Question about GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator not keeping cool
My GE refrigerator model TPS24BP is no longer cooling well enough.
The freezer is working but both sides are not consistently holding the correct temperature.
Your coils could be clogged with debris. i had the same problem. You can go to home depot and get a specific brush that you can use to clean out the coils. They are either behind the fridge, or under the fridge. Do it on a regular basis, cause that can cause the compressor to burn out. I am not an expert, but that worked for me
Posted on Feb 13, 2009
I have a GE side by side refrigerator bought in 2003. The freezer is not cooling enough and the ice creams have melted. The fridge is not cooling much but it is cooling enough to maintain the stuff in it....
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 03, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
FREEZER AND REFRIGERATOR NO LONGER COOLING (GE MODEL GSS25XSRDSS)
Not enough info. If the unit is totally dead then I would suspect the main board (in the rear under a panel) if the fans are running I would suspect the compressor is not running.
Oct 16, 2010 | GE GSS25XSRSS 36" 25.4 Cu. Ft....
Freezer not cooling, fan blowing, fridge also not
If there is no frost , on the inside rear freezer wall ,
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter .
If there is frost , reply back with complete model number .
Nov 08, 2009 | GE PSS25MGN Side by Side Refrigerator
Refrigerator not cooling, freezer is working.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
fdite
Oct 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Evap fan stops running/low cooling, Unplug Frig Evap fan runs
Is there anything obstructing the fan area, ice build up ? It is normal for your freezer to get warm if evap fan is not working, it is essential for it to work :) A defrost cycle should kick on a timer or as needed (adaptive) and there should not be excessive frost buildup that it blocks your evap fan. I would have suggested you unplug your refrigerator for about 10 minutes and see if that resets your control board - if not, then you will need service - either replacing motor assembly or a faulty control board.
Aug 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer working but not colder enough to freeze.
It will usually take 24 hours for the fridge/freezer to adjust fully to the temperature settings.
It is also possible that the defrost timer cycle was going into or just coming out of the defrost cycle, thus it could have delayed the start of the cooling cycle, so give it a little time to determine if the freezer is working.
If, not freezing after 24 hours, let us know and we'll go from there.
It takes longer for an empty freezer to get and hold temperatures, so it is always a good idea to have the freezer loaded with bread (thirft store bargains are cheap) or jugs of 3/4 full water (water takes longer to freeze than bread thou).
Hope you find this very helpful and best regards!
Aug 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Turbo cool will not turn off in GE side-by-side refrigerator. Replaced circuit board...still stays on
There are three temp sensors in my GE side-by-side model GSS20IEMDWW (two in the freezer and one in the fresh food side). Replacing the temp sensor in the fresh food side was enough to allow the compressor to finally turn off.
For me, the problem manifested with an iced-over evaporator coil inside the freezer compartment. Since the compressor never cycled off (presumably because the temp sensor was providing faulty data about the temp inside the fresh food side, thus causing it to continually attempt to cool), the coils were constantly chilled. Eventually the ice on the coils would block the air flow and the freezer side could no longer freeze
I purchased a pair of inexpensive thermometers from a kitchen store and put one in the freeze and one in the fresh food side so I could occasionally look at the temps to see if it made sense for the compressor to be running - ie, was it really a warm-enough temp for cooling to be required, or was the computer reading faulty sensor data.
Six months later I also needed to replace both temp sensors in the freezer compartment. My refrigerator is about seven years old. I would recommend replacing all of the temp sensors just to rule that out.
http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=GSS20IEMDWW&mfgModelNum=&fkMfgID=2
Your model may be different, but this will give you an idea of part numbers and relative locations of the parts.
Jul 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side fridge not cooling enough Freezer side was still
check see if you have frost build up in the freezer back wall you may have defrost problem
Apr 06, 2009 | GE Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
280 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
