Question about Neff U1721 Double circotherm Electric Oven
Unable to release fan on Neff B1441 single oven
I need to replace the Fan/ electric motor on the above and I have removed the 10 mm nut in the centre of the fan inside the oven then removed the washer but the fan will not come away to enable me to remove the motor.
Could you please advise as to how i need to go about solving removing the fan.
I look forward to some expertise advise.
Regards
John
  • Neff Master
  • 3,463 Answers
It is probably baked on grease that is holding the fan on, if you have removed the center nut, then it should pull straight off.
Try spraying WD40 on it, grasping it with a pair of pliers or similar, and pull it towards you. it should come off, there is nothing else to hold it on.
Please rate my fixya solution.
Thanks.
Posted on Feb 13, 2009
I have a Neff double oven U1721NOGB/02. I need to replace the element in the bottom oven. It would seem the fan needs to be removed as part of this process but it isn't clear how to. How do you remove...
Remove the nut and the locking washer and then stop the spindle from turning ensuring that you don't damage the thread. Then spin the fan vigorously round and round back and forth whilst pulling fan towards you until it releases or detaches from the shaft, then pull off. If you're unable to turn the fan on the central spindle, try a little WD40 ensuring you burn it off by heating the oven afterwards. Reminder: ensure you don't damgae the thread..... Rgds Damian
Dec 02, 2010 | Neff U1721 Double circotherm Electric Oven
Tip
Common heating faults with Neff B1644 single oven
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Neff fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the NEFF element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your NEFF fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 19, 2010 | Neff B1644 Electric Single Oven
Tip
Common heating faults with Neff B1476 single oven
on Jan 19, 2010 | Neff B1476 Pyrolytic Stainless Steel...
Replace fan motor in an electric fan oven
1, If the fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
Jan 13, 2010 | Neff B1421 Electric Single Oven
Unable to remove the fan blade on the neff u1721 oven (too tight)
The nut is a left hand thread, so unscrew it clockwise to release it, hold fan blade as you are doing this. Tighten anti- clockwise.
Plz rate my solution.
Thanks.
Jan 11, 2009 | Neff U1721 Double circotherm Electric Oven
Tip
Common heating faults with Neff B1451 single oven
on Jan 19, 2010 | Neff B1451 Single circotherm plus Electric...
Tip
Common heating faults with Neff B1432 single oven
on Jan 19, 2010 | Neff B1432 Single circotherm plus Electric...
REMOVAL OF FAN
Ha - I found the solution myself. You need to remove the 3 screws securing the fan motor. Once you've done this, you can wiggle the fan a few mm, far enough to be able to remove the top element screw.
Jul 09, 2008 | Neff U1721 Double circotherm Electric Oven
Tip
Common heating faults with Neff B1641 Single electric oven
on Jan 19, 2010 | Neff B1641 Single circotherm super...
Tip
Common heating faults with Neff B1421 Electric Single Oven
on Jan 19, 2010 | Neff B1421 Electric Single Oven
Neff U1721 Double circotherm Electric Oven Logo
239 people viewed this question
Top Neff Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Samyfam
Samyfam
Are you a Neff Oven Expert? Answer questions, earn points and help others
