Question about HP OfficeJet J4580 All-In-One Laser Printer
Not faxing Hello, a new hp 4580 all in one not faxing or receivng fax, the image is off, how do i turn the image on, i believe this is the problem because the connection is fine it's just not excepting or receiving anything. and this is the error that shows ont he confirmation receipt. thanks RG
  • dc_native Apr 27, 2009
    I have been able to send faxes in the past but today, I got that same message. Any suggestions?
  • 27 Answers
Is there a phone on the fax can you hear a dial tone? if there is no phone plug one in to that phone jack and see. it could be the problem.
please rate my answer it is much apreceated
Posted on Feb 13, 2009
Hi, My fax machine is plugged in and set up, but it won't answer the phone to receive the fax. It's a HPj4580 officejet all in one. Thanks for any help you can offer.
I'm a phone/data field service tech so all I can tell you is the most common things I've found on service calls (please do not be insulted).Plus I have a 4580 myself. 1st I unplug the phone cord at the back of the fax and plug that end into a working single line phone and check for dial tone and does it ring if I call the number.yes? then go to fax settings: rings to answer - 2, then auto answer - on. also if your using the "fax to pc" option turn off your pc ... just for test purposes. see if any of that helps at all.
phonmancps
Dec 15, 2010 | HP OfficeJet J4580 All-In-One Laser...
Receivng a fax and printing pages has vertical
Its ether the toner cartridge or the fuser. send one page to the printer and open the cover when the page is under the cartridge. Pull the cartridge out and look at the page. If you can see the line its the cartridge if not its the fuser. I think its the cartridge. Thank you, Steven 805-520-3003
Jul 07, 2010 | HP LaserJet M3027 MFP Printer
Hp officejet 6310 all-in-one send fax configure
1. Press Setup on the front panel of the All-in-One.
2. Press 2 to enter in to Print Report.
3. Press 1 to enter in to Fax Confirmation.
4. Press 1 to turn on Fax confirmation
5. Press 2 to enter in to Image on Fax Send Report
6. Press 1 to turn on Image on Fax Send Report
Jun 03, 2009 | HP Officejet 6310 All-In-One InkJet...
Oki 4580 fax machine "change drum soon" shown on the display, still says "change drum soon" even after it has been changed any ideas
DEAR JUST PRESS FOLLOWING KEYS
  1. SELET FUCATION
  2. PRESS OT KEY NO.7
  3. THEN PRESS YES KEY
  4. PRESS OK
  5. STOP TWICE
REGARDS
KHAWAJA
SGA66@HOTMAIL.COM
Apr 28, 2009 | OKIFAX 4580 Plain Paper LED Fax
Panasonic Panafax UF-550 not receivng faxes
Check your line for static, should sound a clear tone. 95% of communication problems are related to line quality (phone company fix this). The other 5% is the modem PCB of the fax machine
Feb 12, 2009 | Panasonic Panafax UF-550 Plain Paper Laser...
Okifax 4580 oki "change drum soon"
1st replace drum if needs to!than press select function button!counter button,new drum reset select yes than start button should reset!
Jun 17, 2008 | OKIFAX 4580 Plain Paper LED Fax
Oki Fax 4580 problem
Does this happen when you perform a test print such as an activity report or config page? if it does you may have a transfer roller issue. The transfer roller is the long black spongy roller directly under the drum, the metal rod in the roller conducts a charge that interacts with the drum. If the roller is dirty (usually chocked up with toner) the necessary charge is diminished and the image will be lighter. You will have to remove the roller in order to clean it, (TURN THE POWER OFF) there is a bendable plastic tab at the right side end of the roller that will release the roller. I personally drench the roller with metho and then wrap a rag around it and squeeze the metho/toner out (dont do this with lexmark rollers, they deform) let dry and give it a try, also check the end of the metal rod and where it connects for contamination.
Mar 16, 2007 | OKIFAX 4580 Plain Paper LED Fax
HP OfficeJet J4580 All-In-One Laser Printer Logo
126 people viewed this question
Seeker5211
Seeker5211
