Question about GE Spacemaker JVM1640SJ Microwave Oven
Starts on its own right after it finished prior task.
When it starts on its own, it flashes 3.5 on the screen. Only way I can control it is by unplugging. Sometimes when it's re-plugged, it will do the request; sometimes it will do nothing.
  • GE Master
  • 9,086 Answers
You have a shorting membrane keypad. If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and please do not leave it running unattended.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs.
But please note that for some models, the membrane keypad is not available as a separate part, so you would have to order the control panel frame which comes with a new keypad.
In this case, you simply move your circuit board into the new frame.
Feel free to reply back or contact us directly with your full model number and we can tell you if yours is one of these models, and if so, we'll also give you the part number you need to order and a link to the best priced supplier.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Feb 14, 2009
Fault flashing 8888 on a mc32f606tct
Pc board probkem, call technician
Sep 14, 2014 | Microwave Ovens
Kitchenaid microwave model KHMS155L, starts randomly for 3 minutes with "PAN" flashing on display screen, than locks up with "F-2" message on display screen
"F2" means you have a shorting membrane keypad. The "Pan Heat" key is shorting.
On these models, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job.
You can find helpful exploded view diagrams and order parts by entering your full model number* from the tag on the oven here.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors may have a lock:
* The exact part number you need will depend on your exact model number. Models in that series are shown below:
KHMS155LBL0
KHMS155LBL1
KHMS155LBL2
KHMS155LBL3
KHMS155LBT0
KHMS155LBT1
KHMS155LBT2
KHMS155LBT3
KHMS155LSS0
KHMS155LSS1
KHMS155LSS2
KHMS155LSS3
KHMS155LSS4
KHMS155LWH0
KHMS155LWH1
KHMS155LWH2
KHMS155LWH3
Dec 17, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Starts when closing door
This is a list of possible causes. 1. Defective triac or relay 2. controller is confused (pull power cord for a minute and see if it resets) 3.Defective controller or touchpad.
Mar 02, 2010 | Microwave Ovens
Starts constant beeping with F3 on the screen
I thought I was helping my daughter out by clenaing her kitchen, well the inside of her microwave was pretty bad and very hard to clean so I was a spray to loosen up the crusted on food. In doing so it started beeping and flashing F3 and now we can't get it to do anything. How do we saolve this?
Jul 17, 2009 | GE Microwave Ovens
I have a Sharp Carousel microwave model R438DV 1200 watts. There is a small 5x7 screen on the right side wall. It now has a small hole and has char marks on it. When I use the unit a fire starts o
You have to replace that small screen which is called wave guide. If there is a sharp authorised service centre near to your place you can buy the part from them. Do not work the oven without replacing that part.
May 29, 2009 | Microwave Ovens
Can't figure out how to defrost something.
> If for some reason you don't still have your manual, here are ways to get one:
Look at the model number tag and find the FCC ID number.
Enter the number (in two parts) as shown on the FCC ID page here:
https://www.fcc.gov/oet/ea/fccid
In the list of exhibits, look for the owner's manual. You can download it free.
If it's not there, you should be able to order it via the links on my part ordering page here:
http://www.microwavecontrol.com/parts.htm
- William E. Miller, AS-EET
pupista@gmail.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 16, 2017 | Sharp R-220BW Microwave Oven
Shuts off
change your electrical wall plug to a diffferent one, do not use extention wire pls, there is insufficient to drive your microwave, thats why it resets and restarts again
cheers
Nov 25, 2008 | GE JVM2070 Microwave Oven
Hi, I have a Sharps R-23 AM 1900W microwave. When i use it, it starts the timer and counts down for a few seconds then stops and flashes with 'err 3' on the display. Can you help at all with...
Is that code actually "EE3"?
If so, that is called a Magnetron (1) and (2) failure, but it may not be the magnetron.
It may be any of number of things, form door switches to control board relays to the high voltage parts.
Methodical troubleshooting is needed, and we have the manual for similar models here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Aug 01, 2008 | Sharp Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
