Question about Sanyo Katana® II Cellular Phone
Antenna radiation blocking
Is there a built in shield on my Katana II blocking outgoing signals on the side of the phone that has the keypad?
  • 14 Answers
The answer is no.
Posted on Feb 21, 2009
Katana II: my keypad doesn't work.
there is a possibility that teh contacts ar dirty or the circuit itself for the keypad is damage.
let me check for parts you may check on to.
Aug 12, 2008 | Sanyo Katana SCP-6600 Cellular Phone
Can i insert a memory card to my katana 2 cellular phone?
The Katana II is a good durable phone and well priced, has a 21 Mb internal memory but, does not sport a memory card slot. It is not a GSM phone and therefore does not utilize a SIM card. So the answer is no. You can, however, download your data to a computer from a memory card such as a SIM, SD, Micro SD, Memory Stick (Sony), XD, or CF using software tools, the proper USB cable, and a Digital Concepts 6 slot card reader or the like, and then upload them to your Katana II. The only limitation is the size of the internal memory. If I did not work at a cell repair shop with all the goodies available, I would take it to a service store and pay the pros. It can get a little tricky.
Check out this link for the "Phone Scoop" on the Katana II.
http://www.phonescoop.com/phones/phone.php?p=1231
Aug 05, 2009 | Sanyo Katana® II Cellular Phone
My keypad on my Katana stopped working. Can only
Friend, Check the flex connection from the keypad interface then clean the board or the doom with pencil eraser
Jul 25, 2009 | Sanyo Katana SCP-6600 Cellular Phone
Weak roaming signal with Sprint Katana 2 cellphone
Call sprint and ask them to flag you for a PRL update. Then dial *2 and it will automatically update.
I checked in the Katana II menu and there is no option to update the PRL
Feb 03, 2009 | Samsung Instinct Cell Phone
My vizio tv has a ticking noise
Unless you are getting your input signal from an antenna (in or outside) it isn't likely being disturbed by radiating sources such as blinking lights, kitchen mixers, etc.
The shielding on any cable or satellite system keeps such airborne interference from invading your receiver. You might just check to see if signal cables are well-attached; not with a wrench but a firm twist or those that just plug in should be pulled and reinserted in case a shield is not contacting well.
Dec 21, 2008 | Vizio L37 Television
Six months is well under the manufacturer warranty. Call Sprint or take it into a store.
Apr 24, 2008 | Sanyo Katana SCP-6600 Cellular Phone
How to improve on Wireless Range
You can use repeater with your router to increase wireless router signal strength.
Feb 19, 2006 | NetGear RP114 (RP114CN) Router
Wireless and Antenna Terms Wireless routers, access points, and adapters send and receive radio wave signals through antennas. The antenna is hidden inside adapters, but on routers and access points there's a visible antenna. Radio waves can be focussed like a lightbulb. And like a light, some materials reduce or stop radio waves. While light focused from several lights is brighter and makes it easier to see, several antennas in the same area cause interference ? the radio signals will be muddy and confused. Your goals in optimizing power are: * Avoid obstacles. * Avoid interference. * Increase signal strength. Power affects how far an antenna radiates. * Use the equipment in places it's most powerful and most sensitive. Antennas don't radiate equally in every direction. Just as the base of a lightbulb blocks light, and just as a light can be focussed by a reflector, so an antenna signal may be blocked and focused. Since people cannot see radio waves, you'll rely on testing and trial-and-error to get an idea of where antennas "shine" most brightly. An adapter's antenna is important, but the most powerful and sensitive antennas are on routers, access points, and detachable external antennas. The focus of an antenna is either omni-directional antenna or directional. "Omnis" are used in most home products, they radiate horizontally all around, but are weaker upward or downward. When visible, these antennas are usually a rod a few inches long. A directional antenna radiates strongly in a limited direction. It is a flat panel or a dish. These are used for point-to-point transmissions (where two antennas are focused directly at each another). These need a line of sight between them, and preferably a large open space around the main beam. When you are near antennas you'll still get a signal, even if you are out of the direction of its strongest signals. But when further away, you have to be in the direction the beam is the most powerful and unobstructed to receive it. One final concept before you go to the above links is interference. Interference is a signal ? one you don't want ? at the same frequency as the one you're using. Interference comes from devices such as microwave ovens, cell phones, 2.4 GHz cordless phones, and copy machines. Interference is also caused when your own wireless signals are bounced off reflecting objects. Objects may partly or completely absorb signals, reflect them, bend them, or let them pass right through. Metal and water (including the water in people!) absorb or reflect signals. Air, wood, and glass tend to let signals pass with weakening. And when outdoors, plants and the weather may cause interference.
Feb 19, 2006 | NetGear CG814M Wireless Cable Modem...
Sanyo Katana® II Cellular Phone Logo
57 people viewed this question
Top Sanyo Cell Phones Experts
Computer Repairing
Computer Repairing
Jeffrey Thomas
Jeffrey Thomas
Level 1 Expert
Are you a Sanyo Cell Phone Expert? Answer questions, earn points and help others
