Question about Sherwood RD-6108 Receiver
CANT GET SUB WOOFER TO WORK WITH MY RECIEVER!!!!!
I HAVE A BRAND NEW SONY SUB WOOFER. I CANT MAKE IT WORK WITH MY RECIEVER. THE RECIEVER IS A SHERWOOD RD-6108. I BELIEVE MY PROBLEM IS IN THE SETUP. PLEASE HELP!!!!!
  • 3 more comments
  • ckbmx51 Feb 13, 2009
    IT IS A POWERED SONY SUB. THE CONNECTIONS ARE CORRECT. I AM TRYING TO TELL THE RECIEVER THAT THERE IS A SUB BUT IT WONT LET ME. I NEED TO TELL THE RECIEVER THAT THE THERE IS A SUB SOMEHOW. THANK YOU FOR YOUR TIME
  • blueextc3221
    blueextc3221 May 11, 2010
    What is the model of the subwoofer??
    I think your problem is the subwoofer is not sensing the voltage to turn on the amplifier. (if it is voltage sensing)
    Reply with the subwoofer model #
  • rabidchimp May 11, 2010
    is there a subwoofer setting somewhere in the stereo? check the manual, or find one online if possible and see. sometimes the stereo requires the subwoofer setting to be on before it well send anything out of the preamps.
  • blueextc3221
  • blueextc3221
    How is it SET UP?? Is the subwoofer powered? is it running off speaker outputs? pre-amp outputs?
    we'll need more information to diagnose.
  • 15,935 Answers
See step 9 for turning the subwoofer output ON
HERE
Part of the original link i gave you to your online manual.
Thanks for using FixYa - a FixYa rating is appreciated!!
Posted on Feb 13, 2009
Trying to hook up a KLH sub woofer, S100ETH, PSW8-100 to a VCR reciever. Reciever has sub woofer connection but does not works on the KLH sub woofer. What is the problem ?
I suggest you go over your receiver set-up instructions. See if you need to set the receiver to acknolwedge the addition of the subwoofer. It should be in your receiver set-up steps. Just as a check, hook up one of your other speakers to the subwoofer lead to see if gets audio signal. I'm guessing the issue is your receiver settings.
Jan 06, 2015 | KLH Audio Players & Recorders
Power sub woofer is not working on my pioneer vsx-81txv everything is working all the speakers except the power sub connection at the back all i can hear is the hissing sound when i try to connect the sub...
Hissing? How loud? A sub isn't even capable of making high frequency sounds at normal volumes.
The Pioneer manual would tell you how to enable and test the subwoofer output.
Page 17 and the MACCV procedures on Page 33 (auto) or 43 (manual)
Jun 13, 2011 | Pioneer VSX-81TXV Receiver
I'm not sure how to hook up a powered sub woofer to my rx4109 reciever
It doesn't have a specific low-frequency or subwoofer output.
Depending on your unnamed subwoofer we may be able to work something out. Any sub should be able to work with a full-range Line Level feed.
If you use a Line Level input you won't have volume control of the sub through the receiver.
That would be available at either Tape Out or Aux Out. Just run an RCA pair (or combined to one male out if that's what the sub amp requires).
Whichever one you use, you won't be able to activate that function for listening as it would remove the input to the sub amp.
If your sub accepts speaker level High Level inputs you could drive it with speaker outputs and yoi WOULD have some volume control, assuming the sub had a way to match its initial volume to your other speakers.
Of course, the manual for your sub might explain some of this, too.
Jan 10, 2011 | Sherwood RX-4109
The sub-woofer output on the receiver is not working. I have tested the sub-woofer (speaker) and it works. And I have tested the cables and they work. The problem lies within the receiver. How can I fix...
I don't have the manual, but if YOU do, crack it open and find the part where you tell the receiver it HAS a subwoofer and any other settings that direct bass toward it.
Apr 18, 2010 | Sherwood RVD-8090R Receiver
Can I hook the reciever to mm bose subwoofer and 5
if bose unit has built in amplifier .Then your sherwood would have to have a variable RCA output jacks in order to work with sub.Then bose audio input RCA cable would connect there.If bose unit does not have built in amp .Then you would connect sherwood left/right speaker outputs into bose left/right inputs .Then other bose speakers will connect to bose unit
Jul 30, 2009 | Sherwood RX-4105 Receiver
Sherwood RD7502
Hi - You can download the manual by clicking the link underlined in blue below:
RD-6108
Your sub woofer needs to have it's own power amp i.e. a "powered" sub woofer:
Assuming your sub woofer is powered & connect as shown then check the following setting:
Let us know how you get on.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 06, 2008 | Sherwood RD-6108 Receiver
Connecting a sub-woofer to Pioneer VSX-453 surround reciever
I got the same issue. But, I go ahead hooked it up two banana plugs on teh VCR outlet. It works fine on my Cerwin Vega Sub.
Nov 08, 2007 | Pioneer VSX-453 Receiver
Sound problems through subwoofer
check all speakers wires andcheck test mode. every thing ok, may be input wiring problem ,check every thing after that internalcircuit may be problem..
Oct 08, 2007 | Audio Players & Recorders
Sherwood RD-6108 Receiver Logo
505 people viewed this question
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Josh Whitehead
Josh Whitehead
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
