Question about Philips Televison & Video
Philips dvdr3480 won't recognise blank discs
Can anyone help. I've been using the abobe philips dvd recorder for 6 months or so and quite happily recording onto blank memorex dvd-r discs.
However, the last couple of times I've tried to record, the machine tries to load the disc as though it has content on it, comes up with an error message, and won't let me record.
The discs are from the same pack as the ones I've been successful with, and I've tried discs from a new pack. No luck!
Has anyone encountered this problem and found a solution please.
Rob Ansdell
SOURCE: Panasonic DMR-E50 won't recognise blank DVD's only
You can only record to dvd-ram or dvd-r NOT dvd-rw!
Posted on Mar 20, 2007
SOURCE: dvd recorder won't record on DVD-RW disc.
CLEANING THE DISC LENS ? If this unit still does not perform properly although you refer to the relevant sections and to ?TROUBLESHOOTING GUIDE? in this Owner?s Manual, the laser optical pickup unit may be dirty. Consult your dealer or an Authorized Service Center for inspection and cleaning of the laser optical pickup unit. FROM EWR20V5 OWNERS MANUAL FUNAI-CORP.COM
Posted on Jul 01, 2007
SOURCE: Recording Error "Can not record on this disk/E4 54037380
I had that exact same problem. I would record a bunch of dvds with no problems for months and then some and one day it doesn't work. Only this showed up E4 EA03738B. However I've found the solution. Instead of going out and returning the recorder or buying new dvds just purchase a Laser Lense Cleaner. It's a dvd cleaner. Works like a charm.
Posted on Jun 24, 2008
SOURCE: Won't Read blank disc!!
I my DVD-HR735 wont recognise any discs at times, and is getting worse. I've now discovered (out of frustration) that if I tip the front up to between 30-45 degrees, it will play all the discs it says were unreadable. I've started jamming three dvd boxes under the front of the machine when i want to play dvds.
Posted on Aug 24, 2008
SOURCE: Philips DVDR615/69
Take, if good  batteris from the remote controller and recycel the unit, and by a better one. I have the  same problem, recordings will stay on the dvd only a short thime readable and later the disk is empty.
Sorry my english.
Posted on Feb 10, 2009
Why does not the philips dvdr3480 record?
I would start with the dvd format used for recording, the simplest being dvd+r and dvd-r. Does the unit play a pre-recorded dvd and/or cd? If not, the laser assembly would be the first suspect. The delay in reading discs can be a sign of a borderline laser. Is your record overwrite function turned on, this overwrites previous material when starting each new recording when using +-rw discs. Verify if a format is required for the type of disc used for recording, page 45. Is the correct country/region selected?
Oct 26, 2017 | Televison & Video
The dvd recorder has stopped recognising dvds that previously it would play quite happily. Is the likely cause a dirty lens or is it more likely to be something to do with the spindle? I get the "cannot...
I presume you hade cleaned the discs and the players optical lense before posting this request and also tried them on another player?
Basicaly If they do not work on other players then the discs have now failed for some reason: many budget priced discs I have come across only work for a few years.
If you have a 'spindle problem' then your laser is probably slowly moving off track. If so you should be able to record and then playback on a GOOD disc for a while.
May 27, 2010 | Panasonic DMR-E50 DVD Recorder
The DVD side will not recognise any disk i offer it to record to it shows a circle with a red x on it dislays that the disk is blank on the front panel
Make sure you are using the right kind of discs check the manual My player will only play the philips brand blank dvds. Also clean the player with a philips lens cleaning disc if that does not work you may, as I had, a hair on the disc spinner inside the player that caused errors.
hope this helps
gary cox
Mar 27, 2010 | Philips DVDR3430V DVD Recorder/VCR
Recording with a philips DVDR3480 using dvd+r
my phillips dvdr3480 will not let me record from my camcorder it states writing has failed please help
Dec 10, 2009 | Philips Televison & Video
Unlock region code for Philips DVDR3480 region code 5
Here you go.....
The only thing you do to unlock DVDR3480 is this:
With NO disc in your DVDR3480-player you press SETUP on the remote and then press this code: 5 0 1 8 ,now you can pick Region-code with the remote from 0-6
( 0=Region free)
Jul 07, 2009 | Philips DVD625 DVD Player
My Philips DVD8421 burner will not recognize a blank DRD-R disc.
Ok, the reason is quite simple. The Philips DVD8421 does not recognise the DVD-R format.Not all DVD/CD burners read all discs. It does recognise DVD+R though. So all you need to do is use these discs instead. This should solve your problem.
Hope that helps.
Dec 05, 2008 | Philips (JR24CDRW99) CD-RW/DVD-ROM (Combo)...
I cannot open the DVD drawer on my Philips DVDR3480 DVD RECORDER – it just won’t open? The screen display just keeps saying ‘Error’. Any help is appreciated.
I have two of these dvd recorders and both have the exact same problem where the drive won't open. It opens fine when there is a disc in the tray. So I just unscrewed the cover, press the white part which would be over the center of the disc as it's trying to open, it should then open. Then just make sure there is always disc left in the tray.
Nov 26, 2008 | Philips Televison & Video
I bought a Magnavox 810H 160GB HDD/DVD recorder. It's a decent machine which worked perfectly for a few months, but now I can't get it to record to DVD. The HDD recording and playback functions work fine,...
Try switching it over to DVD . Because you may still have it on HDD when you put the disc in it may be that the unit is still thinking you are on HDD and don't recognise it as a disc just the hard drive
Sep 11, 2008 | Televison & Video
Dec 03, 2006 | Panasonic DMR-E50 DVD Recorder
Televison & Video Logo
95 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
