Question about RCA D52W23 52" HDTV CRT TV
RCA D52W23 convergence chip
Well to late..thanks for info but I already went to far ..But Wait, listen ti this !!!! went to bestbuy to pick out new hdtv met and older couple there and there rear projection TV also went out !!! same day, now that got me thinking as we talked more..and with everything switching over to hd signal, seems we both have comcast and both rear projection hdtv`s ..now , call me crazy but I`m thinking this is all comcasts fault and with their update sent ia signal through the cable and fried the convergence chip.. does anyone one think that this is possible?
  • 2 more comments
  • sli20001 Feb 13, 2009
    the picture on it was bent ...still had a picture the convergence menu was gone..the lines were all outta whack.. and the screen was blurry..I found the fuses on it to small for me to change, and yes seemed like it was all on one board..anyway I still had a bent blurry picture.coulld it have been a comcast update fault , seems awfully strange that 2 house sam kinda tv rear projection same day same cale company..just asking is it possible? sounds to me like yes !
  • sli20001 Feb 14, 2009
    Thanks for everyones help..
  • amylattimore Feb 22, 2009
    where do you get the fuses to replace it, and can you fix it any other way until you get the fuses?Our tv is the same make and it just all the sudden went into 3-d mode with a curve at the top of the screen with green,blue,and red lines and no convergence option like stated in manual to fix??
  • jasondobbins Mar 01, 2009
    I already bought a new fuse for my tv put it wont go in is it suppose to be soldered in
  • RCA Master
  • 5,138 Answers
THERE is no convergence ICs on these sets it does have convergence board it has serveral ALuminnin heat sinks on it If comcast was at fault it would have fried your SSB board which will shut TV down Cost of Board is 352.00
Posted on Feb 13, 2009
  • ladywinn
    ladywinn Feb 13, 2009
    If you do not see convergence on menu when you go to setup then Fuse FL231 is opened replace it and that will fix your problem it will be on right side of Flyback Transfomer there is 3 fuses right in a roll it will be the middle fuse they look small brown rectrangler caps but they are fuses.
How do I access RCA HDTV D52W23 Service Menu?
Shut unit off. Wait 10 to 15 seconds then press and hold volume down and channel down together for 10 to 15 seconds. This will get you into the service menu.
Apr 07, 2010 | RCA D52W23 52" HDTV CRT TV
My RCA D52W23 has 3 colors split.
Thats a convergence failure. You can get a repair kit called " The ITC222 and ITC222A convergence option missing repair kit" From www.tvrepairworld.com which should solve the issue. The kit also contains the CD with instructions.
Apr 02, 2010 | RCA D52W23 52" HDTV CRT TV
RCA D52W26- 52 " rear projectio- 3d colors,,,is convergence issue
um i think your gona meet your maker,,,your solutions are not being tolerated.. listen...to the new maker, he can and will make you learn what manners are!!
Jan 22, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Convergence problem
Did you replace the convergence power supply board, or the Convergence board?
Sep 23, 2009 | RCA D52W23 52" HDTV CRT TV
I have a rca 52" d5223w, the picture looks like it is in 3d, someone said it was a circut board but which one?
HI, this will be the convergence board in this case. the chip set on this particular board is malfunctioning at this time. i recommend replacing the convergence board asap, if possible.
This will correct this issue.
Jul 21, 2009 | RCA D52W23 52" HDTV CRT TV
No Convergence adjustment option in my RCA Projection TV
please check out the fl231 fuse poblem in the tips and trics under willtab profile you may have this simple repair
Jun 17, 2009 | RCA D52W23 52" HDTV CRT TV
I WANT TO CONVERGE MY RCA REAR PROJECTION TV. HOW?
Here is a link to the detailed instructions for the RCA ITC222 convergence adjustment proceedure CD with detailed photos.
http://servicemanuals.vstore.ca/product_info.php/pName/itc222-convergence-and-geometry-adjustment-cd/cName/rca
Jun 14, 2009 | RCA D52W23 52" HDTV CRT TV
Rca r52wh74 - no auto convergance
Go to menu then setup look for convergence if it is missing on menu then you have a open FUSE/ FL231, But if you have convergence on menu then go into service mode turnTV off then PRESS and hold at same time ch- and vol- wait for set to come on then release TV should now be in Factory settings.
Feb 20, 2009 | RCA D52W23 52" HDTV CRT TV
RCA D52W23 52" HDTV CRT TV Logo
1,164 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
