Question about Gateway 838GM (RB838GM) PC Desktop
Finding a cpu cooler replacement for motherboard with screwholes.
I need a CPU cooler that fits my cpu/motherboard! have a gateway 838gm with Intel (Augsburg) 915G motherboard, cpu is intel P4 630, socket LGA775, 4 pin connector for cpu fan..  recently, my cpu fan died and i want to replace. my motherboard has screwholes for the original cpu cooler. seems that most cpu coolers available are just for motherboards with holes. the original maker of the cooler is Taisol. have not gotten help from them.  Anyone have this problem with a solution?
  • 565 Answers
You should be able to purchase a cooler that fits your existing cooler plate.
Replacing a cooler can sometimes be a lot of work. Sometimes you have to remove the motherboard from the case and remove the cooler plate from the underside of the motherboard. Then coolers that use "just the holes" can be used. Or another (different) cooler plate can be installed that may have came with your new cooler. In my experience, the coolers that use "just the holes" (no plate) leave a lot to be desired. Plus, if you're not careful, you can damage the motherboard by applying too much force when installing the fan. If you use a new plate, don't forget to install the insulator between the motherboard and the plate, if it comes with one.
Be careful to protect against unwanted electrostatic discharge. Always touch the metal computer case before touching any parts inside the computer. Also, if you remove the mobo, take careful note of where all the wires go before disassembly.
Posted on Feb 13, 2009
  • Bob
    Bob Feb 14, 2009
    Is this what you are looking for?:
    http://cgi.ebay.com.au/(NEW)-TAISOL-INTE...
  • Bob
    Bob Feb 21, 2009
    Thanks for the negative feedback and taking the time to vote.
    BobB
I need to know how much main memory that supports my motherboard.
According to Intel:
(DIMM) sockets
• 800/667 MHz single or dual channel DDR2 SDRAM interface
• Support for up to 8 GB of system memory
Nov 10, 2012 | Intel Gateway E210882 Motherboard With...
Need to find witch motherboard fits gateway computor M-6843
http://support.gateway.com/s/Mobile/2008/Avalon/1015608R/1015608Rnv.shtml
Click on Components in the list.
Scroll down to -
Motherboard:
4006229R - Motherboard GM965 Chipset Intel Video W/10/100LAN No HDMI (FRU)
Click on the above.
Main View
Specifications
http://www.buy.com/prod/gateway-4006229r-gateway-m-6750-m-6755-m-6834-m-6823a-m-6846/209257968.html
http://www.codemicro.com/store/product/Gateway-4006229R-New.php
http://www.ebay.com/itm/Gateway-M-6750-Motherboard-31SA1MB0030-DA0SA1MB6E0-IS-read-carefully-/261119779234?_trksid=p2047675.m1850&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D11%26meid%3D3052480971542613513%26pid%3D100011%26prg%3D1005%26rk%3D2%26sd%3D270875445041%26
Just from some quick searches. Note that -
31SA1MB0030 is also another reference number.
May I ask what the problem is?
Power problem?
Do you have decent soldering/un-soldering skills?
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 27, 2012 | Computers & Internet
Am I able to to upgrade the original cpu that came with the pc? And or mother board? Intel Pentium D cpu 2.80ghz 32 bit os
Hi . you should check with intel web site as to what you can upgrade to , it has to be the right cpu other wise your system will not work , so check with intel and let me know if this helps you , if not i will research it myself....................Roy
Jul 20, 2011 | Gateway GT5040 PC Desktop
We have a desktop computer((Model: GATEWAY 838GM) misplace the ADAPTER for the CPU which one to get please thanks
sallyduby we may have some confusion here.
CPU = Central Processing Unit. Another term used is Microprocessor, or simply Processor for short.
CPU does not refer to a Personal Computer. At least not since the 1960's, and not unless you wish to confuse someone with the wrong reference. ;)
This is Gateway Support > Gateway 838GM Desktop PC > Main Support page,
http://support.gateway.com/s/PC/R/5389/5389nv.shtml
In the list click on Components.
A) There is no adapter device for the CD drive, or DVD drive, unless this is a mistaken reference to the flat ribbon data cable
B) There is no adapter device for the Harddrive, unless this is a mistaken reference to the SATA data cable that connects the SATA harddrive to the motherboard.
C) There IS possibly an adapter for the Keyboard, if you are using a Keyboard with a USB connector on the end of the cable, and are not using the original Keyboard that has a PS/2 connector.
Example;
http://www.directron.com/freeusbps2.html
D) There is no adapter for the Media Card Reader, unless this is a mistaken reference to the data cable that connects the Media Card Reader to the motherboard.
E) There are no adapters for the Ram Memory module/s.
F) There are no adapters for the Modem. The Modem plugs straight into the motherboard.
G) There are no adapters for the Motherboard, unless a USB mouse, or again a USB keyboard, is being used.
The same style of adapter for the USB Keyboard will also work for a USB mouse.
H) There is no adapter for the Power Supply, unless this is a reference to a power cable adapter that could go to a computer case fan, from a 4-pin standard Peripheral power cable.
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
(The 4-pin standard Peripheral power cable, and it's connector, are shown in the middle photo.
The Harddrive example/s shown is an IDE {PATA} harddrive. This style of Harddrive uses a 4-pin standard Peripheral power cable)
I) There is no adapter for the Intel Pentium 4 CPU {Processor} (3.0GHz, 800MHz FSB)
The motherboard has an LGA 775 processor socket.
The Processor has the socket holes, while the processor socket has the pins.
775 socket holes, 775 pins.
http://en.wikipedia.org/wiki/LGA_775
Unless this is a mistaken reference to the Fan/Heatsink combo that sits on top of the CPU.
Typical Fan/Heatsink combo example of Processors (CPU's) using an LGA 775 processor socket,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2943299&CatId=493
(Except the Gateway version is square)
J) No adapter for the Speakers unless I am mistaken.
Post back in a Comment, and give at least a general description of the adapter you are referencing to.
Regards,
joecoolvette
Dec 12, 2010 | Gateway 838GM (RB838GM) PC Desktop
System.hardware.vendor = 'Packard Bell NEC' system.hardware.product = '00000000000000000000000' system.hardware.version = 'PB13109001' system.chassis.manufacturer = 'NEC COMPUTERS...
you need a new CPU cooler and the part you will be needing is called 'CPU COOLER". Go to any computer accessories shop/store within your vicinity and purchase another CPU cooler. You will need to remove the one from your motherboard and use it as a sample to get another one so that you can get exact size of cooler that will fit your CPU because CPU coolers varies in size and shape.
Good luck.
Aug 03, 2010 | Computers & Internet
Car won't start when hot. only starts in morning when cool. is this the icm?
Sounds like the CPU HSF is loose or has stopped
The HSF.. heat sink and fan needs to be running or the motherboard sensors will just shut the computer down.
This board in an intel LGA775 and uses this type of CPU cooler
http://www.aria.co.uk/Products/Components/Fans%2C+Heatsinks%2C+Coolers/CPU+Coolers/?x=12&p_order=price_asc&p=cF9zdHlsZT1kZXRhaWwmcF9wcm9kdWN0c1BlclBhZ2U9Jg==
You can get a new 1 for under £10 and they are not to hard to fit
Jul 10, 2010 | Intel D945GCCR Motherboard
Gateway 838GM will not turn on even after installing new power supply. It was on and began making a loud noise and just quit.
Did you test the old power supply? If not, noise could have come from CPU fan. In either case, problem is most likely main board and/or CPU. Try removing all plugin components except CPU and heat sink and see if you get any signs of life.
Aug 03, 2009 | Gateway 838GM (RB838GM) PC Desktop
I need to know the size cpu fan for gateway 838gm. Can't find anywhere on the internet
You have a 3GHz intel processor socket #775.
here is a great place to purchase: Also this page (link below) contains several products - see what you think
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=50002177%2040000574%201371026035&name=LGA775&SpeTabStoreType=0&ActiveSearchResult=True
Hope this helps, please leave rating
May 07, 2009 | Gateway 838GM (RB838GM) PC Desktop
I need a cpu fan what size does it take
It goes by which socket you have. I am an Intel connoisseur so my knowledge ends with Intel PCs.
If your processor is an early Intel Pentium 4, you will want a socket 478 CPU cooler.
If your processor is a late Intel Pentium 4 or Intel Core 2 Duo/Quad (~2ghz+) you will want a socket 775 CPU cooler. Luckily this socket is still in wide use and many can be found locally or online.
If your processor is an Intel Core i7, you will want a socket 1366 cooler.
Just go to a local PC store and ask for an LGA478, LGA775, or LGA1366 CPU heatsink.
Apr 11, 2009 | Gateway GP PC Desktop
How to change
Hi
Replacing the heatsink fan on a PC is not a difficult job, but it pays to be thorough, especially with cleaning the top of the CPU die before replacing the fan.
Don't be mean with money when choosing a new cooler either. With CPU coolers you get what you pay for. I personally always use coolers from a company called Zalman.
Ok ..with that out of the way ..the basics are ...remove old cooler..
They are either held on by a sprung clip that fits across the cooler and locates in lugs on the cpu socket surround, or they are held by screws that go through the motherboard.
Clean the top face of the cpu die carefully making sure to use a blunt implement ..... scratches on the machined face will lead to premature failure due to overheating.
If the cooler you buy has a "thermal pad" stuck to the face of the heatsink, then remove this too and clean up the heatsink face. Use good quality thermal paste on the top face of the CPU die, then fit the new cooler. Getting the right amount of thermal paste is a bit of an art .... too much is a bad as too little. The paste is NOT a glue. The paste simply fills in any imperfections on the machined surfaces of the cpu die and the heatsink to aid heat transfer.
Does this sound complicated? It isn't really. The key is not to rush it and make sure the surfaces are completley clean and the thermal paste applied correctly.
Here is a link to one tutorial on fitting cpu coolers that you might find useful:
http://www.jsyte.com/tutorials/replacehsf
Oct 31, 2008 | Intel Socket 478 CPU COLLING FAN & HEAT...
Computers & Internet Logo
653 people viewed this question
Top Gateway Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
