Question about Dell 1600n All-In-One Laser Printer
I get a "no paper" when there is plenty of paper in printer
The error message was intermittent and would resolve if I shut off the computer and printer and restarted both. Sometimes it would copy but not print. After a number of copies the problem went away for a while. Now it is back again.
There is a little white tab on the left hand side of the papper tray. If it dose not pop up the papper when the tray is closed, you will get a papper error,.
Posted on Mar 24, 2009
I have a cannon image class MF6540. When I try and print I get an error "out of paper". I have plently of paper. I am able to copy but not print.
I assume you are trying to print from your computer.
The driver for this unit will give you an out of paper message almost any time it won't print for any reason.
If the unit copies, but does not print from your computer, then it is a communication issue. Perhaps uninstall/reinstall the driver?
Mar 24, 2014 | Canon ImageClass MF6540 Copier
Code3825
Error: Printer Error (3825) Published 04/17/2012 04:30 PM ' Updated 05/30/2012 11:48 AM ' Answer ID 46577
How do I resolve the error message "Printer Error" (code 3825) on my all-in-one printer? To resolve the error:
  1. Remove all paper from the paper tray(s).
  2. Disconnect the power cord from the printer.
  3. Wait 5 seconds, then reconnect the power cord.
  4. Reload paper in the paper tray(s).
  5. Try printing again.
Mar 12, 2014 | Office Equipment & Supplies
I'm getting a service error 02 in a printer oki b6100. How do I solve this problem?
The OKI B6100n Laser printer is a unique printer. These Error messages are to enable you detect the fault and resolve it if you can and the once you cant it resolve,u call the repairman.
The Service Error 02 means that there is a paper jam inside the printer and the only way to resolve it is to remove the paper from the indicated location on the printer.
You can also check the user manual on the CD ROM of the printer for more information and how to correct similar error messages on the printer.
Thank you.
Sep 12, 2011 | OKI B6100n Laser Printer
My paper won't load - it pulls in about 1/4 of the sheet and then stops. I'm getting error code E3 and have checked for a jam but see and feel nothing. I've also used alcohol to clean the...
This is a paper jam error. Unplug your computer from the AC outlet and from the computer, next place the printer on a table or anywhere that you can get access all panels and the paper tray easily. Remove the paper tray and look for any pieces of paper that may be stuck in the printer. Look also around the back as there is usually a panel that can be removed without any tools.and check there. Also open the printer as if you were going to change the ink and look around there. Make sure you have plenty of lighting or a flashlight as even the tiniest piece of paper can trigger this error message.
Hope this helps.
Jul 17, 2011 | Canon PIXMA MP240 All-In-One InkJet...
I can not get it to print anything from my computer. When I do the status says error. It had said out of paper even though there was plenty of paper in the tray. I reinstalled it, shut it down ... got rid...
Try this...
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00786157&cc=us&lc=en&dlc=en&product=421991
I think that the key instruction is the one about cleaning the rollers inside the printer - accessed from the back of the printer. They aren't the wheels visible just inside the rear of the printer, you're looking for a wheel or set of wheels farther inside that rest on the input tray.
Sep 14, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Error 1200. i have tried to resolve using the steps in the manual. No luck The model is Lexmark 4720 Maltifunction printer
I managed to fix the problem. Error 1200
Checked for paper jam, no luck
Unplugged the USB connection and from the wall socket, no luck
Took the cartridge out and reloaded them again, no luck
Switched the whole computer off and then logged in back again, no luck.
Uninstalled the software.
Installed the software, driver, message "computer cannot communicate to the printer", but the scanner, fax and copy started working.
Deleted all pending jobs
Shut down the computer then logged in again.
Bingo, the printer started working.
Hope this helps
regards,
Tara
Sep 26, 2008 | Lexmark X4270 All-In-One InkJet Printer
Adding paper
I had this problem, try half filling the paper holder and move the slider tight against the paper. This worked for me.
Aug 29, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Hp psc 1219
dear szaszy
as per your information your printer paper jam sensor is having problem.Please get it serviced
Apr 04, 2008 | Office Equipment & Supplies
My printer
sounds quite compelling
Mar 08, 2008 | Epson Stylus C60 InkJet Printer
Hp psc 1219
try pressing repeatitivly the red cancel button
Apr 16, 2007 | HP PSC 1210v All-In-One InkJet Printer
Dell 1600n All-In-One Laser Printer Logo
102 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
