Question about Pioneer SD-643HD5 64" Rear Projection Television
HELP TO FIND IC's CONVERGENCE GENERIC NUMBERS
HI EVERYONE I NEED FIND THE PART NUMBER OR GENERIC # FOR PIONEER HD REAR PROJECTION TV MODEL SD-643HD5 ANY HELP WELCOME THANKS...
B40-756cp
Posted on Jan 09, 2008
  • 3 Answers
STK392-180 http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Posted on Sep 02, 2007
SOURCE:
Rns on and has picture. Picture is split into colors
The pioneer model listed here has two convergence chips and if one or both (should be both changed) have failed they need to be replaced. In customer menu select convergence and see if set will adjust or not first.
Oct 31, 2012 | Pioneer SD-643HD5 64" Rear Projection...
Convergence board cracked?
Once the board is cracked it is no longer repairable (even if it's a tiny crack that may not appear to interrupt any connections), and you would have to replace the complete board. Any attempt to repair or continue using a cracked board may cause more damage to the entire unit. You can find a replacement digital convergence board for a model # SD-643HD5 from this major Pioneer parts distributor at the following link:
Pioneer SD-643HD5 Replacement Part Digital Convergence Board
Feb 02, 2009 | Pioneer SD-643HD5 64" Rear Projection...
Where do i find convergence chips for a pioneer sd-643hd5
Complete convergence assy is available in Part Store for $126
Pioneer Parts has same CONVERGENCE ASSY for $288
Jan 25, 2009 | Pioneer SD-643HD5 64" Rear Projection...
Pioneer SD-643HD5 HD set up
Yes a simple cable will do it. Look for a converter designed to display a computer vga on an HDMI jack. I have one, and would expect it to work in reverse. My cable has a male VGA like a computer monitor cable.
Oct 22, 2008 | Pioneer SD-643HD5 64" Rear Projection...
Piomeer 643hd5
no sounds like either the vertical output IC needs resoldering or maybe defective. vertical IC will make the tubes shutdown for safety while audio and Crt heaters will remain on. Try resoldering the IC if that doesnt help replace the vertical output IC its an inexpensive part. If you need more assistance please let me know
Apr 10, 2008 | Pioneer SD-643HD5 64" Rear Projection...
Pioneer sd-643hd5
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Nov 03, 2007 | Pioneer SD-643HD5 64" Rear Projection...
Picture is green and stays green
check the convergence area for bad solder connection
Sony Convergence
Aug 19, 2007 | Pioneer SD-643HD5 64" Rear Projection...
Pioneer SD-643HD5 64" Rear Projection Television Logo
175 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
