Question about Lexmark X5470 All-In-One InkJet Printer
Power won't stay on...power cord must be pulled hard to one side
When I release the power cord that I have been pulling hard to one side on the back of the Lexmark printer, it will shut off when no longer being pulled hard. Weird?
Faulty connections in the wire. get a replacement. switch off power to it and put it to one side. replacement wire shouldnt cost much.
Posted on Feb 15, 2009
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers ยท I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
Cord won't stay out, it keeps going back in
when pulling the cord out, it should 'keep' it that spot if you pull a certain direction, cant recall if it is up, or down, left or right, and pulling it opposite direction releases the cord again
Mar 10, 2013 | Electrolux EL6984A UltraSilencer Green...
Pull cord hard to pull and won't reel back in
should never pull cord unless correct amount of oil is in it !, My advise take back to sears and buy a Toro ! Did you have the blade break lever pulled back ?
Oct 11, 2012 | Craftsman 675 Series 190cc 22" Briggs ...
Pull cord pulls hard won't start
Remove the top engine flywheel & pull cord cover
Most likely dirty,as well as worn out. or the cord
is in the wrong place,you will see that,once apart
You can work on it some & down the road
get a new one if you have to
Jun 11, 2012 | Husqvarna 6021P 21-Inch 149cc Kohler XT-6...
Pull started cord won't recoil after attaching a new one
your spring may be broke or might just have to rewind it they could be a pain somtimes
Apr 07, 2012 | Ryobi Factory Reconditioned 18" 40cc...
I have an hp m8425f and the tower won't turn on,
Remove the Power Cord, then press and hold the power button for 30 seconds. After 30 seconds, plug the cord back in and press the power button. If it works, you had a Static Charge Buildup that had to be released.
Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.If the above two steps fail, pull the main power plug that comes out of the power supply and plugs into the motherboard. The end that plugs into the motherboard is probably about two inches long, Grab the release latch on it and press it while pulling up to unplug it. Wait 30 seconds then plug it back into the motherboard. Push it back in firmly.
Try turning on the system.
Apr 04, 2012 | HP Computers & Internet
Loose hood cord 95' civic, first I had to push the little latch that makes the hood shut completely with a screw driver now it won't even open (the hood) I pulled on the cable with pliers but no...
Just perform some checks please,
  • try to pull the hood release lever with its cable tightly pulled towards you.
  • that may tighten the loose cable so a release can happen
  • then pull out the hood piece hard, so the lock would release.
  • trimming is not a good idea, because it would be hard to set it back into the assembly.
  • try this, good luck. vote it!!
Sep 24, 2011 | 1995 Honda Civic
The battery light on the tower stays on.
pull out the pwr cord and press the pwr button for one min and then release. this process is called as power drain. replug the pwr cord at the back of the computer and check. if its works then good or else replace the SMPS the power unit inside the computer. for sure it has gone bad. power unit is easily available in nearby retail outlets.
May 12, 2010 | HP Pavilion 520c PC Desktop
When i pull the starter cord it pulls back really hard
pull off the spark plug and spray wd40 wait 15 min to 30 min and then pull without spark plug in then put the spark plug back in and then try it
Apr 15, 2010 | Craftsman 8.50 Torque Rating Dual...
System turns on however hard drive will not cycle nor will mouse or key board activate
Turn power off and unplug power from computer.
Unplug printers,backup drives and speakers.
Open case and unplug power supply from the board.
plug power cord back in press the power button.
Of course nothing will happen.
unplug power cord again.
plug power supply back into the board.
plug power cord backup and press power switch.
If nothing happens unplug power cord again.
pull out your memory sticks and plug cord back in and press power button.
Of course not much will happen.
But really something is happening to your computer so continue.
Pull power cord and replace memory sticks.
replace power cord and press power switch.
Continue this pulling out pci cards one at a time until you find out what the problem might be.
Try different keyboards and mice too.
Good Luck
Oct 27, 2008 | Intel Computers & Internet
Lexmark X5470 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
