Question about Sony KDS-R60XBR1 60" Projection HDTV
Replacing the exhaust fan on a KDS-R60XBR1
Red blinking light 4 times no picture.
  • 10,594 Answers
4 times blink shows problem of fans not running or connector of fan is not attached properly.
Please recheck the things what you removed during fan replacement and make sure all that is mounted and connected securely.
Posted on Feb 13, 2009
I had this same problem, but I unplugged the TV from the surge protector, waited 60 seconds, and plugged it back into the surge protector, and the TV powered up normally.
Posted on May 02, 2009
SOURCE:
Red standby blinkig light 4 time on a sony 60 in wega
4 Blink 9 out of 10 times is your lamp fan. Check and make sure it clean and free of debrey. Spin it and see if there is any grinding noise. If after you clean and reassemble and the set still shuts down, either replace the lamp fan or check your outher 3 fans as well.
Apr 26, 2012 | Sony KDS-R60XBR1 60" Projection HDTV
What do i do if my sony sxrd power light starts blinking red
Red led blinks 4 times is an error code that shows that fan is not running in tv, check fans connections and make sure all are plugged properly
Jun 17, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
Sony tv red light blink 4 times on 60" WEGA
When your red light blinks four times on the Sony KDS-R60XBR1 60 inch HDTV, this is an error code for a stopped up fan. You will need to check the ASU board to verify Fan1-4 power to the fan is supplied, next check the fan connector to make sure it is properly connected, and finally make sure the fan is not caught in the wires or harness.
Feb 27, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
The red indicator light blinks 4 times no sound or picture
this is the error for a stoped fan... feel to check to see if fan is blowing. it might be clogged. the fan might have failed. MY motto when it comes to motors is "anything that moves eventally stops someday" cooling fans are relatively inexpensive and easy to replace.
Nov 09, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
Red light blinking 5 times. is a fan problem on a sony KDS-R60XBR1
here are the fans you need are you sure this is the problem
http://www.discount-merchant.com/SONY-Cooling-Fan-Set-Cooling-Fan-Set-p/1158984.htm
Sep 15, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
Had Blinking RED blinking lights. FIXED
CHECK LAMP COVER, CLOSE IT AGAIN THE RIGHT WAY
Feb 21, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
KDS R60XBR1 Red Light blinks 3 times when turning
on my xbr tv there is a little *** that sticks out on the lamp cover. the wrapped and it wont work light flashed 3 time with a new cover it worked fine. there was a t. s. b. for an over heat problem new fan and sensor and door. go to sony.com its there
Mar 22, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
KDS-R60XBR1 60" SXRD HDTV
I had the same problem if it is blinking 4 times like I think it is... it is a problem with one of the fans (there are 4) in your TV.. It is a simple fix... try using an air canister to clean them. It will require some disassembly though.
Sep 12, 2007 | Sony KDS-R60XBR1 60" Projection HDTV
Sony KDS-R60XBR1 60" Projection HDTV Logo
1,617 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
