Question about AOC LM729 17" LCD Monitor
Black Screen but has power.
I have a 7LSP monitor that has gone black after rebooting the system. The power light remains on but blinks every 5 seconds. During these 5 second intervals the screen is faintly visible (Very faintly). I opened it up, but did not see any distended capacitators, but not really sure what I am supposed to be looking for..
Not sure what to do, since I am very much a novice at repair.
  • 38 Answers
SOURCE: Monitor problem
You are experiencing an inverter board failure. You will need to replace or repair the inverter. The inverter drives the CCFL lamps that illuminate the screen if the lamps draw to much current or components on the board are overheating it will shut down the backlights. Some monitors have cold solder joints on the toroidal coils of the inverter that causes this problem, very typical with HP monitors, If you are handy with a solder iron you may try just re-soldering board and replacing push-pull transistors for a few more years of use. Provide make and model and I can be more specific about probable cause and solution.
Posted on Jan 18, 2008
JULIANFIX
  • 975 Answers
SOURCE: AOC LM729 17" LCD Monitor Screen goes black
YOU HAVE A DRY SOLDER PROBLEM, You have to open the monitor and check the solders in the PC BOARD , mainly where theres A SMALL transformer resolder it , and try again ,that should fix it . hope it helps
Posted on Apr 20, 2008
  • 33 Answers
SOURCE: aoc lm725 display off after few seconds
I've had a very similar issue on many Dell Monitors. Mine have been under warranty and they usually send me a new monitor, but I believe the issue lies with the power supply within the monitor.
Posted on Jul 10, 2008
bammbammfran
  • 159 Answers
SOURCE: AOC lm720 no screen plus blinking green light
Sorry to say, but it sounds like you power board is due for an overhaul.
It should be fixable since it does show signs of a little life left in it.
It would have to be taken apart. A visual may tell for sure.
Look for bulging capacitors (canister looking things) This a sign of a typical failure.
Of course, not all capacitors bulge when they go bad. That would make things too simple !!
ebaysbammbammfran
Posted on Oct 12, 2008
SOURCE: AOC LM725 LCD Monitor
try looking for bloated caps, check all diodes... see if its not shorted/leaking and finally check the power regulator ic if its not shorted! note: some capacitors and diodes are very tiny, you should use a lens with good amount of light...
if it does not help..... well, what the hell? try pouring some gas, then light it up! that should solve the problem, at least it turned on right? hehehehe!
Posted on Nov 12, 2009
I defragged my computer, restarted, and now my monitor won't come on. When on button pushed, get a green power light but the monitor stays black - cannot get anything on screen :( Helllllpppp!
Please try booting with your windows DVD and see if you screen loads, on that boot DVD you should see an option to repair install, try that. But if after booting to your DVD you see your screen come up, just try a regular restart again before doing a system repair.
Feb 28, 2011 | Impression Products 7LSP Monitor
Screen is black when computer is turned on. Tthe monitor power button blinks, but when you push the button, the light does not stop blinking and the screen stays black.. The monitor was working and last...
Try a different video card or disconnect the one you have in your PC and use the VGA monitor connection on the motherboard. If it works your video card is gone.
Dec 22, 2017 | Envision 19" Widescreen Flat Panel LCD...
When I play some games on my syncmaster 215tw, the screen goes black after 5 minutes. I have to reboot everytime to get the screen back on. The blue light flashes but i cant do nothing until i reboot....
that means your VGA is not big enough to run the game.This problem is not from the monitor but your system.I suggest an upgrade in your system to enhance better performance.
Aug 02, 2010 | Samsung SyncMaster 215TW 21" LCD Monitor
Acer AL1917W blinks off in a split-second, twice
remove power to your monitor; then remove the monitor's back cover and, front cover;
when you can see the circuit board check for a buldged can capacitor or, two; replace these by unslodering them and, resoldering the new ones in place digikey.com sells the capacitors (don't forget the position of the capicitors they go in only one way
Jul 22, 2010 | Acer AL1917W LCD Monitor
Black screen
At this point I believe there are failed caps in your monitor.
http://www.badcaps.net/forum/showthread.php?p=73310
This is very common in all LCD monitors. Did the tech just push the power switch off and on?
From my experience at fixing broken monitors of all brands, I think it is the power supply problem.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
You can get second help from repair shop also.
Apr 20, 2010 | Gateway FPD2275W LCD Monitor
Desktop PC monitor suddenly went black & power light went off
1 either ur VGA card is corrupted or
2 RAM is corrupted
3 Last may be your motherboard is gone - not sure
Jan 04, 2010 | Computers & Internet
The screen remains black when i turn it on. The power button turns green and blinking but the screen remains black.
try using the Fn + F?key (has a graphic of a monitor)F5 or F7 to switch the system from external monitor to the laptop ... you probably have it in presentation mode for external monitor.
Oct 14, 2009 | Acer Computers & Internet
Screen goes black, but power light is on (not blinking)
The problem is not with your screen. Its the problem of Video Card of your system which is unable to send Video Signals to the Screen.
Apr 23, 2009 | Daewoo L700C 17" Flat Panel LCD Monitor
Dell - 17" flat screen
This sounds like the back light is gone on the monitir... to check this look very close at the monitor whet the PC has booted, if you see a VERY dim image on screen then it suggests that the back light is gone.
Many monitors hace a 3 year warranty so I would try a warranty claim before throwing it away
Jul 12, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Monitor screen blackout
check for any DRY SOLDER , specifically around the INVERTER TRANSFORMERS on the PC board . hope it helps
Mar 28, 2008 | Computers & Internet
AOC LM729 17" LCD Monitor Logo
130 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
