is no button for "Print" and the reason for this is that all the other functions are for using the printer as if it wasn't connected, nor needed a computer.
All your printing functions that DO use a computer require you to interact with the printer via the computer.
In short, to use the printer from the computer you'll need to make sure you've installed the correct drivers (see your installation CD or the Canon website) and then plug the printer in using a USB cable connection to your computer. If the computer recognises the printer you'll then be able to print.
In a nutshell if your printer is connected and drivers installed properly it doesn't matter what your printer has selected on the printers own control panel, you just print :)
Hope that helps.
Was this helpful?
Yes
No
Popular Solutions for Canon PIXMA MX700 All-In-One
Questions and Unsolved Problems for Canon PIXMA MX700 All-In-One
Do you recommend Canon PIXMA MX700 All-In-One InkJet Printer?
Answer
Answer
Can't print from MAC OS X 10.5.8 to Canon MX700 network printer. Get error message pop-up box... (More)
Answer
my fax machine recieves faxes but does not send out
Answer
mx 700 after set up cannot get past ( in window "install printer head and set the ink...
Answer
My Cannon MX700 is not copying straight. What could be the probem?
Answer
Model MX700 - scanner operates to send image to comuter but will not operate to make copies from... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printers Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
