I have wireless speakers and the transmitter stopped working. Nothing happens when you plug it in--??? It's only a month old. AW872
  • 19,396 Answers
Hi I also post in here , so that you can let me know how it goes.
Try unplugging the transmitter from power adapter, if it also has batteries remove them. Also unplug transmitter audio cable.
Then remove batteries/unplug adapters from speakers.
Wait few minutes and reconnect the system.
This is a proper hard reset, and can fix minor problems.
If when you re connect the transmitter does not glow, or you do not have sound on one or both channels then there is a fault.
Check the transmitter audio cable, a short in there can cause troubles.
If you find no problems , then unit is defective, as it is under warranty contact Acoustic Research to validate the warranty here and get the transmitter or the whole set replaced.
http://www.acoustic-research.com/homedecor/HomeDecorInfo.do?ACTION_TYPE_ID=ACTION_TYPE_CONTACT_INFO
Posted on Feb 13, 2009
Connecting external speakers
If the speakers are wireless, wouln't the receiver connect to the speakers and some kind of transmitter connect to the TV?
Jan 20, 2013 | Samsung Hl-s5686w 56-inch Dlp Hdtv
Acoustic Research Model AW871 wireless sterio speakers
Your connection between the AR transmitter and the ONKYO receiver sounds solid. I'd guess it's the wireless speakers that are the wrong point, or at least that's what I'd look at first. Doing a bit of research, I noticed a couple minor points. First, these seem prone to RF interference from other RF devices. Have to tried switching channels on them? Second, someone reported theirs would not work properly unless the speakers were turned on just before the transmitter, and turned off shortly after the transmitter. Apparently you have to hold the button on the front in for 5 seconds to turn the speakers on or off. I know that's rather basic, but it's been a few days and no one else has responded, so I figured we should start somewhere.
Aug 27, 2007 | Audio Players & Recorders
Aw872 transmitter
sewing machines have speakers now?
Aug 29, 2012 | Sewing Machines
My rear wireless speaker from one side is making a loud noise.
the problem is the transmitter. it is generating undesired signal. in all wireless communications if the transmitting end creates oscillations other than which is desired - they are termed noises. ur receiver unit happens to pick up one of those noises and is able to amplify it. a qualified tech will be able to identify the frequency range and filter that out on the transmitter stage. if the warranty covers it- replace!
Mar 12, 2010 | Panasonic Audio Players & Recorders
Sharper image wireless speakers, model CT 413, were working fine. today, the blue transmitter light isn't on and nothing can seem to make it transmit. suggestions?
My speakers were working fine on my TV, I disconntect them, then when I re-connected the transmitter no signal is received and nothing is heard via the spearkers either.
Nov 25, 2009 | Audio Players & Recorders
AR Wirells Speak Transmitter Stopped Working
Hi there ,
Let me know if you did the steps below, then we can proceed form there:
Feb 18, 2009 | Acoustic Research 900MHz Wireless Stereo...
Wireless keyboard won't work
Check the cabling from transmitter unit to the back of your pc, unplug and plug the cable back in, perhaps to another USB port. When you do the connect button I have always down the transmitter first and then the device, like they keyboard or mouse. Make sure the batteries you used work. If you have another computer you could try it as a test.
Jan 17, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Wireless speakers AW872 transmitter won't power on anymore
Idhager,
I have the same set of speaker and had a similar problem. what I did was disconnent and reconnect the transceiver (sort of a reboot) and then powered everthing back up and that solved my problem.
Hope this helps
Dec 23, 2008 | Acoustic Research 900MHz Wireless Stereo...
Sharper Image Wireless transmitter deal
Do not restart them with the button, that won't reset settings, unplug everything from power for 5 minutes and plug them back.
Jul 19, 2008 | Audio Players & Recorders
Transmitter not working
You can 'pump up' the circuit on the transmitter by pumping the power connector in and out of of the back of the tranmitter to the beat of Beethoven's 5th: da duh duh duh, da duh duh duh, da Duh Duh.
It is a little awkward the first few times you try. You have to get the power connector in far enough each pump that the unit gets a pulse of power. It has to be pumped at the right pace, not too fast, not too slow, the beat of Beethoven's 5th is pretty quick and just right.
I have been powering our WSP155 transmitter unit on at work this way for several months. We originally had 4 sets of these, only using 1 transmitter at a time. 1 transmitter, 8 speakers. Over the course of a year or two, all of the tranmitters went bad the same way and now that I discovered how, I can make them all power on using this method, so I am pretty sure yours will power on this way too.
Nov 22, 2007 | RCA WSP155 Main / Stereo Speaker
152 people viewed this question
 Grubhead
Grubhead
