Question about RCA D52W19 52" Rear Projection Television
Replaced the Capacitors, Still have a Power Issue
After reviewing a few other solutions on this site I replaced three capacitors on the Flyback PCB of my RCA D52W17. I replaced cp150, cp114, and cp120. Two of which were obviously blown. The television powers up normally runs for 5 to 15 minutes and powers itself down again. I am looking for any other possible solutions. Please help.
  • RCA Master
  • 5,138 Answers
Resolder all the pinns on Flyback transfomer.
Posted on Feb 13, 2009
I have a 52" rear projection TV. D52w19b. Green
Make sure you resolder the flyback and recheck any RCA fuses that may be blown - they are usually near the flyback. If this does not help check the site www.tvrepairkits.com for repair kits or tips for your projection tv model.
Apr 27, 2013 | Televison & Video
Goodmans gtvl26w28hd picture very dull and fluttering badly
I had the same issue. Some other sites suggested the Inverter PCB could be faulty but I couldn't see anything obviously wrong with it. However, I did notice that there was only 19V coming in on the 24V supply to it. The 24V is supplied from the Power Supply PCB (the one where the mains supply comes in to). So the solution was to replace 2 x 680uF capacitors on the power supply board, located near the 24V output connector to the Inverter PCB. Visually, these two capacitors appeared to be 'bulging' which is a good indication that they are faulty.
Oct 10, 2011 | Televison & Video
I replaced the 4 capacitors on the DM board and got about 6 months out of my Mistubishi WS-55613 projection television. Now it is doing the same thing again with the blinking green light and no power. I...
For their cost it's probably worth trying to replace the capacitors again.
If there's space around the capacitors then I suggest you get high voltage rating i.e if the existing ones are 16V then get 25V.
Also worth checking for any other damaged components or scorch marks on the PCB.
Jun 17, 2011 | Mitsubishi WS-55613 55" Rear Projection...
TV was unplugged for a little while and now won't power up and is making a buzzing sound. What can cause this?
How old is the tv? This is a power supply symptom. You will need to take the back of the tv off and check for puffed capacitors on the power pcb. This is the board where the power cord plugs into. Lay tv face down on a cushioned surface large enough to support the tv frame. You do not want to damage the panel. Then remove the back. If there are puffed capacitors, replace them with equal or slightly higher valued capacitors. The value rating for capacitors are mf and voltage, printed on the capacitors. If they look good, you will need to check the dc voltage output from the pcb usually about three connectors in the same area. One way or another, it is a power supply problem, usually corrected by replacing caps, but if that doesn't work, you will need to replace power pcb
Apr 03, 2011 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
HI I HAVE A PANASONIC TV 32 IN WHEN I TURN IT ON IT GOES ON FOR FEW MINUTES AND GOES GREEN AND SWITCH IT SELF OFF
try to open the back of your tv. but be sure to unplug it. try to follow the ac cord of your tv that is your power supply part. you will see the capacitor try to find a swollen capacitors if you see a swollen capacitors replace it with the same type observe the marking of the capacitor the marked part of the capacitor is the negative. then try check also the main pcb. the power supply part up to the flyback area check if their is a weak solder parts.
Oct 17, 2010 | Panasonic Televison & Video
GE Tv, replaced flyback... still nothing.
Have you ck 3 capacitors on deflection board cp150 2200uf 16v, if it is bad other 2 caps are 220uf 35v cp114 cp120 Your TV is really a RCA
Sep 16, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
Replaced flyback a month ago and it worked fine. Now it the power light started blinking. Takes like 45 min to get it to come on. Whats wrong now
replace the power/deflection pcb which has the
flyback on it.go to encompass.com to see if
available or try shop jimmy parts.com.
Jul 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Switch on goes off switch on goes off switch on goes off then sta
replace the flyback # 259296 you can get the 259296 flyback replacement kit at the following link which contains the flyback and the CD with detailed instructions for the repair.
http://www.tvrepairworld.com/
Jul 14, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Thomson scenium doesn't start when we switch it on.
First, try to unplug and reset. Second, Remove back cover and check for shorted horizontal output transistor with ohmmeter. If shorted replace flyback. Next, carefully disconnect plug connectors from deflection pcb. No need to disconnect h.v. or screen leads. Remove from plastic frame and look at bottom (solder side) for cracks around pins of flyback transformer. Resolder all pins. Last, look for two or three bulging capacitors in power supply on same board and replace. Any of these things can cause a dead set. Good luck, Russmann.
Dec 11, 2008 | Thomson Televison & Video
RCA D52W19 52" Rear Projection Television Logo
251 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
