Question about Sony WEGA KLV-23HR1 23 in. HD-Ready LCD Television
A white horizontal line moving from bottom of screen to top
Hi, I have a 46' Bravia Sony LCD, I bought it about 2 years ago. Recently I notice that there is a white horizontal line moving slowly from bottom of the screen to the top, once the horizontal line reaches the top, a new one starts from the bottom again. The horizontal line is not that white, a bit blur, can someone please explain to me what 's wrong, what causes it and how I can fix it and how much it will cost ...Thanks in advance..Hank
  • 3153 Answers
SOURCE: Airsoft gun hit Sony Bravia LCD screen, can this be repaired??
Yes but not cheaply
Posted on Aug 10, 2009
  • 335 Answers
SOURCE: A fine green vertical line displayed on the Sony Bravia 46.
Thats a pixel data problem, there's no data being sent to that row of pixels so they don't change color. This is a pixel address registry (PAR) issue and the PAR circuits need to be serviced its usually due to open or shorted SMT components on the PAR circuits. PAR also sends data, voltage, and control to each pixel, the green line you see are pixels that have voltage but because there's no data sent too them their all green because there's no control. If the pixels have voltage but no data or control they show up as green red, blue, yellow, or whit line vertically down the LCD panel. The vertical-horizontal section of PAR are controlled by 16 to 32 bit micro-controllers which may need replacing. If its under warranty take it back if not have your local repair center fix the tv for you...
Posted on Nov 09, 2009
SOURCE: I have horizontal lines in my screen about every
I have the same problem, mine is not even 2 years old, mine was getting worse as the days went on, it took all day to fix last week, got fed up and bought a new TV. I am asking around if it can be fixed. please let me know if you get any where.
Feeling your pain friend
Posted on Dec 20, 2009
SOURCE: 3 horizontal lines through screen and distortion
Yes this thing start happening to my tv too about 4weeks ago and this goes away in about 15 minutes. TV is only 18 month old and I donot have extende warranty. Please post the solution if someone has got it repaired. Thanks
Posted on Jan 21, 2010
SOURCE: My Sony Bravia 46' XBR46 LCD has horizontal lines
I hope this helps it seems Sony has extended warranty coverage for your TV for this issue.
(any less hurts our averages)
Thank and Good Luck!
Posted on Feb 04, 2010
SONY KDL-46W4100 LCD colour horizontal lines...
Your tv have problem with the T con board. The t con board drives the Pixels in the lcd screen . If there is some problem with the t con board then this can exibits such problem as you mentioned. Normally you can find the t con board in the bottom center of the lcd coverd with a metal cover. Its part number is SONY T-CON: E40951307. If its avilable then try to replace the same which will solve the problem. Its a regular complaint with the Lcd tv's. I have added the picture of tcon board.
Som times if there is any loose conatct in the pannel connection which comes to the t con board then also the same problem can occur. Before going to replace the board do one thing remove all the connections to the t con board and reconnect it. Some times it will solve the problem. If you need any more assistace feel free to conatct me through fixya.
Dec 12, 2011 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
My Sony Bravia 46" has a 1" thick black line horizontally thru the middle of the screen. It separates the top and bottom. Has anyone seen this happen before?
It sounds lcd screen problem and lcd panel (screen) will be replaced. Please check with local tv repair shop or nearest Sony service center for lcd screen replacement.
Jun 17, 2010 | Sony BRAVIA KDL-40XBR3 40 in. LCD HDTV
The reasons for the fault may be due to:
  1. The Control PWB only causes this defect when the Backlight Control Signals are Output from the Control PWB.
  2. No LVDS signal may also result in this symptom.
Dec 04, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
I have a new Sony Bravia 46inch LCD tv with direct TV remote RC64R, what code can I use to get my remote to work? I've tried all the codes in the book.
i have a 46 inch sony bravia that i bought in 2007. recently i have noticed that the screen is showing horizontal lines (purple?) about that come and go. any advice would be greatly appreciated
Jul 11, 2009 | Sony BRAVIA KDL-46XBR2 46 in. LCD HDTV
Sony Bravia 42" Horizontal Lines
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Oct 19, 2017 | Sony Bravia KDL-42V4100 42 in. LCD TV
Horizontal ines---original post got wiped. Sorry.
leaky cap(s) in vertical circuit. shouldn't be more than $125 (plus taxes) parts and labour
May 14, 2008 | JVC AV-27230 27" TV
A horizontal line on sony 32'' LCD
This is a known defect with the lcd panel.With a little persistence to the customer support with sony they will fix the problem for free.
Apr 24, 2008 | ViewSonic N2750w 27 in. HD-Ready LCD...
Line in picture
Send me a Digi-pic of the screen please.. Good starting point..
Jan 09, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony Bravia XBR 40" LCD
1) Press MENU.
2) Scroll to SETTINGS.
3) Scroll to SCREEN.
4) Go to HORIZONTAL CENTER. Move the picture to the right. Hopefully, the line will go away. Otherwise, there is a problem with the pixels or the signal processor. Call 1-800-222-SONY. Or, Have a high-limit credit card handy for out of warranty repairs. Sorry about that.
Aug 27, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony WEGA KLV-23HR1 23 in. HD-Ready LCD Television Logo
133 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
