Canon Pixma MP220 won't print
I've refilled the ink cartridge but the printer still says ink has run out and won't print.Is there any way to reset the counter or printer.
  • Anonymous Apr 20, 2009
    Where is the reset button on the mp220. there isnt a button called this
  • ken_sue21 May 11, 2010
    is there a way around this
    Problem Solver:
Hi problem fixed through a previous post that is by holding the reset button for 5 seconds.
Posted on Feb 14, 2009
Canon pixma mx350 printer ink level shows exclamation mark about the icon
If you are using an ink refill kit (or buying ink that has been refilled, the ink level will not show accurately) also, if refilling yourself you must clean the pint area of the cartridge with alcohol before installation, and then run the 'clean print head' tools from you Canon menus.
I recommend buying Canon ink, at least for 1 in 4 refills to reset your ink levels.
Nov 20, 2013 | Canon PIXMA MX350 Wireless All-in-One...
Canon PIXMA MP 500 ink refills stop working
you have to reset the ink cartridge.. you have to use a ink refill reseter which come along when you buy a refill kit..
thank you.
May 03, 2008 | Canon Pixma MP500 All-In-One InkJet...
How do I reset or disable the ink level indicator on the Canon mg2120?
Inkjet cartridges dried up at the nozzles. Can be dissolved by water to print again. Refill cartridges done by yourself can have dried up ink left in the cartridge to make it too concentrated. Too easy to dry up.
Jul 15, 2012 | Canon PIXMA MG2120 Inkjet Photo All-In-One
I refilled the ink cartridges on my canon mp250 copier because it stoped printing. The little info box said that the ink was running low now it still won't print . I 've re inserted the ink cartridges...
originally, when u have ink cartridges in Canon product run low u need to buy new ones, because it was designed like that. even u have refilled the old cartridge full, it will detected low ink because the old cartridge already detected for the beginning. this designed to make Canon buyer to buy new ones ink cartridge. but, there some trick to make your old cartridge detected as new one, all u need just to reset the setting for cartridge recognition. try to visit this site:
http://resetcanon.com/reset-canon-mp250-pixma-inkjet-all-in-one-printer/
maybe this site can help your problem, regard riyan.
Mar 09, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Black ink cartridge is full, when printing no black showing
Reset waste ink counter
To reset waste ink counter at printers canon pixma MP150, MP160, MP170, MP180, MP450 and MP460 there any 2 choice, that is :
Start with printer on then run this software
Click Reset Main (main) to reset waste ink counter and then click Reset Platen button (additional)
Or
When you insert a refilled ink cartridge into your Pixma MP500 printer you should get a warning about the refilled cartridge. You should also be prompted, asking if you wish to disable ink level detecting. Agree to do so, and you won't get the warnings again because the ink levels won't be monitored by the printer.
Feb 22, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Dear Adviser The Canon cartridges for my Pixma MP140 printer have run out of ink as indicated both on the printer by the E4 signal and on the computer by a pop up window when trying to print a...
Hello, the printer Canon Pixma MP140 has cartridges with no chips. The printer reads the serial from the cartridge and tells you an estimated ink level. My recomandation is to press the resume/cancel buton for at least 10 seconds, that being the method to cancel the ink counter. After you press the resume/cancel buton you will be able to print, scan and copyas you did before.
The only disadvantage is that your printer will never show the ink level for this set of refilled cartridges, but it will work as well as brand new cartridges.
Nov 12, 2010 | Canon PIXMA MP150 All-In-One InkJet...
My Canon Pixma MP220 is has an error code U051 Chk Ink Blk Col, but i have just refilled my ink cartridges
Using refilled ink cartridges will get this error. You have to reset the waste ink levels by doing the followin
  1. Start with printer off
  2. Press and hold resume Button (triangle in the circle) and click “Power” button. green led should be on
  3. hold the Power button, release Resume Button.
  4. Without releasing the Power Button, double click “Resume” button and then release Both Buttons.
  5. Click “Resume” for four times then click “Power” button, to confirm the selected action (reset counter absorber).
  6. Turn off the printer and turn on again
Aug 12, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Error code U163 on cannon pixma mp220 printer
Those cartridges don't refill unless you have a way to reset the internal chip. Check online for refillable cartridges or a chip resetter. For priming you go into printer properties and choose maintenance and head cleaning, or choose cleaning from the front panel.
Feb 15, 2010 | Canon PIXMA MP530 All-In-One InkJet...
I have a Canon PIXMA iP100 printer. I refilled my Canon PGI 35 ink tank and the sensor did not reset so it still says that it has no ink. Is there a way to reset the sensor so the cartridge will work?
Nope. The ink levels cannot be reset on refills for this type of cartridge. As long as your printer still prints you should be good. If it doesn't print you either need to go get another refill or a Canon brand cartridge.
Dec 25, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
520 people viewed this question
jasbo
jasbo
