Question about HP PAVILION A6230N DESKTOP PC
HP Pavillion freezes up on the HP Invent splash screen
When I boot the pc up I get the HP Invent splash screen and the pc
immediately freezes up, I can't hit f10 to get into the bios, I can't even
boot up off of cd, I've changed the hard drive, reset the CMOS to no
avail.
  • 2 more comments
  • carol_comeau Feb 13, 2009
    I reset the cmos by removing the battery then I tried replacing the battery, I can disconnect the hard drive and the system still never gets past the hp splash screen, I can reinstall the os because it never gets past the hp splash screen. I can't boot off of cd because it never gets past the spash screen. I have reseted the memory it made no difference, there are no beeps heard when booting up.
  • Anonymous Apr 29, 2009
    had the same issue I did what jonnyzero sugeested and that worked.
    Before that I pulled the battry to clear the CMOS, I tried diffrent hard drives, booting from cds, from a usb, nothing worked... then I opened up the computer and disconnected EVERYTHING, booted up, reconnected everything and presto it works..... was a fun day for me =/
  • Bob
    Bob May 11, 2010
    Could be a lot of things, so let's try to eliminate some. Did you hear any beeps when booting, and if so, how many? Did you have this problem before you changed the hard drive? If not, remove the hard drive and try to boot. It should take you past the splash screen and say something like "unable to find boot device" or similar words. If the computer lets you do that, you may have configured the hard drive incorrectly. Is the new drive an IDE (PATA) or a SATA drive? If a PATA drive, did you remember to use the correct the jumper setting on the drive? Also, how did you reset the CMOS if you couldn't get into the BIOS setup? Did you pull the CMOS battery? Try replacing the CMOS battery with a new one (use exact replacement) .
    Also, re-install the old hard drive to see if that lets you boot.
    Additionally, you may have jarred the memory sticks loose when you changed the hard drive. Check all of your other connections too, as you may have accidentally pulled something loose.
    There are a lot of other steps in troubleshooting this problem, but try these first.
  • Bob
    Bob May 11, 2010
    When did the computer last work OK? What led you to replace the hard drive? Is the new hard drive IDE or SATA? Was the old hard drive IDE or SATA? Do you still have the old hard drive, if so, can you re-install it and try to boot? Do you have a floppy drive? If so, have you tried to use a boot disk? Is _anything_ displayed besides the splash screen? A blinking cursor? Any numbers or letters? Are you using Windows Vista?
    Remove everything from the computer except the mouse, keyboard, and monitor including any media in the media card reader if you have one. Also, any cd's in the cd/dvd drive or floppies in the floppy drive if applicable. Then start the computer and hit F10 repeatedly. Does it let you go into BIOS after that? If no, re-boot and hit the F8 key repeatedly when it starts. Did it give you an option to enter safe mode?
    If none of that works, unplug the monitor (is it a flat panel?), let it set for a few minutes, then plug it back in, turn it on and start the computer.
    Are you using the onboard video connection, or do you have a separate video card? If so, remove it and re-seat it. Do you have access to a known to be good monitor? If so, try it.
    I know it's a lot of questions and things to do, but we have to try to eliminate all the possible problems. The next step is to start unplugging everything inside the computer but what's needed to start it...expansion cards, media reader, floppy,(if applicable) etc.
    If none of that works, we'll need to explore the possibility that the motherboard may have been zapped by static electricity.
    Also, if all else fails, try taking the computer apart and re-assemble it. Sometimes doing that makes things work.
  • 16 Answers
Don't throw out that computer or replace any components just yet.
After much trial-and-error, I finally figured out the solution for this common issue with certain HP Pavillion models. It turns out to be a design flaw with the front-panel memory card reader. Somehow the card reader's firmware gets scrambled, and it prevents the computer from booting. You can test this on your machine by temporarily disconnecting the card reader cable at the motherboard header. Voila - I'll bet you $1 that your computer will now boot!
The solution is buried deep inside this HP tech support document. The card reader firmware needs to be reset.
Here\'s how to fix it once and for all:
1) With the computer power unplugged (duh), open up the case & disconnect the card reader cable at the card reader itself - NOT the end that connects to the motherboard header. Make sure the cable end is not touching any metal components before proceeding to step 2 (another duh).
2) With the cable still disconnected, fire up the computer. The tech support doc says to let it boot into Windows and stay there for about 5 minutes.
3) Shut the computer down and reconnect the cable to the card reader.
4) Turn your computer back on - your memory card reader will work and, most importantly, the computer will no longer hang at POST!
I suspect that when you fire up the computer without the cable connected, the card reader is designed to reset its firmware by grounding out through the case - sort of like a CMOS Reset jumper on a motherboard.
I hope this solution is helpful to others.
best,
JohnB
Posted on Mar 23, 2009
  • 2 more comments
  • ridesahd Feb 04, 2011
    Thanks!!! Solved my problem!!!
  • sbrocali365
    sbrocali365 Mar 01, 2012
    who would have ever thought a front usb & or controller card that isn't even being used, could cause such a big problem... Thanks JohnB!
  • p_ausserdorf
    p_ausserdorf Jul 25, 2012
    planned obsolescence!
  • p_ausserdorf
Ok here is a stuoid solution that worked for me, after taking the desktop apart, peice by bleedin peice.....nothing was working..take out out then try..no good, pulled the 2 dvd drives, two hdd's, card reader floppy, ram etc etc...the last thing that was plugged in the back i tried was get this...the damn external hdd that i had plugged in last night and forgot to turn off..it was on and freezing the machine on the splash screen as described above...my advice is this...look for silly little things in the back plugged in before rippin apart your pc...lol
wow this one caught me off guard...lol
Posted on Oct 18, 2009
  • kdeez Sep 21, 2010
    Thanks myzermod - this worked for me!
  • 4 Answers
JonnyZero fixed my problem. I owe this man a dollar. Many thanks to you, sir.
Posted on Aug 12, 2010
  • 4 Answers
Thank you Jonnyzero the Master, it work 100% by disconnect the card reader cable
Posted on Jul 20, 2009
  • Cooperbiker7 Oct 17, 2010
    i tried all this and am still getting the blue screen on startup. Any other suggestions?
I had this same issue. It turns out all I had to do was remove the microSD card/adapter and restart the computer. For some reason it doesn't boot when there is something in the card reader :S
Posted on May 21, 2011
  • Richard A Jan 23, 2013
    I'm glad I found your post. I've had an SD card in my reader for a couple of months with no problem. Yesterday when I rebooted, it locked up at the HP splash screen. I've torn the entire computer down with no sucess, and then I found your post. Thanks!
  • 27 Answers
Did you try to reinstall the os either xp or vista? cus after the hp splash screen comes on thatswhen it starts to load the os.
Please rate my answer its much apreceted
Posted on Feb 13, 2009
  • Jason Suprenant Feb 13, 2009
    you can reinstall the os xp/ or vista by cd. you have to go into the bios and change the boot sequince to cr drive before hard drive and have the cd in there you can get into the bios by restarting and pressing either F1 F8 F10 all pcs are different some will tell you look on the screen when starting it might say bois F something and you only have about 2 seconds to hit it so you might have to restart it a few times to get into it. then when your in the bois you go to boot setup and change that once you do that look at bottom of the screen and it will tell you how to exit with saving then you system should start from the restore cd just when finished doing the install make sure you set the boot seq back to hdd first
    New Friend:
Found this fix and tried it. Awesome! My computer is back up and running!
Posted on Mar 16, 2016
I have problem with hp computer.when i start up my computer it appear difference screen that i shutdown last day i used it. so how can solve this problem .plz someone help me .
Posted on Sep 20, 2012
    Problem Solver:
  • 14 Answers
Open side panel remove cable from usb reader and others cd too i have not pulled all back in just in install new mother board same thing stuck no key board 1 blink/ f10 got setup ..... stuck . This may be a chip set driver not installed. or a bad hardware pulling to mush power. I change CPU, MEM sticks. Power supply all the same thing. Just pull these cable to hadrware not hdd. boot right up . BINGO> down 1yr.
Posted on Jan 07, 2012
  • bromberg
    bromberg Mar 11, 2014
    What if I just remove my USB thumb drives which I permanently leave in the USB ports for backing up my files? Will this have the same effect as disconnecting the cables as previously described?
    Problem Solver:
  • 17 Answers
This is the Bios start screen. Bios System can not Tell it what to do next. Lock up . ( Call hp you can ship it and we fix it. A new board. (NOT) I order a Bios chip about $10-15 us dollars Ebay. BINGO IT BACK UP AND RUNNING. Try a new chip beat it will fix it. Now that i up I going to pull ever thing OFF it place on 2nd hdd. So if i need to pull it i can use in any pc. Plus i going to get a smaller hdd to move the image to it (c) only will have window and reg. Place all install program to other hdd. I hit not be able to read disk from other pc. If fails hdd matches pc system. my system motherboard not listed . Bios Chip HP Pavilion A6500F NAPA-GL8E MCP73M02H1 but had this openBios Chip HP Pavilion A6500F NAPA-GL8E MCP73M01H1 same chip
Posted on Dec 11, 2010
4 Suggested Answers
rockitman187
  • 2559 Answers
SOURCE: HP Compaq dc7100 CMT: Impossible to enter BIOS
Try this,Remove the TPM and start computer,
TPM Card for dc7100
cae4c98.gifOn the desktop and workstation models, the connector is located under the drive bay on the right hand side of the computer. In order to recover the system you should remove the TPM module and re-install the OS.
Please rate this a fixya
Posted on Feb 11, 2009
sparky1500
  • 1066 Answers
SOURCE: Computer died - will not reboot - even to show system bios.
motherboard or cpu failure. or possibly power supply.
Posted on Dec 27, 2009
  • 11800 Answers
SOURCE: I installed an HP P450 motherboard, pulled from HP
That is the BIOS boot screen, it doesn't go beyond that because it can't load the OS. You can disable it if you don't want it but it won't fix your problem - you can't just attach a hard drive with an OS and it will work, it never does and Network Service Boot means that you already have a network server with the appropriate OS for your motherboard. You will have to install the OS on that motherboard on your local disk or, if you still wanna use the Network Service Boot, have an appropriate server on your network that when the PC boots, it sends an extended DHCP request, and your server responds by sending a bootable image to the PC via the network and the PC then boots from this image.
Posted on Apr 09, 2010
Testimonial: "Extremely helpful resolving my problem. I would have taken me much longer troubleshooting the issue on my own, so excellent support."
I have an hp pavillion dv6000, it cannot be accessed properly as it beeps continuously during start up (HP invent screen) and as i try to press ESC, it displays the windows error recovery. i tried choosing...
Check your keyboard for a key being stuck in the down position. Usually when you get that error sound you have a key stuck as though it has been pushed.
Aug 10, 2011 | Computers & Internet
Computer will not start screen comes on HP invent
Hi.
This is a problem with HP/Compaq wherew the motherboard "freezes".
Here's a way that might just "thaw" it out.
First, disconnect EVERYTHING from the computer EXCEPT for the keyboard and mouse and screen.
Unplug the computer.
Next, while unplugged, press and hold the power button for at LEAST 45 seconds.
This allows the bios to reset to an available state.
Then release the power button and then plug the computer in.
Boot up.
The computer should now boot normally.
This is known as a "soft reset".
Hopefully this works for you, as it has worked well for many others.
I hope I helped you out, and good luck !
Mar 13, 2011 | HP Pavilion a450n PC Desktop
Hp invent screen frozen
If the F8 key will not work upon turning this computer on the computer has a virus. A reboot CD will be needed which will correct this problem
Good Reboot disc can be purchased on Ebay from this seller.....
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=270517181851&ssPageName=STRK:MEWNX:IT
Ask for STEVE by name. He will respond quickly with questions pertaining your computer
I have purchased a Vista & a XP reboot disc from hime which did the trick. I had the same problem as you do
Jul 27, 2010 | HP Computers & Internet
My hp DV5 Pavillion Laptop keeps showing Hp invent on booting and when the hp screen appears the system hangs and never gets beyond it. Please what do i do as the Laptop is still very new slightly over a...
this is only bios issue..im sure 101% find the person who can update ur laptop bios with programmer ... no need open compelete laptop bios location is on the bottom ... if u need bios file i can send u .. this is my email sim4182@yahoo.com
Jun 20, 2010 | Computers & Internet
HP pavillion dv2700 clicking noise, black screen
try to run the hdd test in the bios page and see what it says. if it says no ide device found, try to reseat the hdd.
Apr 26, 2010 | HP Computers & Internet
HP Pavillion a1555a stuck on the blue HP Invent screen.
You have to uninstall the old graphics driver in Contol panel / add / remove programs rebbot the install new drivers.
Mar 05, 2010 | Video Game Consoles & Games
I have an HP Pavillion a1250n which has a MS-7184 V1.0 that will not boot. When turned on the HP Invent logo screen appears with thw following at the bottom:(Esc=Boot Menu)(F1=Setup)(F10=System...
It sounds as though you might have a problem with BIOS.
You should remove your motherboard battery (little round silver disc) and if you can find (or Google motherboard model#) the CMOS reset jumper, you can remove the battery for 30 seconds and put it back in and reset the CMOS, then see if it boots. If it doesn't, you might need to flash the BIOS, which is not recommended unless you know what you are doing.
Nov 16, 2009 | Intel Motherboard
HP Pavillion dv2500 laptop will not boot up.
Pressing the f8 key doesn't work either? This should boot the laptop to safe mode, if it doesn't then check the memory cards before you do anything else, try to get somebody with the same type of memory card to lend it to you. If that doesn't work, then your HDD is corrupted, and to re-install Windows.
Sep 05, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
My Hp Pavillion laptop dv2214tu doesnot boot beyond the HP INVENT logo page. I tried performing the Primary Hard Disk check as stated on the HP Support site but its not happening.I also reseated the RAM...
Unscrew your Laptop HardDrive bay and remove your harddisk first, then try to boot your system wthout the Harddisk inside. If it Boots past the HP Invent Logo Page, then your harddisk is the one that is faulty, if still doesnt, get another good, working RAM, apart from the one in your system, and use it to test your laptop...making sure that the harddisk is still not inside...then if it boots insert your Harddisk back with the new RAM, and restart your system.
If in the first case it boots (i.e wihout the harddisk inside)...then it means your harddrive is faulty, just retrieve your file on it and get a new one.
If in the second case it works (i.e with a new external RAM) then just change your RAM instead.
Jul 09, 2009 | HP Pavilion Notebook
My compaq laptop freezes after 30 minutes
It sounds like an overheating problem. When it is booted, does it run ok other than just being slow? Check your cooling fan and make sure it is running and not stopped up. That is a number one symtom of overheating is freezing and rebooting by itself. Have you expierenced that problem also? There is a free program called "Motherboard Monitor 5" that will monitor the temp for you and set off an alarm when it is getting to hot. Check that problem first. Hopes this helps!
Nov 27, 2007 | HP Compaq nx6110 PC Laptop
HP PAVILION A6230N DESKTOP PC Logo
13,214 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
