Question about Jenn-Air JFC2089H Bottom Freezer French Door Refrigerator
Icing in freezer
Jenn-air french door fridge w/bottom freezer iced up yesterday. Does not seem to be defrosting the ice that has caked on the racks. Read the guide but did not see any reference to defrosting in this situation. Did I miss something? Or will it eventually defrost (this morning there was still icing on the rack, top of freezer....
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 531 Answers
You have defrost problem
Posted on Apr 06, 2009
Model # MFF2557HES Top refrigator section stoped cooling freezer is working
You may have Ice buildup in the freezer. You freezer has a fan in the bak that sends the cool air to the fridge. Your fridge dial determines how muh cold air comes from the freezer. Try defrosting the freezer. You may have to pull the back panel off of the inside of the freezer to get the ice thawed. The ice build up is likely causing the air to not get to the fridge. Hope it works.
Aug 16, 2012 | Maytag MFD2560HES Bottom Freezer French...
My freezer has ice on the bottom,we keep cleaning it out and the ice keeps coming back
I need to ask, what kind of ice are we talking about, ice cubes or a slate? If cubes there is a gage that can be added to the ice maker arm to prevent this. If its a slab or slate, than I would look at the defrost drain system in the back of the freezer to be clogged. If no ice there, is it possible not all the water from the ice maker is getting into the ice maker?
I hope this helps or leads you in the correct direction.
Aug 17, 2011 | Jenn-Air JFC2290VEP (21.8 cu. ft.) Bottom...
Seems the freezer door was not completely closed. Ice started ot melt and then form icicles! Well we closed the freezer the next morning. Now the ice maker and water dispensor are not working. In...
when you closed the door, the freezer froze all the condensation/melting ice,hence the icemaker freezing.
the best solution is a TOTAL defrost/clean out,then dry out.DO NOT USE HOT WATER/SCRAPERS,let it defrost naturally or use car de-icer.wipe out with bicarb to keep fresh.and then restart as new.
Sep 11, 2010 | Jenn-Air 21.6 cu. ft. Side-By-Side...
The ice tray is not producing ice and we have the handle up. I think the ice makeer has frozen itself over. Can the ice make be removed or thawed out without unplugging the whole fridge?
the handle needs to be in the down posit. ans if up it shuts the ice maker off. .. you can defrost the ice mker with a turkey baster & hot water . use towel under icemker .. mm
Aug 10, 2010 | Jenn-Air JFC2089HP Bottom Freezer French...
I have an LG LFC21770 refrigerator and have noticed a build up of ice on the back wall of the freezer section. Yesterday, when I opened it to get some ice - the ice was frozen but had obviously melted...
If the freezer fails to defrost you get ice building up at the back of the freezer.
The defrost cycle relies in a thermistor transducer to detect the ice build up and to turn on the defrost cycle. The water usually then drips down to a tray under te fridge and then gets evaporated away.
Hopefully you only have a problem with the thermistor and not the defrost circuitry,
This is hard for a repair man to diagnose as when you call them out to your fridge it will be impossible to diagnose if the freezer is totally packed with ice.
And if you let it defrost totally it will be hard to diagnose as they may not be allowed to use freon to cool the transducer.'
So if you call someone in to check this you need to know if the ice build up will be a problem for them .
Youtube has several videos on this situation .
Apr 21, 2017 | LG LFC21760 Bottom Freezer French Door...
Water is leaking out the bottom of my brand new Jenn Air French door model JFC 2089 HE. Why?
likely a lot of condensate has been collecting in the catch tray, and it hasn't been able to evaporate off. You may have to slide the fridge out, and empty the tray by hand.
Nov 02, 2009 | Jenn-Air JFC2089HE French Door...
Q: Does the water for the ice maker go thru the in-fridge filter?
the water should go thru the filter first then to everything else.
Jan 02, 2009 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Jenn Air (french door freezer on bottom) icemaker - 2 years old
the water supply in the unit may be blocked or frozen up at some stage, i would try a full defrost for 36 hours and then try it out.
Jun 06, 2007 | Jenn-Air JCD2295HES Side by Side...
Jenn-Air JFC2089H Bottom Freezer French Door Refrigerator Logo
409 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
