Question about Microsoft Windows XP Professional
Want to get rid of OS selection screen
I'm frustrated of having to select the operating system everytime I start my computer is there a way I can get rid of it also I want to be able to directly land to my desktop without having to login or click the username
  • 46 Answers
Do you have different operating systems installed, as well as windows, or just windows?
If you only have windows XP installed then you can modify the boot.ini file. Rather than explain it all here. I am inserting a link to a very detailed howto: http://vlaurie.com/computers2/Articles/bootini.htm
If you have Ubuntu installed you can change the settings from the grub bootloader in Linux.
You can change the way your computer logs you in by not setting a password under the user profile settings.
You can do this under control panel, users.
If you only have one computer on your network you can do this without any problems.
It however is not suggested you do so if you are going to be sharing, or accessing media from other computers on your home network.
Posted on Feb 13, 2009
    Scholar:
  • 75 Answers
Right Click MY COMPUTER > PROPERTIES >(click) ADVANCED > (Under startup and recovery click) SETTINGS > uncheck the option time to display the list of Operating System.
For automatic log in:
Click Start>run>type "control userpasswords2"(without quotes)> select the user name you prefer and uncheck the option that says "Users must enter a username and password to use this computer"
you will be required to provide the password for the selected username if you do not have a password leave it blank> click apply and ok
  • Microsoft Master
  • 4,806 Answers
Hi there.
First of all delete any passwords that protect the account and any users that you don't want (not your own)
Then, Right click on my computer and select "properties" tab, then you want the advanced tab and then "startup and recovery" tab and then the "edit" tab. You should see something like this >>>
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect
It should look like this so delete the second string and save:
[boot loader]
timeout=30
[operating systems]
Restart the PC and it should boot straight into windows
Good luck and thanks for using Fixya!!
How do i erase all my personal data on my mac mini?
That depends on what operating system you have. If it's 10.6.8 or older, you need the operating system install discs that came with your computer. Just put it in and restart the computer. When you here the start up chime, press and hold the C key to boot from disc. Then in the utilities bar on the top, select disk utility and then the top left hard drive icon in the side bar do the disk utility application. Go to the erase option on the right portion of the screen and make sure the erase option says MAC OS JOURNALED and click erase. That wil remove all data off of the hard drive including the operating system. After that is done, you can reinstall the OS with the disks.
if your OS is newer than 10.6.8, hold option after the apple start up chime, this will let you select bootable drives that the computer detects, there should be a recovery partion, select that and repeat the steps in disk utility I mentioned above.
Jul 10, 2014 | Apple Mac Mini Desktop
Internal error 000000b
What are you doing when this error happens ???...
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
Right click on the error message select properties you will see all details about the error
or click start type in event viewer press ENTER
this should give you some sort of understanding of the error and
you might be able work your way through the problem
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer.
As the computer is booting repeatadly press the F8 key as the computer is booting
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice
select the safe mode option
then run your antivirus if still cant get rid of the virus restart again
Use the up and down arrow keys to move the highlight to your choice.
select safe mode with networking download anti malware and microsoft security essentials
http://www.microsoft.com/en-us/download/virus-malware.aspx?q=virus
anti virus and malware
http://windows.microsoft.com/en-US/windows/products/security-essentials
If this fails you might have to go back into safe mode.
You might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System
Configuration utility Installation restore points that occur before you install a program or a service. You can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly.
This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8 until you fix your configuration issue.
Sep 07, 2013 | Computers & Internet
How to delete virus in my computer
Restart your computer into safe mode where the only things working are the mouse and keyboard allowing you an attempt to repair your computer
Reboot the computer As the computer is booting repeatadly press the F8 key as the computer is booting If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice select the safe mode option then run your antivirus if still cant get rid of the virus restart again Use the up and down arrow keys to move the highlight to your choice. select safe mode with networking download anti malware and microsoft security essentials http://www.microsoft.com/en-us/download/virus-malware.aspx?q=virus anti virus and malware http://windows.microsoft.com/en-US/windows/products/security-essentials if this fails you might have to go back into safe mode you might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue. other than that you might need to do a format and then re install your operating system Hope this helps.
Dec 27, 2012 | Computers & Internet
When i start the computer up, it always comes up with a screen saying: "windows boot manager choose an operating system to start, or press TAB to select a tool: windows 7 tools: windows memory diagno
Noramlly this happens only if u have 2 or more operating systems on your pc and this is helpful in that case.
Anyway if u wanna get rid of this, then download and install EasyBCD and open it.
Then go to "change settings" menu and set bootloader timeout to '0'.
Your problem should be solved, Additionally, you can check "add/remove entries" menu in EasyBCD and delete any entries other than windows 7.
Dec 25, 2012 | Acer Aspire 5742 Notebook
Operating system
You have not stated what type of problem you are having??..
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
Jan 19, 2012 | Compaq Computers & Internet
Hi i have one virus in my computer and he block my system and now i want to know if i can format my computer from command prompt but i type format c: and the computer tell me something about parttion can...
Why oo you want to format the C drive, you would not be able to do that. Why dont you try installing some antivirus and try to fix the virus.
In case you still want to format the hard drive and in the process remove the OS, you would need a bootable cd / DVD for the OS. You would need to start the process of re-installing the OS
First change the first boot device in the bios DVD, then insert the bootable CD in the CD Drive, restart the computer and follow the screen instructions, you would get an option to select new installation or repair the existing installation. Please select new install.
Then you would get he option to select the partition to install the OS. select the desired partition.
Then you would get the option to format the selected partition. select the disered option.
and follow the screen instruction an complete the installation.
Jun 27, 2010 | Computers & Internet
When i switch on a box comes on in centre of screen saying "an unhandled exception has occured in application"I cant remove it as it wont close (have to switch off at switch) new surfer!!!! A family tree...
DO NOT RE-FORMAT YOUR SYSTEM !
This is just a minor software bug thats all.
Try booting into safe mode.
Do this be repeatedly pressing F8 during switch on until you are offered boot options.
Select SAFE MODE.
Windows should continue to boot.
You will be offered a YES NO option just before windows opens up select YES.
You can try a system restore from here to an earlier point in time
Another option is from the boot options screen select LAST KNOWN CONFIGURATION THAT WORKED
Once you are in windows use add/remove programs to remove the family tree maker.
then restart.
after you have re-started go to the software website and see if there are any patches for family tree maker and download then to your hard drive.
re-install the software and then apply any patches without re-starting.
You should be OK from there
Oct 10, 2009 | Dell Microsoft Windows XP Home Edition
How do I get rid of this screen when I start up my Windows XP?
Ctrl+ F11 Pc restore option is not available on Dimension 3000 it was launched from Dimension 8400 model so you are not doing the right thing already. coming to the two os option there have been two entries createdin the boot.ini which is why you see two options please check which one works 1st or the second if you wanna get rid of this please do the following: Step 1: open my computer properties window start>my computer (right click) 7b978cb.gif
step 2: click advanced>settings under startup and recovery and uncheck the option time to display the list after selecting the appropriate os entry from the drop down.
Now if you could also clarify why you want to restore I cud give you the correct option to do so
Feb 11, 2009 | Dell Dimension 3000 PC Desktop
Error message for TI-84 Plus
Try and resolve this issue by re-installing the calculator's operating system using the TI OS Downloader. To do this, please follow the steps listed below. Be sure you have fresh batteries in your calculator.
1. Download the OS 2.43 file to your computer (preferably the desktop).
2. Open the TI OS Downloader by going to Start>>Programs>>TI Tools>>TI Connect>>TI OS Downloader. If you do not see TI OS Downloader, you may need to install the latest version of TI Connect. You can download a free copy from:
www.education.ti.com/downloadticonnect
3. From the main screen, select your calculator and cable type. Click "Next" to continue.
4. From this screen, locate the OS 2.43 file by clicking on the yellow browse folder and navigating to the location where you downloaded it. Double-click the OS 2.43 file to select it.
5. Remove one triple A battery from your TI-84 Plus. With the battery removed, press and hold the [DEL] key while you re-insert the battery.
6. You should see a "Waiting..." message on the screen of your calculator. If so, disconnect the USB cable from your computer, re-connect it and then click "Start Download". This should begin the OS transfer process.
Aug 19, 2008 | Texas Instruments TI-84 Plus Calculator
Everytime I turn on my computer. It would take to a black screen. Saying that to select on of the four modes to start windows xp. Either Safe mode with networking or command prompt. And to start windows...
first try using your boot disk for your current operating system and recover your system if that doesn't work you would need to install over your os but if u have any important files on your hard drive you would need to take out your hard drive and and place it in another pc to and save your files
Jul 27, 2008 | Compaq Computers & Internet
Microsoft Windows XP Professional Logo
467 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
