Question about Lucent AT&T 1810 Corded Phone (23118)
Need a new hand set
I have an 1810 wall telephone and I need a new handset.
Thank you
Mary Gregorio
HOW DO I REMOVE A CORDLESS PHONE AND SET UP A NEW ONE?
disconnect the base phone at the wall socket and put the new base phone line into the wall socket
follow the user directions that came with the new phone to set it up
Oct 19, 2015 | Uniden DECT 6.0 Cordless Telephone...
Want to be clear about the handset and telephone base set because base set is not responding to handset.
The base needs to be plugged into the wall for power and have a working phone line.
Oct 16, 2014 | Lands Phones
Why doesn't the LCD display doesn't work?
Does the LCD not work at all? or do you mean that it doesn't display Caller ID information? If the LCD is completely dead, you'll need to get the phone repaired. On the other hand, if it's just the Caller ID that's on the fritz, try this: unplug the base from the power socket; remove any batteries in both the base and the handset; wait one minute; plug the base back into the wall and replace all batteries. This will reset the Caller ID so it works again. (Depending on the phone you may or may not lose settings and memorized numbers.) If this doesn't help, the problem will require a professional repair.
Aug 06, 2014 | Uniden D3097 LOUD & CLEAR Cordless Phone -...
Phone ring tone in house cannot hear it do not know house to fix as instructions are in greek
must be sure handset ringer volume is NOT set TO off
2) THE Telephone line cord and power adapter are plugged in properly.
3)the handset may be too far from the telephone base. Move it close to the telephone base.
4) many extension phone on the telephone line to allow all of them to ring simultaneously.
5) if other telephones in your home are having the same problem , the problem will e in service provider
6) other electronic products such as HAM radio detect the phones cause interferences.
7)test a working phone at the wall jack.
8)remove and install the battery again and place the handset in the telephone base
9) wait for the handset to synchronize.
God bless you
Sep 27, 2012 | Lands Phones
Hi, I have a Siemens ( 4000 series) land line phone with an extra hand set. What steps do I need to take to have the second headset sync(?) to the same base so that both headsets are usable? I can not...
Some Panasonic cordless phones come with up to five handsets each will need to be properly adjusted. You may need to set the main handset to synchronize with the base unit plugged into the telephone wall jack and assign special configuration numbers to the other handsets in order to properly identify each one within a specified location. One handset left in the turned on mode may make it impossible to place calls with the any of the other handsets. This will continue until either the battery dies or fails on the handset or the phone is switched off and replaced in its charger for charging again. Synchronize the main handset by pressing the MENU button on the handset, then pressing the down button IN order to select the number you wish to assign to that handset. Repeating this process if you have already done so will greatly decrease the level of errors experienced with panasonic phones
Jan 17, 2011 | Lands Phones
Vtech 6.0 deregister
Getting startedReplace a handsetIf you want to replace a handset or reassign the designated handset numberof a registered handset, you must deregister all the handsets and thenindividually register each handset.To make deregistration easier, read all of the instructions on this page beforeyou begin. To deregister all handsets:Press and hold FIND HANDSET on the telephone base for about 101.seconds (until the IN USE light on the telephone base turns on and starts toflash), then release FIND HANDSET.Press and release FIND HANDSET again. You must press FIND HANDSET2.while the IN USE light is still flashing. The IN USE light flashes forapproximately seven seconds.All system handsets show CONNECTING... The deregistration process3.takes about 10 seconds to complete. All handsets show NOT REGISTEREDwhen the deregistration completes.If deregistration fails, you might need to reset the telephone and try again.To reset:1.Pick up the registered handset and then press talk/flash.Press OFF/CLEAR and place the handset back in the telephone base.2.-OR-1.Unplug the power from the telephone base, then plug it back in.You cannot deregister a handset if any system handset is in use.
May 29, 2010 | Vtech Cordless 6041 Phone
I have a dual handset GE 2.4 GHZ telephone set. The main hand set works but the second hand set will not work, it just beeps and shuts off.
Swap batteries and see if second hand set will work. Can get new battery or a different hand set on eBay.
Sep 03, 2009 | GE Lands Phones
I have a CS60 Handset doesnt work when the headset is connected
First setup the headset as follows:
  • Locate the 2 ports on the bottom of the CS60 charging base. One has an icon of a "full telephone" and the other has an icon of a "hand receiver."
  • Unplug the hand receiver from the base of your existing telephone and plug it into the "hand receiver" port on the CS60 base unit.
  • Then take the short cable that came with the CS60 and plug it into the "full telephone" port on the base of the CS60.
  • Plug the other end of the short cord into the hand receiver port of your telephone (where the hand receiver just was).
  • Make sure the AC Power is plugged into the wall, and then you can adjust the configuration settings.
To be able to hear or speak through the handset, either place the headset back into its charging cradle or press the call control button on the side of the headset. The talk indicator light on the base should go off and no sound will come through the headset.
Note: Make sure that the cables are connected correctly and the handset cable is connected to the base of the CS60 base.
Jan 27, 2009 | Plantronics CS60 Professional Headset
Connecting headset to phone
Setup the Plantronics CS60 wireless headset as follows:
Jun 16, 2008 | Plantronics CS60 Professional Headset
Lucent AT&T 1810 Corded Phone (23118) Logo
32 people viewed this question
Top Lucent Lands Phones Experts
Paul C.
Computer Repairing
Computer Repairing
Michael Galve
Michael Galve
Are you a Lucent Lands Phone Expert? Answer questions, earn points and help others
