Question about RCA D52W19 52" Rear Projection Television
RCA DLP TV with a red dot in the middle of the screen
I got a flash of green light when I powered the tv on. I turned it off for a minute and when I turned it back on I had a good picture but only green color. I turned it back off and left it off for a few minute and when it was turned back on I had a good picuture and color but now there is a red dot in the middle of the screen. I've ran through all the diags I can find in the menu and all seem to pass ok. It's been this way for a couple of weeks now.
    Novelist:
  • 184 Answers
Sounds like the color wheel stopped and re-started. It may continue to function for a while, but could fail at any time.
I've also seen on rare occasion, a defect in a lamp produce uneven color rendition, but its far more likely that the culprit is the color wheel.
michtech
Posted on Feb 13, 2009
Got a Samsung dnie model code spp4251x/data tv when powering up the front light comes on but no picture or anything anyone got some good info??
tv seems to turn on but no picture? - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - ... Samsung Dlp TV (HLR-5067W) it seems like the TV turns on butthere is no picture. ... the lamp is, light is visible from where the lamp is located but no picture. DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
The timer, lamp, and standby/temp. light are flashing?!
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...I Have A Sanyo TV I Can Hear But Black Screen Im 14 And Dont Know What To Do ! .... power button the power light goes from red to green, the screen flashes on then goes black ....Troubleshooting LCD Backlight Failure Samsung LNT-4066 ...
Samsung plasma tv repair blinking light no picture ...
Jan 09, 2016 | Samsung Televison & Video
RCA rear projection tv picture bowed to middle. Red Green Blue colors have been seperated on screen.
If I had to guess I would say it's either the DLP chip or the prism. Simply put the lamp lights the DLP chip which directs the light into a prism and then onto the TV screen. The prism or prisms are responsible for aligning the colors correctly. The DLP chip is essentially a million little moving mirrors which direct light
If you're at all comfortable with electronics you might want to open the TV up to take a look. You might get lucky and find something obviously wrong with the TV. Sometimes adhesives melt and parts slip out of place. If your DLP chip is blown there isn't much you can do. You're probably right that this would cost a lot to fix and not be worth it.
Jul 24, 2012 | RCA Televison & Video
Hello, why does my plasma tv have thousands of red and green flashing dots all over the dark parts of screen after it has been on for roughly half an hour? if i turn tv off for a while then turn back on...
I had a similar problem but mine was just red specks that showed up in dark scenes. I opened up my plasma and found the adjustment pots that are labeled Vsc, Vy. I then marked the factory default with a sharpie first. Then I lowered the Vy a little and my red specks disappeared. Now my tv looks awsome again like it was new.
May 10, 2010 | Samsung DLP HL-P5663W 56" TV
I have a philips dlp 55pl9773 has one red flashing led on the front when i do a hard reset tv boots up lamps lites led goes from flashing yellow to green for about ten seconds and then back to red flashing...
MY philips tv model number 55PL9773/17 WAS TURNING OFF THE SCREEN AND LEAVING THE AUDIO ON FOR ONE MINUTE. THEN THE YELLOW LIGHT STAYED ON. THEN THE LIGHT TURNED OFF. thEN I TURNED ON WITH THE REMOTE AND THE YELLOW LIGHT TURNED ON AND A FEW SECONDS LATER CHANGED TO THE GREEN LIGHT AND THE TV TURNED ON. AFTER A FEW MINUTES, BETWEEN 10 AND 30 IT DID THE SAME THING. NOW IT IS OFF WITH A BLINKING RED LIGHT PERMANENTLY ON. TO TURN IT OFF I HAVE TO UNPLUG IT FROM THE WALL. I REPLACE THE LAMP A FEW WEEKS AGO AND IT IS FINE.
Dec 01, 2009 | Philips 55PL9773 55" Rear Projection...
Samsung HLR6178W Rear projection. Continues to turn off after 5-10 minutes- Front power button flashing Red & Green lights. When on there are two vertical bands one on each side of middle screen.
Your Model number says that this TV is DLP and not rear Projection Go to website Encompass Electronics they have everything you need for repair or Call 1-800-638-3328
Oct 05, 2009 | Samsung HLR6178W 61" HDTV
RCA 32V434T Flashing Red Light
Flashing led..in protect mode..internal shorted component.
Aug 14, 2008 | RCA F32450 32" TV
Toshiba dlp 46 inch red light keeps blinking
42 inch Toshiba DLP. Was watching a movie and the screen went dark. The red light started to flash and kept flashing. any ideas
Jun 26, 2008 | Toshiba 46H84 46" Rear Projection...
RCA D52W19 52" Rear Projection Television Logo
169 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
