Question about Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw
How do you fit the recoil spring on a homelite 360
The saw stalled, and the pull cord would not move. So I undid the recoil the cover where the recoil spring sits and can not see where it locates to lock in.
  • 603 Answers
Go to m-and-d.com then parts diagram then illustrated parts online then parts look up then select oem homelite then model no. hopefully this will show you correct way.
Posted on Apr 07, 2009
Pull cord on my chain saw will not recoil
Off hand I would say the recoil spring is broken. they can be a bugger to replace. I would remove the cover and take it to a hasqvarna dealer, and have them replace it.
Dec 29, 2012 | Husqvarna Garden
Pull cord will not rewind
  • 1
    Turn the Homelite chainsaw so that the bar and chain are laying flat and the starter cover is facing up. Loosen the four starter cover screws by unscrewing them counterclockwise with the screwdriver.
  • 2
    Take the starter cover off of the engine. Turn the starter cover over to work on the pull starter. Pull the rope out about 6 to 8 inches.
  • 3
    Twist a loop into the end of the rope. Insert the intersection of the two ropes into the notch on the upper flange of the pulley. Rotate the loop back and forth until you notice the recoil spring has disengaged. Unwind the rope from the pulley. Cut off any old rope if you need to replace it with a new rope.
  • 4
    Unscrew the screw holding the pulley to the starter cover using the screwdriver. Take the pulley off the starter cover. Turn the pulley over and remove the recoil spring cassette from inside the pulley.
  • 5
    Inspect the spring inside the cassette to see if it is damaged or overstretched. Replace the recoil spring cassette if it is broken. Lubricate the post on the starter cover using about a dime-sized amount of engine grease.
  • 6
    Put the recoil spring cassette back into the pulley. Set the pulley onto the starter cover and tighten the screw down with the screwdriver. Wind the starter rope back around the pulley in a clockwise direction.
  • 7
    Leave about 6 to 8 inches of rope unwound. Form another loop at the end and insert the loop into the notch on the pulley. Rotate the loop back and forth until you notice the tension is set on the recoil spring.
  • 8
    Remove the loop and place the starter cover back over the engine. Pull the rope out 6 inches and tighten the starter cover's screws using the screwdriver. Release the rope and it should automatically retract
  • hope this helps
    John
    Sep 09, 2011 | Homelite Garden
    CRANK STRING WON'T RETRACT BACK INTO CRANK CASE
    This is an instruction for replacing the starter cord, but your problem involves the same steps to repair.
    This is a messy frustrating job, and if you had to put a price on the hassle that it is, it is probably better to pay somebody else to do it. That said, remove the starter cover with the cord and pulley inside. If there is a plate holding down the cord pulley, remove it and carefully lift out the pulley, try not to dislodge the recoil spring as this is where the frustration part comes in. Remove the old cord and insert the new cord end into the hole and copy the old knot - pass the other end of the cord through the eyelet in the cover. N.B. At this time take note of the direction that the recoil spring coil is orientated. Wind about 3/4 of the cord around the pulley and attach the start handle to the outside end of the cord. Carefully fit the pulley over the spring and place the cord into the cutout in the pulley. Wind up the pulley so that it engages in the curl in the inside of the recoil spring and further wind up the pulley in the opposite direction of the normal pulley start pull, holding the cord in the little cut-out so that the cord does not wind up as you wind the spring. It probably takes about 5 extra turns on the pulley to get the recoil tension right. Always hold the pulley in place to prevent the spring from jumping out. Release the cord so it can retract and replace the retaining plate. This is all if the spring does not jump out - which it so often does.
    If the spring jumps out, hold it by the inside portion and start winding it up, pulling it tight to keep the coil small enough to fit back into its receptacle, . Once the spring is wound up and will fit into its position the problem starts. I found that gripping the spring with an alligator jaw vice grip will allow you to replace the spring and carefully release it without it going wild again, engaging the outer hook in its retaining slot or around its peg. Trying to feed the spring into position coil by coil seldom works, it has to be wound up outside and then inserted, especially on a small motor.
    This procedure is as difficult to explain as it is to carry out. I have done many cord replacements and always dread the next one. If you have any problems, feel free to come back to me.
    Jul 11, 2011 | Homelite Consumer Products 4.0 Amp, 13 In....
    Recoil spring came out, how do i grt it back
    This procedure is as difficult to explain as it is to carry out. I have done many cord replacements and always dread the next one. Please rate this solution and if you have any problems, feel free to come back to me.
    May 20, 2011 | Homelite Mighty Lite Lawn Trimmer
    How do you rewind the spring for the pull rope.
    This procedure is as difficult to explain as it is to carry out. I have done many cord replacements and always dread the next one. Please rate this response and if you have any problems, feel free to come back to me.
    May 19, 2011 | Homelite Garden
    Spring on homelite chainsaw came out while I was replacing pull rope. Help
    Get someone to hold onto the recoil and spin the spring back in until desired tightness. You'll have to remove the clip on the centre post before you have to recoil the spring. Take your time so you only have to do it once. good luck
    Sep 20, 2010 | Homelite ZR10926 16" Chain Saw
    Recoil spring on homelite chain saw doesn't retract pull rope
    Easy suggestion would be to get new spring coil. Is it older saw? Have had to change mine on poulan saws before.
    Jul 04, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
    Starter on trimmer wont retract
    i'm sorry to tell you this, you have to take take the hole recoil apart.either the spring is broken or the dog that holes the spring is not engaged.to fix it you have to take it apart.restring the rope,make sure the dog is catching the spring,rotate the recoil rotor to tension the spring,retie the handle and reinstall the recoil as an assembly.hope this helps,let me know if you have any questions...........
    Jun 02, 2009 | Homelite Mighty Lite Lawn Trimmer
    Recoil not returning rope when pulled
    There is a spring inside the pull cord housing that makes the cord come back in, it probably undid itself, remove the housing cover and rope assembly and you will see the spring, you need to retighten it and place everything back. hope this helps
    May 31, 2009 | Ardisam 5.5 Hp Rear Tine Rototiller
    Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw Logo
    682 people viewed this question
    Top Homelite Garden Experts
    roeb
    Roland W VanLue
    Roland W VanLue
    Mike Squire
    Are you a Homelite Garden Expert? Answer questions, earn points and help others
